81 Puch Newport za50 kitted timing?
Hello all,
I was searching around and I could not get a concise answer. I have 70cc treatland treat kit version one with the hi comp head installed on my ZA50. Here’s the link to be more specific:
https://www.treatland.tv/puch-PHBG-treat-party-supreme-p/puch-treat-phbg-party-supreme2.htm
She fired right up but after adjusting the idle after warm up, she started to kind of hiss. I knew it was a compression issue and she died. Two of the head bolts loosened up. When I retightened the head down to specs..... The problem continued until I realized that the aluminum head gasket is pretty much a one shot deal. I have read that you can reuse them by blow torching them or something but I didn’t bother since I had a new spare. This time I coated it in that copper spray stuff and no more compression issues.
So the question I have now is timing. What is the best method to set it/check it? How many degrees? What should my points gap be? Retarded/advanced? Forgive my noobness on it but I don’t have much experience with timing on small engines.
Thanks
Re: 81 Puch Newport za50 kitted timing?
Probably Fred /
Run a head temp gauge too for the higher timing the higher temps.
Start at 14° BTDC with a timing light @ 3,500 rpm and you can add timing if you run cool,
You want around 370-380° Max continual temperatures @ full throttle when fully broken in.
