Re: Remove ethanol from my gas?
Stephen Keller /
> Dirty30 Dillon Wrote:
> Pay double the gas price to avoid a carb clean on a bike that typically
> has 4 moving components...
> Yeah, y'all should worry more about other aspects of life rather than
> what's in your gas.
I would MUCH rather ride than wrench. If I put on 500 miles per bike per season I'm doing well, worth every cent for the non ethanol. Carb cleaning should not be a spring ritual, putting on your new tabs and enjoying the first ride should be! :) If your petcock is bad and you don't want to fix/change it out, just run the bike and carb completely dry, seal tank vent, intake and exhaust against moisture and you are done. When I used a bike every day I just shut the petcock off and ran dry every night and never had an issue with ethanol fuel, but now when I ride more for fun, non ethanol is the way to go, it is not that much more expensive.
  Remove ethanol from my gas?Topic by: Storm Roland Storm Roland 04/04/18 11:55AM
  Re: Remove ethanol from my gas?Re: Full Tuck Full Tuck 04/04/18 12:38PM
  Re: Remove ethanol from my gas?Re: Storm Roland Storm Roland 04/04/18 01:04PM
  Re: Remove ethanol from my gas?Re: - Joe - - Joe - 04/04/18 02:07PM
  Re: Remove ethanol from my gas?Re: Charles Cole (OFMC) Charles Cole (OFMC) 04/04/18 02:00PM
  Re: Remove ethanol from my gas?Re: Full Tuck Full Tuck 04/04/18 02:21PM
  Re: Remove ethanol from my gas?Re: frank dadog frank dadog 04/05/18 02:34PM
  Re: Remove ethanol from my gas?Re: Blaine- The artist formerly known as Plumber Crack "(OFMC)" Blaine- The artist formerly known as Plumber Crack "(OFMC)" 04/06/18 12:35AM
  Re: Remove ethanol from my gas?Re: Bad Cadillac™ Bad Cadillac™ 04/09/18 10:11AM
  Re: Remove ethanol from my gas?Re: Bas Autowas Bas Autowas 04/04/18 02:29PM
  Re: Remove ethanol from my gas?Re: P D P D 04/04/18 03:28PM
  Re: Remove ethanol from my gas?Re: Full Tuck Full Tuck 04/04/18 05:31PM
  Re: Remove ethanol from my gas?Re: P D P D 04/04/18 06:41PM
  Re: Remove ethanol from my gas?Re: Dirty30 Dillon Dirty30 Dillon 04/06/18 08:50AM
  Re: Remove ethanol from my gas?Re: P D P D 04/06/18 11:14AM
  Re: Remove ethanol from my gas?Re: Stephen Keller Stephen Keller 04/06/18 04:33PM
  Re: Remove ethanol from my gas?Re: * * * * 04/04/18 07:17PM
  Re: Remove ethanol from my gas?Re: Probably Fred Probably Fred 04/04/18 08:09PM
  Re: Remove ethanol from my gas?Re: kenny s kenny s 04/26/18 03:51AM
  Re: Remove ethanol from my gas?Re: Joe Schuitema Joe Schuitema 04/04/18 10:02PM
  Re: Remove ethanol from my gas?Re: Mick Doohan Mick Doohan 04/04/18 10:09PM
  Re: Remove ethanol from my gas?Re: Derek Cox Derek Cox 04/04/18 11:01PM
  Re: Remove ethanol from my gas?Re: Thomas TPRF Thomas TPRF 04/04/18 11:50PM
  Re: Remove ethanol from my gas?Re: Stephen Keller Stephen Keller 04/05/18 01:55AM
  Re: Remove ethanol from my gas?Re: EH FCC of the QCB EH FCC of the QCB 04/05/18 04:00PM
  Re: Remove ethanol from my gas?Re: Flagrant - Flagrant - 04/05/18 04:22PM
  Re: Remove ethanol from my gas?Re: P D P D 04/05/18 07:36PM
  Re: Remove ethanol from my gas?Re: frank dadog frank dadog 04/05/18 09:44PM
  Re: Remove ethanol from my gas?Re: P D P D 04/05/18 11:38PM
  Re: Remove ethanol from my gas?Re: frank dadog frank dadog 04/06/18 09:26PM
  Re: Remove ethanol from my gas?Re: P D P D 04/06/18 09:42PM
  Re: Remove ethanol from my gas?Re: Stephen Keller Stephen Keller 04/06/18 01:01AM
  Re: Remove ethanol from my gas?Re: Steve Paul Steve Paul 04/05/18 10:07PM
  Re: Remove ethanol from my gas?Re: Stephen Keller Stephen Keller 04/06/18 10:20PM
  Re: Remove ethanol from my gas?Re: EH FCC of the QCB EH FCC of the QCB 04/06/18 10:59PM
  Re: Remove ethanol from my gas?Re: frank dadog frank dadog 04/06/18 11:39PM
  Re: Remove ethanol from my gas?Re: Mr Moped Mr Moped 04/07/18 01:11AM
  Re: Remove ethanol from my gas?Re: * * * * 04/07/18 11:59AM
  Re: Remove ethanol from my gas?Re: frank dadog frank dadog 04/07/18 04:44PM
  Re: Remove ethanol from my gas?Re: Probably Fred Probably Fred 04/07/18 08:04PM
  Re: Remove ethanol from my gas?Re: frank dadog frank dadog 04/07/18 10:05PM
  Re: Remove ethanol from my gas?Re: Probably Fred Probably Fred 04/07/18 10:48PM
  Re: Remove ethanol from my gas?Re: frank dadog frank dadog 04/07/18 11:25PM
  Re: Remove ethanol from my gas?Re: Probably Fred Probably Fred 04/09/18 03:33PM
  Re: Remove ethanol from my gas?Re: P D P D 04/09/18 03:37PM
  Re: Remove ethanol from my gas?Re: Mr Moped Mr Moped 04/07/18 10:33PM
  Re: Remove ethanol from my gas?Re: Bad Cadillac™ Bad Cadillac™ 04/09/18 07:42AM
  Re: Remove ethanol from my gas?Re: frank dadog frank dadog 04/09/18 04:21PM
  Re: Remove ethanol from my gas?Re: Probably Fred Probably Fred 04/09/18 05:53PM
  Re: Remove ethanol from my gas?Re: frank dadog frank dadog 04/09/18 06:43PM
  Re: Remove ethanol from my gas?Re: Dirty30 Dillon Dirty30 Dillon 04/26/18 09:57AM
  Re: Remove ethanol from my gas?Re: Probably Fred Probably Fred 04/26/18 10:33AM
  Re: Remove ethanol from my gas?Re: Nico V Nico V 04/27/18 07:24AM
  Re: Remove ethanol from my gas?Re: P D P D 04/27/18 09:59AM
  Re: Remove ethanol from my gas?Re: Born to be WillD Born to be WillD 04/27/18 03:20PM
  Re: Remove ethanol from my gas?Re: Probably Fred Probably Fred 04/28/18 04:13AM
  Re: Remove ethanol from my gas?Re: Bad Cadillac™ Bad Cadillac™ 05/04/18 11:20AM
  Re: Remove ethanol from my gas?Re: P D P D 05/04/18 11:55AM
  Re: Remove ethanol from my gas?Re: Don Ohio Don Ohio 05/09/18 02:25AM
  Re: Remove ethanol from my gas?Re: Dirty30 Dillon Dirty30 Dillon 05/09/18 03:58PM
  Re: Remove ethanol from my gas?Re: Don Ohio Don Ohio 05/09/18 04:03PM
  Re: Remove ethanol from my gas?Re: Dirty30 Dillon Dirty30 Dillon 05/10/18 12:37PM
  Re: Remove ethanol from my gas?Re: Stephen Keller Stephen Keller 05/09/18 08:55PM
  Re: Remove ethanol from my gas?Re: P D P D 05/09/18 09:06PM
  Re: Remove ethanol from my gas?Re: Don Ohio Don Ohio 05/10/18 12:21AM
