> JBOT Admin Wrote:
> Stamped or Cnc, if the curves are the same it doesn't matter how it's
> made.
> They will be stamped in the future for cost savings I bet and it should
> perform exactly the same
Yes they will perform the same as long as everything is nice and smooth the nice thing about the CNC is just a couple of buttons and you can change the radius angle once the mill is set up and running in index.
And just a question for the masses out there to verify what we're doing.
You're using the 13 mm rollers on a modified t j t so they don't rattle around and you get the full ramp not just the last two thirds with the smaller rollers.
To modify you cut the center down so that the plate will sit deeper in the T J T.
I'm running a BX belt with the teeth ground down to the radius in The Notches that way I can get the belt way down in the front pulley for better take off from a stop and speed on super steep hills.
If I remember right I cut it down approximately 2 mm it might have been three can't remember.
CW(edited)
