Re: So Macho
EH 📣FCC of the QCB /
Whoa is right. A water cooled head with a trans fluid chamber would be unreal.
I like the side pocket with heat sink idea. That seems pretty cool. I have an extra KS cover with one broken tab on the inside. I may be able to mess with his idea a bit. That way it is fucks up no biggie.
Thanks for the filter offer! Using the filter would be great. Have it draw from the drain hole, go through the filter, then trough a oil cooler then back to the case in the oil fill hole. Only problem with that is I am running the internal rotor that puts out 10w. I was lucky enough to find LEDs that it can power and be bright enough. I don’t see how I could run the pump. I don’t want to run a battery.....
Thanks for the ideas. This is inspiring.
  So MachoTopic by: EH 📣FCC of the QCB EH 📣FCC of the QCB 04/06/18 11:45PM
  Re: So MachoRe: EH 📣FCC of the QCB EH 📣FCC of the QCB 04/06/18 11:49PM
  Re: So MachoRe: EH 📣FCC of the QCB EH 📣FCC of the QCB 04/06/18 11:54PM
  Re: So MachoRe: EH 📣FCC of the QCB EH 📣FCC of the QCB 04/06/18 11:56PM
  Re: So MachoRe: EH 📣FCC of the QCB EH 📣FCC of the QCB 04/07/18 12:00AM
  Re: So MachoRe: EH 📣FCC of the QCB EH 📣FCC of the QCB 04/07/18 12:11AM
  Re: So MachoRe: EH 📣FCC of the QCB EH 📣FCC of the QCB 04/07/18 12:14AM
  Re: So MachoRe: Captain Janeway Captain Janeway 04/07/18 12:00AM
  Re: So MachoRe: EH 📣FCC of the QCB EH 📣FCC of the QCB 04/07/18 12:18AM
  Re: So MachoRe: ID OD ID OD 04/07/18 12:23AM
  Re: So MachoRe: EH 📣FCC of the QCB EH 📣FCC of the QCB 04/07/18 12:33AM
  Re: So MachoRe: Allan RJH Allan RJH 04/07/18 08:41AM
  Re: So MachoRe: Buttcheeks BUZZARD Buttcheeks BUZZARD 04/07/18 11:37AM
  Re: So MachoRe: EH 📣FCC of the QCB EH 📣FCC of the QCB 04/07/18 01:31PM
  Re: So MachoRe: Derek Cox Derek Cox 04/07/18 01:34PM
  Re: So MachoRe: EH 📣FCC of the QCB EH 📣FCC of the QCB 04/07/18 03:05PM
  Re: So MachoRe: Ryan Graeme Ryan Graeme 04/07/18 04:18PM
  Re: So MachoRe: EH 📣FCC of the QCB EH 📣FCC of the QCB 04/07/18 05:37PM
  Re: So MachoRe: theron ross(ofmc) theron ross(ofmc) 04/07/18 10:38PM
  Re: So MachoRe: alex ganz alex ganz 04/08/18 12:54AM
  Re: So MachoRe: jayson sumpter jayson sumpter 04/08/18 08:42AM
  Re: So MachoRe: Dave & Bummerzz Dave & Bummerzz 04/08/18 09:21AM
  Re: So MachoRe: Stephen Keller Stephen Keller 04/08/18 04:06PM
  Re: So MachoRe: EH 📣FCC of the QCB EH 📣FCC of the QCB 04/10/18 03:55PM
  Re: So MachoRe: Tate G Tate G 04/12/18 02:07AM
  Re: So MachoRe: Mike Boyd Mike Boyd 04/10/18 07:17PM
  Re: So MachoRe: EH 📣FCC of the QCB EH 📣FCC of the QCB 04/11/18 07:40PM
  Re: So MachoRe: Cpt. F. Cpt. F. 04/12/18 12:25AM
  Re: So MachoRe: EH 📣FCC of the QCB EH 📣FCC of the QCB 04/12/18 12:45PM
  Re: So MachoRe: EH 📣FCC of the QCB EH 📣FCC of the QCB 04/12/18 01:02PM
  Re: So MachoRe: EH 📣FCC of the QCB EH 📣FCC of the QCB 04/15/18 01:27AM
  Re: So MachoRe: Born to be WillD Born to be WillD 05/30/18 09:10AM
  Re: So MachoRe: Gator San Juan Gator San Juan 04/12/18 06:49AM
  Re: So MachoRe: Graham Motzing Graham Motzing 04/19/18 06:07PM
  Re: So MachoRe: Max LGN Max LGN 04/23/18 10:38AM
  Re: So MachoRe: EH 📣FCC of the QCB EH 📣FCC of the QCB 04/26/18 10:44PM
  Re: So MachoRe: Max LGN Max LGN 06/05/18 07:37AM
  Re: So MachoRe: EH 📣FCC of the QCB EH 📣FCC of the QCB 06/05/18 02:09PM
  Re: So MachoRe: EH 📣FCC of the QCB EH 📣FCC of the QCB 06/09/18 11:10PM
  Re: So MachoRe: Brandon Weiss (Detective brandon to you) Brandon Weiss (Detective brandon to you) 06/10/18 12:56AM
  Re: So MachoRe: EH 📣FCC of the QCB EH 📣FCC of the QCB 06/10/18 07:38AM
  Re: So MachoRe: EH 📣FCC of the QCB EH 📣FCC of the QCB 06/10/18 08:09AM
  Re: So MachoRe: EH 📣FCC of the QCB EH 📣FCC of the QCB 06/10/18 10:59AM
  Re: So MachoRe: Max LGN Max LGN 04/23/18 10:50AM
  Re: So MachoRe: weldwizard Jake weldwizard Jake 04/27/18 01:39PM
  Re: So MachoRe: EH 📣FCC of the QCB EH 📣FCC of the QCB 05/25/18 10:48PM
  Re: So MachoRe: Flagrant - Flagrant - 05/26/18 10:38AM
  Re: So MachoRe: EH 📣FCC of the QCB EH 📣FCC of the QCB 05/26/18 02:25PM
  Re: So MachoRe: Charlie BUZZARD Charlie BUZZARD 05/27/18 06:17PM
  Re: So MachoRe: Derek Cox Derek Cox 05/27/18 10:06PM
  Re: So MachoRe: EH 📣FCC of the QCB EH 📣FCC of the QCB 05/28/18 12:06PM
  Re: So MachoRe: Probably Fred Probably Fred 05/27/18 07:50PM
  Re: So MachoRe: David Cox David Cox 05/27/18 10:06PM
  Re: So MachoRe: Brandon Weiss (Detective brandon to you) Brandon Weiss (Detective brandon to you) 05/27/18 07:32PM
  Re: So MachoRe: Ryan N. Ryan N. 05/29/18 07:45AM
  Re: So MachoRe: todd amundson todd amundson 05/29/18 10:30AM
  Re: So MachoRe: Ben Whittle Ben Whittle 05/29/18 02:34PM
  Re: So MachoRe: EH 📣FCC of the QCB EH 📣FCC of the QCB 06/01/18 01:52PM
  Re: So MachoRe: todd amundson todd amundson 05/29/18 10:35AM
  Re: So MachoRe: Max LGN Max LGN 06/11/18 08:26AM
  Re: So MachoRe: EH 📣FCC of the QCB EH 📣FCC of the QCB 06/11/18 12:24PM
  Re: So MachoRe: EH 📣FCC of the QCB EH 📣FCC of the QCB 08/31/18 10:06PM
  Re: So MachoRe: alex . alex . 09/01/18 01:08AM
  Re: So MachoRe: will warn will warn 09/01/18 09:40AM
  Re: So MachoRe: EH 📣FCC of the QCB EH 📣FCC of the QCB 09/01/18 10:51AM
  Re: So MachoRe: EH 📣FCC of the QCB EH 📣FCC of the QCB 09/01/18 03:41PM
  Re: So MachoRe: EH 📣FCC of the QCB EH 📣FCC of the QCB 09/03/18 12:14PM
  Re: So MachoRe: Buttcheeks BUZZARD Buttcheeks BUZZARD 09/04/18 10:04PM
  Re: So MachoRe: EH 📣FCC of the QCB EH 📣FCC of the QCB 09/04/18 10:15PM
  Re: So MachoRe: Charlie BUZZARD Charlie BUZZARD 09/05/18 10:37AM
  Re: So MachoRe: EH 📣FCC of the QCB EH 📣FCC of the QCB 09/05/18 11:13AM
  Re: So MachoRe: EH 📣FCC of the QCB EH 📣FCC of the QCB 09/05/18 09:44PM
  Re: So MachoRe: EH 📣FCC of the QCB EH 📣FCC of the QCB 09/17/18 11:50AM
  Re: So MachoRe: EH 📣FCC of the QCB EH 📣FCC of the QCB 09/20/18 08:10PM
  Re: So MachoRe: EH 📣FCC of the QCB EH 📣FCC of the QCB 09/23/18 01:13AM
  Re: So MachoRe: EH 📣FCC of the QCB EH 📣FCC of the QCB 09/23/18 09:07AM
  Re: So MachoRe: Alex hernandez Alex hernandez 09/24/18 08:00AM
  Re: So MachoRe: Charlie BUZZARD Charlie BUZZARD 09/25/18 11:43AM
  Re: So MachoRe: Max LGN Max LGN 09/05/18 07:19AM
  Re: So MachoRe: Max LGN Max LGN 09/25/18 02:33PM
  Re: So MachoRe: EH 📣FCC of the QCB EH 📣FCC of the QCB 09/25/18 08:49PM
  Re: So MachoRe: live ɘvil live ɘvil 10/21/18 03:33AM
  Re: So MachoRe: Charlie BUZZARD Charlie BUZZARD 09/27/18 02:22PM
  Re: So MachoRe: EH 📣FCC of the QCB EH 📣FCC of the QCB 09/27/18 10:05PM
  Re: So MachoRe: Charlie BUZZARD Charlie BUZZARD 09/28/18 04:22PM
  Re: So MachoRe: EH 📣FCC of the QCB EH 📣FCC of the QCB 09/28/18 05:30PM
  Re: So MachoRe: EH 📣FCC of the QCB EH 📣FCC of the QCB 10/17/18 07:14PM
  Re: So MachoRe: Mike Boyd Mike Boyd 10/17/18 07:29PM
  Re: So MachoRe: Gator San Juan Gator San Juan 09/26/18 01:59PM
  Re: So MachoRe: Charlie BUZZARD Charlie BUZZARD 10/17/18 10:52PM
  Re: So MachoRe: live ɘvil live ɘvil 10/17/18 11:32PM
  Re: So MachoRe: EH 📣FCC of the QCB EH 📣FCC of the QCB 10/18/18 06:17AM
  Re: So MachoRe: Garelli Master✨ Garelli Master✨ 10/18/18 03:10AM
  Re: So MachoRe: EH 📣FCC of the QCB EH 📣FCC of the QCB 10/18/18 06:20AM
  Re: So MachoRe: Garelli Master✨ Garelli Master✨ 10/18/18 09:54AM
  Re: So MachoRe: Charlie BUZZARD Charlie BUZZARD 10/18/18 08:30AM
  Re: So MachoRe: EH 📣FCC of the QCB EH 📣FCC of the QCB 10/18/18 09:26AM
  Re: So MachoRe: Charlie BUZZARD Charlie BUZZARD 10/19/18 12:02AM
  Re: So MachoRe: Buttcheeks BUZZARD Buttcheeks BUZZARD 10/18/18 09:21PM
  Re: So MachoRe: Buttcheeks BUZZARD Buttcheeks BUZZARD 10/19/18 03:51PM
  Re: So MachoRe: Garelli Master✨ Garelli Master✨ 10/19/18 05:00PM
  Re: So MachoRe: Buttcheeks BUZZARD Buttcheeks BUZZARD 10/20/18 09:58AM
  Re: So MachoRe: EH 📣FCC of the QCB EH 📣FCC of the QCB 10/23/18 04:18PM
  Re: So MachoRe: Gator San Juan Gator San Juan 10/23/18 04:40PM
  Re: So MachoRe: Charlie BUZZARD Charlie BUZZARD 10/23/18 07:26PM
  Re: So MachoRe: EH 📣FCC of the QCB EH 📣FCC of the QCB 10/24/18 12:24PM
  Re: So MachoRe: â—• ‿ â—• â—• ‿ â—• 10/19/18 05:23PM
  Re: So MachoRe: â—• ‿ â—• â—• ‿ â—• 10/19/18 05:40PM
  Re: So MachoRe: EH 📣FCC of the QCB EH 📣FCC of the QCB 10/20/18 10:14AM
  Re: So MachoRe: Charlie BUZZARD Charlie BUZZARD 10/25/18 01:12PM
  Re: So MachoRe: EH 📣FCC of the QCB EH 📣FCC of the QCB 11/03/18 11:37AM
  Re: So MachoRe: EH 📣FCC of the QCB EH 📣FCC of the QCB 11/03/18 11:48AM
  Re: So MachoRe: EH 📣FCC of the QCB EH 📣FCC of the QCB 11/13/18 10:07PM
  Re: So MachoRe: Daniel '' Daniel '' 11/13/18 10:14PM
  Re: So MachoRe: EH 📣FCC of the QCB EH 📣FCC of the QCB 11/14/18 07:14AM
  Re: So MachoRe: Charlie BUZZARD Charlie BUZZARD 11/14/18 03:34PM
  Re: So MachoRe: EH 📣FCC of the QCB EH 📣FCC of the QCB 12/16/18 04:13PM
  Re: So MachoRe: Crazy Wayne Crazy Wayne 12/16/18 04:17PM
  Re: So MachoRe: Daniel '' Daniel '' 12/16/18 04:31PM
  Re: So MachoRe: EH 📣FCC of the QCB EH 📣FCC of the QCB 12/16/18 04:40PM
  Re: So MachoRe: EH 📣FCC of the QCB EH 📣FCC of the QCB 12/16/18 04:49PM
  Re: So MachoRe: Daniel '' Daniel '' 12/16/18 05:56PM
  Re: So MachoRe: EH 📣FCC of the QCB EH 📣FCC of the QCB 12/16/18 06:15PM
  Re: So MachoRe: Crazy Wayne Crazy Wayne 12/16/18 06:38PM
  Re: So MachoRe: Graham Motzing Graham Motzing 12/17/18 11:56AM
  Re: So MachoRe: Brandon Weiss (Detective brandon to you) Brandon Weiss (Detective brandon to you) 12/17/18 12:49PM
  Re: So MachoRe: Crazy Wayne Crazy Wayne 12/17/18 12:56PM
  Re: So MachoRe: P D P D 12/17/18 12:58PM
  Re: So MachoRe: EH 📣FCC of the QCB EH 📣FCC of the QCB 12/17/18 05:52PM
  Re: So MachoRe: scrot rash scrot rash 12/19/18 10:25AM
  Re: So MachoRe: Max LGN Max LGN 11/14/18 08:24AM
  Re: So MachoRe: EH 📣FCC of the QCB EH 📣FCC of the QCB 11/14/18 10:48AM
  Re: So MachoRe: Buttcheeks BUZZARD Buttcheeks BUZZARD 12/18/18 07:24PM
  Re: So MachoRe: Daniel '' Daniel '' 12/18/18 08:52PM
  Re: So MachoRe: Brandon Weiss (Detective brandon to you) Brandon Weiss (Detective brandon to you) 12/18/18 10:31PM
  Re: So MachoRe: Daniel '' Daniel '' 12/18/18 11:39PM
  Re: So MachoRe: EH 📣FCC of the QCB EH 📣FCC of the QCB 12/18/18 10:40PM
  Re: So MachoRe: Graham Motzing Graham Motzing 12/19/18 09:39AM
  Re: So MachoRe: Charlie BUZZARD Charlie BUZZARD 12/21/18 10:20AM
  Re: So MachoRe: Derek Stahl Derek Stahl 12/21/18 11:06AM
  Re: So MachoRe: Totally normal JBOT Totally normal JBOT 12/21/18 12:19PM
  Re: So MachoRe: Totally normal JBOT Totally normal JBOT 12/21/18 12:27PM
  Re: So MachoRe: scrot rash scrot rash 12/21/18 12:36PM
  Re: So MachoRe: EH 📣FCC of the QCB EH 📣FCC of the QCB 12/22/18 10:19AM
  Re: So MachoRe: scrot rash scrot rash 12/22/18 01:45PM
  Re: So MachoRe: scrot rash scrot rash 12/22/18 02:41PM
  Re: So MachoRe: EH 📣FCC of the QCB EH 📣FCC of the QCB 12/22/18 05:26PM
  Re: So MachoRe: EH 📣FCC of the QCB EH 📣FCC of the QCB 01/21/19 07:19PM
  Re: So MachoRe: Totally normal JBOT Totally normal JBOT 12/21/18 01:09AM
  Re: So MachoRe: scrot rash scrot rash 12/21/18 12:09PM
  Re: So MachoRe: scrot rash scrot rash 12/21/18 12:26PM
  Re: So MachoRe: Buttcheeks BUZZARD Buttcheeks BUZZARD 01/24/19 09:13AM
  Re: So MachoRe: EH 📣FCC of the QCB EH 📣FCC of the QCB 01/24/19 09:23AM
  Re: So MachoRe: kevin Smellaflange kevin Smellaflange 01/24/19 06:39PM
  Re: So MachoRe: EH 📣FCC of the QCB EH 📣FCC of the QCB 11/24/19 09:13PM
  Re: So MachoRe: Daniel '' Daniel '' 11/24/19 10:16PM
  Re: So MachoRe: Garelli Master✨ Garelli Master✨ 11/25/19 07:19AM
  Re: So MachoRe: EH 📣FCC of the QCB EH 📣FCC of the QCB 11/26/19 07:09AM
  Re: So MachoRe: jordan * jordan * 11/27/19 09:52PM
  Re: So MachoRe: EH 📣FCC of the QCB EH 📣FCC of the QCB 11/28/19 08:10AM
  Re: So MachoRe: Daniel '' Daniel '' 11/28/19 06:17PM
  Re: So MachoRe: 🇮🇹💦 Of the Loin 🇮🇹💦 Of the Loin 11/28/19 10:16PM
  Re: So MachoRe: Garelli Master✨ Garelli Master✨ 11/29/19 04:14AM
  Re: So MachoRe: 🇮🇹💦 Of the Loin 🇮🇹💦 Of the Loin 11/29/19 12:31PM
  Re: So MachoRe: Daniel '' Daniel '' 11/29/19 02:02PM
  Re: So MachoRe: 🇮🇹💦 Of the Loin 🇮🇹💦 Of the Loin 11/29/19 10:01PM
  Re: So MachoRe: Daniel '' Daniel '' 11/29/19 10:03PM
  Re: So MachoRe: 🇮🇹💦 Of the Loin 🇮🇹💦 Of the Loin 11/30/19 03:08AM
  Re: So MachoRe: â—• ‿ â—• â—• ‿ â—• 04/27/20 10:42PM
  Re: So MachoRe: EH 📣FCC of the QCB EH 📣FCC of the QCB 04/27/20 11:43PM
  Re: So MachoRe: â—• ‿ â—• â—• ‿ â—• 04/27/20 11:04PM
  Re: So MachoRe: Luke Stroehlein Luke Stroehlein 04/28/20 06:53PM
  Re: So MachoRe: EH 📣FCC of the QCB EH 📣FCC of the QCB 04/29/20 08:19AM
  Re: So MachoRe: EH 📣FCC of the QCB EH 📣FCC of the QCB 10/26/20 10:20PM
  Re: So MachoRe: Daniel '' Daniel '' 10/28/20 08:00PM
  Re: So MachoRe: EH 📣FCC of the QCB EH 📣FCC of the QCB 10/30/20 06:47PM
  Re: So MachoRe: Buttcheeks BUZZARD Buttcheeks BUZZARD 10/31/20 11:36PM
  Re: So MachoRe: EH 📣FCC of the QCB EH 📣FCC of the QCB 11/01/20 12:55PM
  Re: So MachoRe: Pavo Z Pavo Z 11/03/20 06:16PM
  Re: So MachoRe: EH 📣FCC of the QCB EH 📣FCC of the QCB 11/03/20 06:48PM
  Re: So MachoRe: EH 📣FCC of the QCB EH 📣FCC of the QCB 05/11/22 07:36PM
  Re: So MachoRe: EH 📣FCC of the QCB EH 📣FCC of the QCB 05/14/22 03:52PM
  Re: So MachoRe: Jay Rivett Jay Rivett 05/14/22 04:21PM
  Re: So MachoRe: EH 📣FCC of the QCB EH 📣FCC of the QCB 05/14/22 10:38PM
  Re: So MachoRe: EH 📣FCC of the QCB EH 📣FCC of the QCB 05/21/22 04:23PM
  Re: So MachoRe: L e e L e e 05/23/22 09:04AM
