Re: So Macho
EH 📣FCC of the QCB /
> will warn Wrote:
> Did you weld the gear on or what? Looking to do something similar, but I
> have the fast arrow kit not a real ks. They are similar though so Im
> sure I could do what you did.
Not I just cut the triangle part of the KTM clutch down with a grinder. When I got it to the hight I needed I sanded it on glass to make sure it was flat. I then made washers to space out the difference in the gaps between the KS mechanism and clutch.. I chucked up washers in a drill and ground them down to the size I needed by putting a file in a vice. I then tightened it all up. It seems not to slip now that it is torqued down. Only time will tell. I thought about cutting ribs in each to keep it from spinning.....may have to. Idk, it seemed to sit fine under pressure with the old setup.
If ya need a pic or something let me know. No secrets with my InVenTiONs.
  So MachoTopic by: EH 📣FCC of the QCB EH 📣FCC of the QCB 04/06/18 11:45PM
  Re: So MachoRe: EH 📣FCC of the QCB EH 📣FCC of the QCB 04/06/18 11:49PM
  Re: So MachoRe: EH 📣FCC of the QCB EH 📣FCC of the QCB 04/06/18 11:54PM
  Re: So MachoRe: EH 📣FCC of the QCB EH 📣FCC of the QCB 04/06/18 11:56PM
  Re: So MachoRe: EH 📣FCC of the QCB EH 📣FCC of the QCB 04/07/18 12:00AM
  Re: So MachoRe: EH 📣FCC of the QCB EH 📣FCC of the QCB 04/07/18 12:11AM
  Re: So MachoRe: EH 📣FCC of the QCB EH 📣FCC of the QCB 04/07/18 12:14AM
  Re: So MachoRe: Captain Janeway Captain Janeway 04/07/18 12:00AM
  Re: So MachoRe: EH 📣FCC of the QCB EH 📣FCC of the QCB 04/07/18 12:18AM
  Re: So MachoRe: ID OD ID OD 04/07/18 12:23AM
  Re: So MachoRe: EH 📣FCC of the QCB EH 📣FCC of the QCB 04/07/18 12:33AM
  Re: So MachoRe: Allan RJH Allan RJH 04/07/18 08:41AM
  Re: So MachoRe: Buttcheeks BUZZARD Buttcheeks BUZZARD 04/07/18 11:37AM
  Re: So MachoRe: EH 📣FCC of the QCB EH 📣FCC of the QCB 04/07/18 01:31PM
  Re: So MachoRe: Derek Cox Derek Cox 04/07/18 01:34PM
  Re: So MachoRe: EH 📣FCC of the QCB EH 📣FCC of the QCB 04/07/18 03:05PM
  Re: So MachoRe: Ryan Graeme Ryan Graeme 04/07/18 04:18PM
  Re: So MachoRe: EH 📣FCC of the QCB EH 📣FCC of the QCB 04/07/18 05:37PM
  Re: So MachoRe: theron ross(ofmc) theron ross(ofmc) 04/07/18 10:38PM
  Re: So MachoRe: alex ganz alex ganz 04/08/18 12:54AM
  Re: So MachoRe: jayson sumpter jayson sumpter 04/08/18 08:42AM
  Re: So MachoRe: Dave & Bummerzz Dave & Bummerzz 04/08/18 09:21AM
  Re: So MachoRe: Stephen Keller Stephen Keller 04/08/18 04:06PM
  Re: So MachoRe: EH 📣FCC of the QCB EH 📣FCC of the QCB 04/10/18 03:55PM
  Re: So MachoRe: Tate G Tate G 04/12/18 02:07AM
  Re: So MachoRe: Mike Boyd Mike Boyd 04/10/18 07:17PM
  Re: So MachoRe: EH 📣FCC of the QCB EH 📣FCC of the QCB 04/11/18 07:40PM
  Re: So MachoRe: Cpt. F. Cpt. F. 04/12/18 12:25AM
  Re: So MachoRe: EH 📣FCC of the QCB EH 📣FCC of the QCB 04/12/18 12:45PM
  Re: So MachoRe: EH 📣FCC of the QCB EH 📣FCC of the QCB 04/12/18 01:02PM
  Re: So MachoRe: EH 📣FCC of the QCB EH 📣FCC of the QCB 04/15/18 01:27AM
  Re: So MachoRe: Born to be WillD Born to be WillD 05/30/18 09:10AM
  Re: So MachoRe: Gator San Juan Gator San Juan 04/12/18 06:49AM
  Re: So MachoRe: Graham Motzing Graham Motzing 04/19/18 06:07PM
  Re: So MachoRe: Max LGN Max LGN 04/23/18 10:38AM
  Re: So MachoRe: EH 📣FCC of the QCB EH 📣FCC of the QCB 04/26/18 10:44PM
  Re: So MachoRe: Max LGN Max LGN 06/05/18 07:37AM
  Re: So MachoRe: EH 📣FCC of the QCB EH 📣FCC of the QCB 06/05/18 02:09PM
  Re: So MachoRe: EH 📣FCC of the QCB EH 📣FCC of the QCB 06/09/18 11:10PM
  Re: So MachoRe: Brandon Weiss (Detective brandon to you) Brandon Weiss (Detective brandon to you) 06/10/18 12:56AM
  Re: So MachoRe: EH 📣FCC of the QCB EH 📣FCC of the QCB 06/10/18 07:38AM
  Re: So MachoRe: EH 📣FCC of the QCB EH 📣FCC of the QCB 06/10/18 08:09AM
  Re: So MachoRe: EH 📣FCC of the QCB EH 📣FCC of the QCB 06/10/18 10:59AM
  Re: So MachoRe: Max LGN Max LGN 04/23/18 10:50AM
  Re: So MachoRe: weldwizard Jake weldwizard Jake 04/27/18 01:39PM
  Re: So MachoRe: EH 📣FCC of the QCB EH 📣FCC of the QCB 05/25/18 10:48PM
  Re: So MachoRe: Flagrant - Flagrant - 05/26/18 10:38AM
  Re: So MachoRe: EH 📣FCC of the QCB EH 📣FCC of the QCB 05/26/18 02:25PM
  Re: So MachoRe: Charlie BUZZARD Charlie BUZZARD 05/27/18 06:17PM
  Re: So MachoRe: Derek Cox Derek Cox 05/27/18 10:06PM
  Re: So MachoRe: EH 📣FCC of the QCB EH 📣FCC of the QCB 05/28/18 12:06PM
  Re: So MachoRe: Probably Fred Probably Fred 05/27/18 07:50PM
  Re: So MachoRe: David Cox David Cox 05/27/18 10:06PM
  Re: So MachoRe: Brandon Weiss (Detective brandon to you) Brandon Weiss (Detective brandon to you) 05/27/18 07:32PM
  Re: So MachoRe: Ryan N. Ryan N. 05/29/18 07:45AM
  Re: So MachoRe: todd amundson todd amundson 05/29/18 10:30AM
  Re: So MachoRe: Ben Whittle Ben Whittle 05/29/18 02:34PM
  Re: So MachoRe: EH 📣FCC of the QCB EH 📣FCC of the QCB 06/01/18 01:52PM
  Re: So MachoRe: todd amundson todd amundson 05/29/18 10:35AM
  Re: So MachoRe: Max LGN Max LGN 06/11/18 08:26AM
  Re: So MachoRe: EH 📣FCC of the QCB EH 📣FCC of the QCB 06/11/18 12:24PM
  Re: So MachoRe: EH 📣FCC of the QCB EH 📣FCC of the QCB 08/31/18 10:06PM
  Re: So MachoRe: alex . alex . 09/01/18 01:08AM
  Re: So MachoRe: will warn will warn 09/01/18 09:40AM
  Re: So MachoRe: EH 📣FCC of the QCB EH 📣FCC of the QCB 09/01/18 10:51AM
  Re: So MachoRe: EH 📣FCC of the QCB EH 📣FCC of the QCB 09/01/18 03:41PM
  Re: So MachoRe: EH 📣FCC of the QCB EH 📣FCC of the QCB 09/03/18 12:14PM
  Re: So MachoRe: Buttcheeks BUZZARD Buttcheeks BUZZARD 09/04/18 10:04PM
  Re: So MachoRe: EH 📣FCC of the QCB EH 📣FCC of the QCB 09/04/18 10:15PM
  Re: So MachoRe: Charlie BUZZARD Charlie BUZZARD 09/05/18 10:37AM
  Re: So MachoRe: EH 📣FCC of the QCB EH 📣FCC of the QCB 09/05/18 11:13AM
  Re: So MachoRe: EH 📣FCC of the QCB EH 📣FCC of the QCB 09/05/18 09:44PM
  Re: So MachoRe: EH 📣FCC of the QCB EH 📣FCC of the QCB 09/17/18 11:50AM
  Re: So MachoRe: EH 📣FCC of the QCB EH 📣FCC of the QCB 09/20/18 08:10PM
  Re: So MachoRe: EH 📣FCC of the QCB EH 📣FCC of the QCB 09/23/18 01:13AM
  Re: So MachoRe: EH 📣FCC of the QCB EH 📣FCC of the QCB 09/23/18 09:07AM
  Re: So MachoRe: Alex hernandez Alex hernandez 09/24/18 08:00AM
  Re: So MachoRe: Charlie BUZZARD Charlie BUZZARD 09/25/18 11:43AM
  Re: So MachoRe: Max LGN Max LGN 09/05/18 07:19AM
  Re: So MachoRe: Max LGN Max LGN 09/25/18 02:33PM
  Re: So MachoRe: EH 📣FCC of the QCB EH 📣FCC of the QCB 09/25/18 08:49PM
  Re: So MachoRe: live ɘvil live ɘvil 10/21/18 03:33AM
  Re: So MachoRe: Charlie BUZZARD Charlie BUZZARD 09/27/18 02:22PM
  Re: So MachoRe: EH 📣FCC of the QCB EH 📣FCC of the QCB 09/27/18 10:05PM
  Re: So MachoRe: Charlie BUZZARD Charlie BUZZARD 09/28/18 04:22PM
  Re: So MachoRe: EH 📣FCC of the QCB EH 📣FCC of the QCB 09/28/18 05:30PM
  Re: So MachoRe: EH 📣FCC of the QCB EH 📣FCC of the QCB 10/17/18 07:14PM
  Re: So MachoRe: Mike Boyd Mike Boyd 10/17/18 07:29PM
  Re: So MachoRe: Gator San Juan Gator San Juan 09/26/18 01:59PM
  Re: So MachoRe: Charlie BUZZARD Charlie BUZZARD 10/17/18 10:52PM
  Re: So MachoRe: live ɘvil live ɘvil 10/17/18 11:32PM
  Re: So MachoRe: EH 📣FCC of the QCB EH 📣FCC of the QCB 10/18/18 06:17AM
  Re: So MachoRe: Garelli Master✨ Garelli Master✨ 10/18/18 03:10AM
  Re: So MachoRe: EH 📣FCC of the QCB EH 📣FCC of the QCB 10/18/18 06:20AM
  Re: So MachoRe: Garelli Master✨ Garelli Master✨ 10/18/18 09:54AM
  Re: So MachoRe: Charlie BUZZARD Charlie BUZZARD 10/18/18 08:30AM
  Re: So MachoRe: EH 📣FCC of the QCB EH 📣FCC of the QCB 10/18/18 09:26AM
  Re: So MachoRe: Charlie BUZZARD Charlie BUZZARD 10/19/18 12:02AM
  Re: So MachoRe: Buttcheeks BUZZARD Buttcheeks BUZZARD 10/18/18 09:21PM
  Re: So MachoRe: Buttcheeks BUZZARD Buttcheeks BUZZARD 10/19/18 03:51PM
  Re: So MachoRe: Garelli Master✨ Garelli Master✨ 10/19/18 05:00PM
  Re: So MachoRe: Buttcheeks BUZZARD Buttcheeks BUZZARD 10/20/18 09:58AM
  Re: So MachoRe: EH 📣FCC of the QCB EH 📣FCC of the QCB 10/23/18 04:18PM
  Re: So MachoRe: Gator San Juan Gator San Juan 10/23/18 04:40PM
  Re: So MachoRe: Charlie BUZZARD Charlie BUZZARD 10/23/18 07:26PM
  Re: So MachoRe: EH 📣FCC of the QCB EH 📣FCC of the QCB 10/24/18 12:24PM
  Re: So MachoRe: ◕ ‿ ◕ ◕ ‿ ◕ 10/19/18 05:23PM
  Re: So MachoRe: ◕ ‿ ◕ ◕ ‿ ◕ 10/19/18 05:40PM
  Re: So MachoRe: EH 📣FCC of the QCB EH 📣FCC of the QCB 10/20/18 10:14AM
  Re: So MachoRe: Charlie BUZZARD Charlie BUZZARD 10/25/18 01:12PM
  Re: So MachoRe: EH 📣FCC of the QCB EH 📣FCC of the QCB 11/03/18 11:37AM
  Re: So MachoRe: EH 📣FCC of the QCB EH 📣FCC of the QCB 11/03/18 11:48AM
  Re: So MachoRe: EH 📣FCC of the QCB EH 📣FCC of the QCB 11/13/18 10:07PM
  Re: So MachoRe: Daniel '' Daniel '' 11/13/18 10:14PM
  Re: So MachoRe: EH 📣FCC of the QCB EH 📣FCC of the QCB 11/14/18 07:14AM
  Re: So MachoRe: Charlie BUZZARD Charlie BUZZARD 11/14/18 03:34PM
  Re: So MachoRe: EH 📣FCC of the QCB EH 📣FCC of the QCB 12/16/18 04:13PM
  Re: So MachoRe: Crazy Wayne Crazy Wayne 12/16/18 04:17PM
  Re: So MachoRe: Daniel '' Daniel '' 12/16/18 04:31PM
  Re: So MachoRe: EH 📣FCC of the QCB EH 📣FCC of the QCB 12/16/18 04:40PM
  Re: So MachoRe: EH 📣FCC of the QCB EH 📣FCC of the QCB 12/16/18 04:49PM
  Re: So MachoRe: Daniel '' Daniel '' 12/16/18 05:56PM
  Re: So MachoRe: EH 📣FCC of the QCB EH 📣FCC of the QCB 12/16/18 06:15PM
  Re: So MachoRe: Crazy Wayne Crazy Wayne 12/16/18 06:38PM
  Re: So MachoRe: Graham Motzing Graham Motzing 12/17/18 11:56AM
  Re: So MachoRe: Brandon Weiss (Detective brandon to you) Brandon Weiss (Detective brandon to you) 12/17/18 12:49PM
  Re: So MachoRe: Crazy Wayne Crazy Wayne 12/17/18 12:56PM
  Re: So MachoRe: P D P D 12/17/18 12:58PM
  Re: So MachoRe: EH 📣FCC of the QCB EH 📣FCC of the QCB 12/17/18 05:52PM
  Re: So MachoRe: scrot rash scrot rash 12/19/18 10:25AM
  Re: So MachoRe: Max LGN Max LGN 11/14/18 08:24AM
  Re: So MachoRe: EH 📣FCC of the QCB EH 📣FCC of the QCB 11/14/18 10:48AM
  Re: So MachoRe: Buttcheeks BUZZARD Buttcheeks BUZZARD 12/18/18 07:24PM
  Re: So MachoRe: Daniel '' Daniel '' 12/18/18 08:52PM
  Re: So MachoRe: Brandon Weiss (Detective brandon to you) Brandon Weiss (Detective brandon to you) 12/18/18 10:31PM
  Re: So MachoRe: Daniel '' Daniel '' 12/18/18 11:39PM
  Re: So MachoRe: EH 📣FCC of the QCB EH 📣FCC of the QCB 12/18/18 10:40PM
  Re: So MachoRe: Graham Motzing Graham Motzing 12/19/18 09:39AM
  Re: So MachoRe: Charlie BUZZARD Charlie BUZZARD 12/21/18 10:20AM
  Re: So MachoRe: Derek Stahl Derek Stahl 12/21/18 11:06AM
  Re: So MachoRe: Totally normal JBOT Totally normal JBOT 12/21/18 12:19PM
  Re: So MachoRe: Totally normal JBOT Totally normal JBOT 12/21/18 12:27PM
  Re: So MachoRe: scrot rash scrot rash 12/21/18 12:36PM
  Re: So MachoRe: EH 📣FCC of the QCB EH 📣FCC of the QCB 12/22/18 10:19AM
  Re: So MachoRe: scrot rash scrot rash 12/22/18 01:45PM
  Re: So MachoRe: scrot rash scrot rash 12/22/18 02:41PM
  Re: So MachoRe: EH 📣FCC of the QCB EH 📣FCC of the QCB 12/22/18 05:26PM
  Re: So MachoRe: EH 📣FCC of the QCB EH 📣FCC of the QCB 01/21/19 07:19PM
  Re: So MachoRe: Totally normal JBOT Totally normal JBOT 12/21/18 01:09AM
  Re: So MachoRe: scrot rash scrot rash 12/21/18 12:09PM
  Re: So MachoRe: scrot rash scrot rash 12/21/18 12:26PM
  Re: So MachoRe: Buttcheeks BUZZARD Buttcheeks BUZZARD 01/24/19 09:13AM
  Re: So MachoRe: EH 📣FCC of the QCB EH 📣FCC of the QCB 01/24/19 09:23AM
  Re: So MachoRe: kevin Smellaflange kevin Smellaflange 01/24/19 06:39PM
  Re: So MachoRe: EH 📣FCC of the QCB EH 📣FCC of the QCB 11/24/19 09:13PM
  Re: So MachoRe: Daniel '' Daniel '' 11/24/19 10:16PM
  Re: So MachoRe: Garelli Master✨ Garelli Master✨ 11/25/19 07:19AM
  Re: So MachoRe: EH 📣FCC of the QCB EH 📣FCC of the QCB 11/26/19 07:09AM
  Re: So MachoRe: jordan * jordan * 11/27/19 09:52PM
  Re: So MachoRe: EH 📣FCC of the QCB EH 📣FCC of the QCB 11/28/19 08:10AM
  Re: So MachoRe: Daniel '' Daniel '' 11/28/19 06:17PM
  Re: So MachoRe: 🇮🇹💦 Of the Loin 🇮🇹💦 Of the Loin 11/28/19 10:16PM
  Re: So MachoRe: Garelli Master✨ Garelli Master✨ 11/29/19 04:14AM
  Re: So MachoRe: 🇮🇹💦 Of the Loin 🇮🇹💦 Of the Loin 11/29/19 12:31PM
  Re: So MachoRe: Daniel '' Daniel '' 11/29/19 02:02PM
  Re: So MachoRe: 🇮🇹💦 Of the Loin 🇮🇹💦 Of the Loin 11/29/19 10:01PM
  Re: So MachoRe: Daniel '' Daniel '' 11/29/19 10:03PM
  Re: So MachoRe: 🇮🇹💦 Of the Loin 🇮🇹💦 Of the Loin 11/30/19 03:08AM
  Re: So MachoRe: ◕ ‿ ◕ ◕ ‿ ◕ 04/27/20 10:42PM
  Re: So MachoRe: EH 📣FCC of the QCB EH 📣FCC of the QCB 04/27/20 11:43PM
  Re: So MachoRe: ◕ ‿ ◕ ◕ ‿ ◕ 04/27/20 11:04PM
  Re: So MachoRe: Luke Stroehlein Luke Stroehlein 04/28/20 06:53PM
  Re: So MachoRe: EH 📣FCC of the QCB EH 📣FCC of the QCB 04/29/20 08:19AM
  Re: So MachoRe: EH 📣FCC of the QCB EH 📣FCC of the QCB 10/26/20 10:20PM
  Re: So MachoRe: Daniel '' Daniel '' 10/28/20 08:00PM
  Re: So MachoRe: EH 📣FCC of the QCB EH 📣FCC of the QCB 10/30/20 06:47PM
  Re: So MachoRe: Buttcheeks BUZZARD Buttcheeks BUZZARD 10/31/20 11:36PM
  Re: So MachoRe: EH 📣FCC of the QCB EH 📣FCC of the QCB 11/01/20 12:55PM
  Re: So MachoRe: Pavo Z Pavo Z 11/03/20 06:16PM
  Re: So MachoRe: EH 📣FCC of the QCB EH 📣FCC of the QCB 11/03/20 06:48PM
  Re: So MachoRe: EH 📣FCC of the QCB EH 📣FCC of the QCB 05/11/22 07:36PM
  Re: So MachoRe: EH 📣FCC of the QCB EH 📣FCC of the QCB 05/14/22 03:52PM
  Re: So MachoRe: Jay Rivett Jay Rivett 05/14/22 04:21PM
  Re: So MachoRe: EH 📣FCC of the QCB EH 📣FCC of the QCB 05/14/22 10:38PM
  Re: So MachoRe: EH 📣FCC of the QCB EH 📣FCC of the QCB 05/21/22 04:23PM
  Re: So MachoRe: L e e L e e 05/23/22 09:04AM
