Re: Remove ethanol from my gas?
Probably Fred /
> frank dadog Wrote:
> > Mr Moped Wrote:
> > small engines do not like ethanol.
> Sorry but this simply isn't true. Small engines don't like bad gas and
> because they are used infrequently it's more likely to happen with
> ethanol blended gas.
> No matter what gas you buy you should add stabilizer if it's going to
> sit for more than a month. No matter what gas you use you should bring
> the engine up to temperature every other week.
> Do what's required to maintain a small engine and they have problem
> whatsoever with ethanol based gasoline. It's 100% the owner not the
> fuel.
No not always
It’s the old engines of all kinds the were designed for leaded gas and have many rubber parts that ethanol is not good for
  Remove ethanol from my gas?Topic by: Storm Roland Storm Roland 04/04/18 11:55AM
  Re: Remove ethanol from my gas?Re: Full Tuck Full Tuck 04/04/18 12:38PM
  Re: Remove ethanol from my gas?Re: Storm Roland Storm Roland 04/04/18 01:04PM
  Re: Remove ethanol from my gas?Re: - Joe - - Joe - 04/04/18 02:07PM
  Re: Remove ethanol from my gas?Re: Charles Cole (OFMC) Charles Cole (OFMC) 04/04/18 02:00PM
  Re: Remove ethanol from my gas?Re: Full Tuck Full Tuck 04/04/18 02:21PM
  Re: Remove ethanol from my gas?Re: frank dadog frank dadog 04/05/18 02:34PM
  Re: Remove ethanol from my gas?Re: Blaine- The artist formerly known as Plumber Crack "(OFMC)" Blaine- The artist formerly known as Plumber Crack "(OFMC)" 04/06/18 12:35AM
  Re: Remove ethanol from my gas?Re: Bad Cadillac™ Bad Cadillac™ 04/09/18 10:11AM
  Re: Remove ethanol from my gas?Re: Bas Autowas Bas Autowas 04/04/18 02:29PM
  Re: Remove ethanol from my gas?Re: P D P D 04/04/18 03:28PM
  Re: Remove ethanol from my gas?Re: Full Tuck Full Tuck 04/04/18 05:31PM
  Re: Remove ethanol from my gas?Re: P D P D 04/04/18 06:41PM
  Re: Remove ethanol from my gas?Re: Dirty30 Dillon Dirty30 Dillon 04/06/18 08:50AM
  Re: Remove ethanol from my gas?Re: P D P D 04/06/18 11:14AM
  Re: Remove ethanol from my gas?Re: Stephen Keller Stephen Keller 04/06/18 04:33PM
  Re: Remove ethanol from my gas?Re: * * * * 04/04/18 07:17PM
  Re: Remove ethanol from my gas?Re: Probably Fred Probably Fred 04/04/18 08:09PM
  Re: Remove ethanol from my gas?Re: kenny s kenny s 04/26/18 03:51AM
  Re: Remove ethanol from my gas?Re: Joe Schuitema Joe Schuitema 04/04/18 10:02PM
  Re: Remove ethanol from my gas?Re: Mick Doohan Mick Doohan 04/04/18 10:09PM
  Re: Remove ethanol from my gas?Re: Derek Cox Derek Cox 04/04/18 11:01PM
  Re: Remove ethanol from my gas?Re: Thomas TPRF Thomas TPRF 04/04/18 11:50PM
  Re: Remove ethanol from my gas?Re: Stephen Keller Stephen Keller 04/05/18 01:55AM
  Re: Remove ethanol from my gas?Re: EH 📣FCC of the QCB EH 📣FCC of the QCB 04/05/18 04:00PM
  Re: Remove ethanol from my gas?Re: Flagrant - Flagrant - 04/05/18 04:22PM
  Re: Remove ethanol from my gas?Re: P D P D 04/05/18 07:36PM
  Re: Remove ethanol from my gas?Re: frank dadog frank dadog 04/05/18 09:44PM
  Re: Remove ethanol from my gas?Re: P D P D 04/05/18 11:38PM
  Re: Remove ethanol from my gas?Re: frank dadog frank dadog 04/06/18 09:26PM
  Re: Remove ethanol from my gas?Re: P D P D 04/06/18 09:42PM
  Re: Remove ethanol from my gas?Re: Stephen Keller Stephen Keller 04/06/18 01:01AM
  Re: Remove ethanol from my gas?Re: Steve Paul Steve Paul 04/05/18 10:07PM
  Re: Remove ethanol from my gas?Re: Stephen Keller Stephen Keller 04/06/18 10:20PM
  Re: Remove ethanol from my gas?Re: EH 📣FCC of the QCB EH 📣FCC of the QCB 04/06/18 10:59PM
  Re: Remove ethanol from my gas?Re: frank dadog frank dadog 04/06/18 11:39PM
  Re: Remove ethanol from my gas?Re: Mr Moped Mr Moped 04/07/18 01:11AM
  Re: Remove ethanol from my gas?Re: * * * * 04/07/18 11:59AM
  Re: Remove ethanol from my gas?Re: frank dadog frank dadog 04/07/18 04:44PM
  Re: Remove ethanol from my gas?Re: Probably Fred Probably Fred 04/07/18 08:04PM
  Re: Remove ethanol from my gas?Re: frank dadog frank dadog 04/07/18 10:05PM
  Re: Remove ethanol from my gas?Re: Probably Fred Probably Fred 04/07/18 10:48PM
  Re: Remove ethanol from my gas?Re: frank dadog frank dadog 04/07/18 11:25PM
  Re: Remove ethanol from my gas?Re: Probably Fred Probably Fred 04/09/18 03:33PM
  Re: Remove ethanol from my gas?Re: P D P D 04/09/18 03:37PM
  Re: Remove ethanol from my gas?Re: Mr Moped Mr Moped 04/07/18 10:33PM
  Re: Remove ethanol from my gas?Re: Bad Cadillac™ Bad Cadillac™ 04/09/18 07:42AM
  Re: Remove ethanol from my gas?Re: frank dadog frank dadog 04/09/18 04:21PM
  Re: Remove ethanol from my gas?Re: Probably Fred Probably Fred 04/09/18 05:53PM
  Re: Remove ethanol from my gas?Re: frank dadog frank dadog 04/09/18 06:43PM
  Re: Remove ethanol from my gas?Re: Dirty30 Dillon Dirty30 Dillon 04/26/18 09:57AM
  Re: Remove ethanol from my gas?Re: Probably Fred Probably Fred 04/26/18 10:33AM
  Re: Remove ethanol from my gas?Re: Nico V Nico V 04/27/18 07:24AM
  Re: Remove ethanol from my gas?Re: P D P D 04/27/18 09:59AM
  Re: Remove ethanol from my gas?Re: Born to be WillD Born to be WillD 04/27/18 03:20PM
  Re: Remove ethanol from my gas?Re: Probably Fred Probably Fred 04/28/18 04:13AM
  Re: Remove ethanol from my gas?Re: Bad Cadillac™ Bad Cadillac™ 05/04/18 11:20AM
  Re: Remove ethanol from my gas?Re: P D P D 05/04/18 11:55AM
  Re: Remove ethanol from my gas?Re: Don Ohio Don Ohio 05/09/18 02:25AM
  Re: Remove ethanol from my gas?Re: Dirty30 Dillon Dirty30 Dillon 05/09/18 03:58PM
  Re: Remove ethanol from my gas?Re: Don Ohio Don Ohio 05/09/18 04:03PM
  Re: Remove ethanol from my gas?Re: Dirty30 Dillon Dirty30 Dillon 05/10/18 12:37PM
  Re: Remove ethanol from my gas?Re: Stephen Keller Stephen Keller 05/09/18 08:55PM
  Re: Remove ethanol from my gas?Re: P D P D 05/09/18 09:06PM
  Re: Remove ethanol from my gas?Re: Don Ohio Don Ohio 05/10/18 12:21AM
