I was curious as to if this was a timing mark? Thanks
Yes, that is the timing mark. I usually time to 1.5mm btdc for stock, and 1.2 or so for kitted.
Make sure to loctite those screws
Awesome, I used some blue on those bolts. I think I have the timing right on the money then. The wooddruf key on the crank lines right up to that mark after using the micrometer. Thanks!
Thanks for all the help from everybody regarding this motor and cdi. I have the the bike running now and she is torquey, quick and nimble. Although I may have a leak still, hopefully just around the intake and carb. Haven't checked yet. Anyways I have no lights. The horn works which I have wired in with the lights. I have a ground on it, should I ground the lights more I'm unsure if they had one from the factory? Thanks again!
