Re: New dual variated launch lever, brought to you by Crazy Wayne and Jbot
your meat
Bunny rescues are okay, I hope.
How about a little pic showing how Drilling 2.6 gram malossi pn# 66 8084.40 rollers out for tuning.
Stock malossi 2.6 grams rollers.
Drilled out 5/16" of an inch = 2.3 grams.
Drilled out 11/32" of an inch = 2.1 grams(edited)
Sure that's fine
I thought you were on tour? I've got a ridiculous idea that came to me recently that you should probably see. Also, figure out how to fabricate springs for me. Kthx
Nothing lasts forever.
Show me idea
I love modding springs, I've never ever had one break from modding.
Rad
Any prime rib left I could use some food.
Prime ribs all gone but there's some brisket.
and this spring my ground down to make it a little softer for shifting with the lighter weights above.
I do like the cameos European design with that angle pins Slots that make the variator respond to torque for gearing and RPM change.
That will work jbot. You can overnight it.
You don't even know who you're talking to. Haha.
GOD
That prime rib though.
Anonymous User /
scootertrash
Jibidybots swingin’ con-cock-shen
I found the pulley again. I call it serial no since that was the name printed on it. 110mm
A little kinky the belts tight as a frozen ball sack.
I was wondering how long it was going to take you to figure that one out.
Anonymous User /
scootertrash
> out.
Wayne called last night, says wrong thread fuck face that’s quad variashun ana’aint no quads allowed on MA. (brought to you by Carl’s Jr.)
Actually you called him.
Anonymous User /
scootertrash
That’s what I said.
The belts changed around and slacked up a fuzz. The 1/2 belt sits down in the GY6 115mm pretty far, I’ll have to get the 5/8. That might be enuff to pull the slack. The front TJT is 105mm
The action is to move it up or down to change speed on a single speed setup. Like this,
Dumb little moped part that I look at a lot. ? Solo
Clutch pulley or pulley clutch swinging variator in between the fixed shit.
NOT I’m not doing it like that, I’m doing it like the pic ya know. Swing it up with a foot lever
Wayne says Howthawathafukindoit!
My version doesn't change gearing at all, or variate in the center.
Just manipulates the shift.
I'm curious how this will respond and how it will be manipulated/tuned.
I will say this.
If this pulley will drop your gearing lower than normal at takeoff it might be annoying. I modded a Camino pulley to go crazy tall on the belt, and the bike wasn't great off the line because the variation had to work it's way thru that extra low gearing, actually making it less zippy. This was with standard gears. Race gears would help to make this kinda quad variation useful. Otherwise it might be kinda pointless, unless you wanna run very low clutch stall and pull stumps.
Or....you might wanna just add some spacers to the center pulley to make each side equal and immovable. Just some thoughts to consider(edited)
Anonymous User /
scootertrash
Anonymous User /
scootertrash
It’s coming along, foot lever is a little bent~
Made a vid of this thing shifting.
It gets fast really fast. Haha
is this the only performance mod allowed on hobbits on 4'20 race
you are all sick fucks...... congrats
