peugeot 103 le partie cdi
hello I just ordered the le partie cdi from treats for a motobecane with the Peugeot adapter plate. I am looking for a wiring diagram. I searched and found some for the motobecane, but not the Peugeot. is the diagram different? if so does anyone have one drawn up? thanks for yall's help
Re: peugeot 103 le partie cdi
yellow goes to your lights the rest just match the colors
thank you sir!
This is how mine is set up with a cdi box from aliexpress coil and 12v rectifier also from the same and it seems to run fine been using it two years now on my 103 1979 i dont gave the "hot wire to a battery though just to a switch for lights and button for the horn all 12v
Hopefully you have ordered the correct one mine was gross cone (1979 103 sp) some are petit cone where the stator side fits gross and petit refer to the tapered crank size
Peugeot 103 have 2 different crankshaft ignition side tapers. One is LARGE TAPER, for POINTS AND CONDENSER. The other is SMALL TAPER for ELECTRONIC IGNITION.Motobecane CDI fits on LARGE TAPER crankshafts.
https://www.mopedarmy.com/wiki/Peugeot_103
If this is the kit you bought all the info is in the advert looks like this kit comes with the cdi and coil ps i also used a trailtech voltage regulator so i could run led bulbs otherwise at wot you get up to 30v
