Re: Two Pintos... lesser config give 5 mph + then better config... Confused.
Bob Selby /
Count teeth on front and rear sprockets as gear ratio will give an edge....most likely 45T on rear and could be 12, 13, 14, 15, 16T ??? on front.....with kit you can run 16 x 40 and roll Treats sells many different sizes...
  Two Pintos... lesser config give 5 mph + then better config... Confused.Topic by: Chris Powers Chris Powers 06/17/18 05:00PM
  Re: Two Pintos... lesser config give 5 mph + then better config... Confused.Re: P D P D 06/17/18 05:18PM
  Re: Two Pintos... lesser config give 5 mph + then better config... Confused.Re: Ryan . Ryan . 06/17/18 05:29PM
  Re: Two Pintos... lesser config give 5 mph + then better config... Confused.Re: Bob Selby Bob Selby 06/17/18 07:14PM
  Re: Two Pintos... lesser config give 5 mph + then better config... Confused.Re: first name last name first name last name 06/17/18 07:59PM
  Re: Two Pintos... lesser config give 5 mph + then better config... Confused.Re: Jack Rutherford Jack Rutherford 06/17/18 09:17PM
  Re: Two Pintos... lesser config give 5 mph + then better config... Confused.Re: Chris Powers Chris Powers 06/18/18 03:50AM
  Re: Two Pintos... lesser config give 5 mph + then better config... Confused.Re: Bas Autowas Bas Autowas 06/18/18 11:09AM
  Re: Two Pintos... lesser config give 5 mph + then better config... Confused.Re: Chris Powers Chris Powers 06/18/18 11:25AM
  Re: Two Pintos... lesser config give 5 mph + then better config... Confused.Re: Jack Rutherford Jack Rutherford 06/18/18 03:24PM
  Re: Two Pintos... lesser config give 5 mph + then better config... Confused.Re: first name last name first name last name 06/18/18 04:05PM
  Re: Two Pintos... lesser config give 5 mph + then better config... Confused.Re: Flagrant - Flagrant - 06/18/18 11:50AM
  Re: Two Pintos... lesser config give 5 mph + then better config... Confused.Re: Chris Powers Chris Powers 06/18/18 02:09PM
  Re: Two Pintos... lesser config give 5 mph + then better config... Confused.Re: Chris Powers Chris Powers 06/18/18 02:11PM
  Re: Two Pintos... lesser config give 5 mph + then better config... Confused.Re: Chris Powers Chris Powers 06/18/18 02:13PM
  Re: Two Pintos... lesser config give 5 mph + then better config... Confused.Re: alex ganz alex ganz 06/18/18 12:44PM
  Re: Two Pintos... lesser config give 5 mph + then better config... Confused.Re: first name last name first name last name 06/18/18 12:56PM
  Re: Two Pintos... lesser config give 5 mph + then better config... Confused.Re: Chris Powers Chris Powers 06/18/18 02:07PM
  Re: Two Pintos... lesser config give 5 mph + then better config... Confused.Re: Chris Powers Chris Powers 06/18/18 02:20PM
  Re: Two Pintos... lesser config give 5 mph + then better config... Confused.Re: Bas Autowas Bas Autowas 06/18/18 03:15PM
  Re: Two Pintos... lesser config give 5 mph + then better config... Confused.Re: Bob Selby Bob Selby 06/18/18 05:53PM
  Re: Two Pintos... lesser config give 5 mph + then better config... Confused.Re: Chris Powers Chris Powers 06/18/18 08:28PM
  Re: Two Pintos... lesser config give 5 mph + then better config... Confused.Re: first name last name first name last name 06/18/18 11:05PM
  Re: Two Pintos... lesser config give 5 mph + then better config... Confused.Re: Probably Fred Probably Fred 06/18/18 06:59PM
  Re: Two Pintos... lesser config give 5 mph + then better config... Confused.Re: Gerry F Gerry F 06/21/18 02:33PM
  Re: Two Pintos... lesser config give 5 mph + then better config... Confused.Re: Chris Powers Chris Powers 06/21/18 09:50PM
  Re: Two Pintos... lesser config give 5 mph + then better config... Confused.Re: Matt Mahloch -- MBM Customs Matt Mahloch -- MBM Customs 06/24/18 09:47PM
