New dual variated launch lever, brought to you by Crazy Wayne and Jbot
JBOT Admin /
CW has been working on a crazy thing for awhile, not exactly what I'm going to do but it gave me an idea. But I'll give him all the credit cuz idgaf.
What if, what if.....
What if one were to use 2 short belts on a hobbit or Vespa, with a 1:1 dual sheave pulley bridging them together in the center.
Then that pulley can be shifted forward or backward to manually control shift. It's so stupid and simple, but it's genius.
Push double pulley forward, rear belt drops into the rear and raises in the front. Push double pulley backwards, belt raises in rear pulley and lowers in the front (downshift)
Only issue might be belt alignment but these V belts can take quite a bit of misalignment before destroying themselves.
The best thing is that there's no belt on belt bullshit like the last one I made. That was dumb. This shouldn't wear the belts too bad, and might just give me the manual control I've always wanted, and can run a crazy weak contra without dropping rpms. Then when all is said n done, I can add my variator brake to the unit, allowing it to lock it and dump it. So fun.
Going to run 1/2in belts to start, as they're easy to find in different lengths and will require less misalignment.
Part is ordered, now I just have to get it and build the mechanism.
And derbi lame-os can't do it haha cuz there's no room. Suckers.
Anyways, boom(edited)
  New dual variated launch lever, brought to you by Crazy Wayne and JbotTopic by: JBOT Admin JBOT Admin 03/19/18 04:10PM
  Re: New dual variated launch lever, brought to you by Crazy Wayne and JbotRe: - Joe - - Joe - 03/19/18 05:39PM
  Re: New dual variated launch lever, brought to you by Crazy Wayne and JbotRe: patrick stover patrick stover 03/19/18 05:55PM
  Re: New dual variated launch lever, brought to you by Crazy Wayne and JbotRe: JBOT Admin JBOT Admin 05/14/18 12:36AM
  Re: New dual variated launch lever, brought to you by Crazy Wayne and JbotRe: - Joe - - Joe - 05/14/18 09:29AM
  Re: New dual variated launch lever, brought to you by Crazy Wayne and JbotRe: JBOT Admin JBOT Admin 05/14/18 11:51AM
  Re: New dual variated launch lever, brought to you by Crazy Wayne and JbotRe: Blaine- The artist formerly known as Plumber Crack "(OFMC)" Blaine- The artist formerly known as Plumber Crack "(OFMC)" 05/14/18 05:22PM
  Re: New dual variated launch lever, brought to you by Crazy Wayne and JbotRe: JBOT Admin JBOT Admin 05/14/18 11:25PM
  Re: New dual variated launch lever, brought to you by Crazy Wayne and JbotRe: Blaine- The artist formerly known as Plumber Crack "(OFMC)" Blaine- The artist formerly known as Plumber Crack "(OFMC)" 05/15/18 11:16AM
  Re: New dual variated launch lever, brought to you by Crazy Wayne and JbotRe: JBOT Admin JBOT Admin 05/15/18 12:10PM
  Re: New dual variated launch lever, brought to you by Crazy Wayne and JbotRe: Blaine- The artist formerly known as Plumber Crack "(OFMC)" Blaine- The artist formerly known as Plumber Crack "(OFMC)" 05/15/18 12:29PM
  Re: New dual variated launch lever, brought to you by Crazy Wayne and JbotRe: Blaine- The artist formerly known as Plumber Crack "(OFMC)" Blaine- The artist formerly known as Plumber Crack "(OFMC)" 05/15/18 02:43PM
  Re: New dual variated launch lever, brought to you by Crazy Wayne and JbotRe: JBOT Admin JBOT Admin 05/15/18 03:09PM
  Re: New dual variated launch lever, brought to you by Crazy Wayne and JbotRe: P D P D 05/15/18 03:57PM
  Re: New dual variated launch lever, brought to you by Crazy Wayne and JbotRe: JBOT Admin JBOT Admin 05/15/18 06:08PM
  Re: New dual variated launch lever, brought to you by Crazy Wayne and JbotRe: first name last name first name last name 05/15/18 11:17PM
  Re: New dual variated launch lever, brought to you by Crazy Wayne and JbotRe: JBOT Admin JBOT Admin 05/17/18 11:27PM
  Re: New dual variated launch lever, brought to you by Crazy Wayne and JbotRe: JBOT Admin JBOT Admin 05/19/18 03:49AM
  Re: New dual variated launch lever, brought to you by Crazy Wayne and JbotRe: JBOT Admin JBOT Admin 11/08/18 02:32AM
  Re: New dual variated launch lever, brought to you by Crazy Wayne and JbotRe: Travis Noll Travis Noll 03/19/18 06:17PM
  Re: New dual variated launch lever, brought to you by Crazy Wayne and JbotRe: JBOT Admin JBOT Admin 03/20/18 09:35PM
  Re: New dual variated launch lever, brought to you by Crazy Wayne and JbotRe: Ada Dictome Ada Dictome 03/19/18 06:59PM
  Re: New dual variated launch lever, brought to you by Crazy Wayne and JbotRe: JBOT Admin JBOT Admin 03/19/18 07:39PM
  Re: New dual variated launch lever, brought to you by Crazy Wayne and JbotRe: JBOT Admin JBOT Admin 03/19/18 09:08PM
  Re: New dual variated launch lever, brought to you by Crazy Wayne and JbotRe: Ada Dictome Ada Dictome 03/19/18 07:01PM
  Re: New dual variated launch lever, brought to you by Crazy Wayne and JbotRe: Derek A Derek A 03/19/18 07:20PM
  Re: New dual variated launch lever, brought to you by Crazy Wayne and JbotRe: JBOT Admin JBOT Admin 03/19/18 07:27PM
  Re: New dual variated launch lever, brought to you by Crazy Wayne and JbotRe: JBOT Admin JBOT Admin 03/19/18 07:32PM
  Re: New dual variated launch lever, brought to you by Crazy Wayne and JbotRe: Derek Cox Derek Cox 03/19/18 09:44PM
  Re: New dual variated launch lever, brought to you by Crazy Wayne and JbotRe: JBOT Admin JBOT Admin 03/19/18 10:36PM
  Re: New dual variated launch lever, brought to you by Crazy Wayne and JbotRe: Ada Dictome Ada Dictome 03/19/18 08:00PM
  Re: New dual variated launch lever, brought to you by Crazy Wayne and JbotRe: - Joe - - Joe - 03/19/18 08:16PM
  Re: New dual variated launch lever, brought to you by Crazy Wayne and JbotRe: DrGeorgeTompson (Alan) DrGeorgeTompson (Alan) 03/20/18 03:29PM
  Re: New dual variated launch lever, brought to you by Crazy Wayne and JbotRe: JBOT Admin JBOT Admin 03/20/18 08:13PM
  Re: New dual variated launch lever, brought to you by Crazy Wayne and JbotRe: Graham Motzing Graham Motzing 03/21/18 04:42PM
  Re: New dual variated launch lever, brought to you by Crazy Wayne and JbotRe: JBOT Admin JBOT Admin 03/23/18 11:32PM
  Re: New dual variated launch lever, brought to you by Crazy Wayne and JbotRe: JBOT Admin JBOT Admin 03/23/18 11:41PM
  Re: New dual variated launch lever, brought to you by Crazy Wayne and JbotRe: JBOT Admin JBOT Admin 03/24/18 06:48PM
  Re: New dual variated launch lever, brought to you by Crazy Wayne and JbotRe: Derek Cox Derek Cox 03/24/18 07:09PM
  Re: New dual variated launch lever, brought to you by Crazy Wayne and JbotRe: JBOT Admin JBOT Admin 03/24/18 07:55PM
  Re: New dual variated launch lever, brought to you by Crazy Wayne and JbotRe: Derek Cox Derek Cox 03/24/18 08:53PM
  Re: New dual variated launch lever, brought to you by Crazy Wayne and JbotRe: JBOT Admin JBOT Admin 03/24/18 09:24PM
  Re: New dual variated launch lever, brought to you by Crazy Wayne and JbotRe: JBOT Admin JBOT Admin 03/24/18 07:53PM
  Re: New dual variated launch lever, brought to you by Crazy Wayne and JbotRe: Thomas TPRF Thomas TPRF 03/20/18 06:15PM
  Re: New dual variated launch lever, brought to you by Crazy Wayne and JbotRe: P D P D 03/20/18 06:55PM
  Re: New dual variated launch lever, brought to you by Crazy Wayne and JbotRe: Thomas TPRF Thomas TPRF 03/20/18 09:13PM
  Re: New dual variated launch lever, brought to you by Crazy Wayne and JbotRe: JBOT Admin JBOT Admin 03/20/18 09:27PM
  Re: New dual variated launch lever, brought to you by Crazy Wayne and JbotRe: P D P D 03/20/18 11:30PM
  Re: New dual variated launch lever, brought to you by Crazy Wayne and JbotRe: Graham Motzing Graham Motzing 03/20/18 07:56PM
  Re: New dual variated launch lever, brought to you by Crazy Wayne and JbotRe: Thomas TPRF Thomas TPRF 03/20/18 10:18PM
  Re: New dual variated launch lever, brought to you by Crazy Wayne and JbotRe: Thomas TPRF Thomas TPRF 03/21/18 11:27AM
  Re: New dual variated launch lever, brought to you by Crazy Wayne and JbotRe: P D P D 03/21/18 11:58AM
  Re: New dual variated launch lever, brought to you by Crazy Wayne and JbotRe: JBOT Admin JBOT Admin 03/21/18 04:35PM
  Re: New dual variated launch lever, brought to you by Crazy Wayne and JbotRe: Buttcheeks BUZZARD Buttcheeks BUZZARD 03/24/18 08:09PM
  Re: New dual variated launch lever, brought to you by Crazy Wayne and JbotRe: JBOT Admin JBOT Admin 03/24/18 09:26PM
  Re: New dual variated launch lever, brought to you by Crazy Wayne and JbotRe: JBOT Admin JBOT Admin 03/24/18 10:06PM
  Re: New dual variated launch lever, brought to you by Crazy Wayne and JbotRe: Ryan N. Ryan N. 03/25/18 11:15AM
  Re: New dual variated launch lever, brought to you by Crazy Wayne and JbotRe: EH FCC of the QCB EH FCC of the QCB 03/25/18 11:26AM
  Re: New dual variated launch lever, brought to you by Crazy Wayne and JbotRe: JBOT Admin JBOT Admin 03/25/18 11:28AM
  Re: New dual variated launch lever, brought to you by Crazy Wayne and JbotRe: David Cox David Cox 03/25/18 11:27AM
  Re: New dual variated launch lever, brought to you by Crazy Wayne and JbotRe: JBOT Admin JBOT Admin 03/25/18 11:30AM
  Re: New dual variated launch lever, brought to you by Crazy Wayne and JbotRe: JBOT Admin JBOT Admin 03/25/18 11:34AM
  Re: New dual variated launch lever, brought to you by Crazy Wayne and JbotRe: JBOT Admin JBOT Admin 03/25/18 12:25PM
  Re: New dual variated launch lever, brought to you by Crazy Wayne and JbotRe: JBOT Admin JBOT Admin 03/26/18 12:19AM
  Re: New dual variated launch lever, brought to you by Crazy Wayne and JbotRe: Blaine- The artist formerly known as Plumber Crack "(OFMC)" Blaine- The artist formerly known as Plumber Crack "(OFMC)" 03/26/18 08:33AM
  Re: New dual variated launch lever, brought to you by Crazy Wayne and JbotRe: P D P D 03/26/18 11:36AM
  Re: New dual variated launch lever, brought to you by Crazy Wayne and JbotRe: JBOT Admin JBOT Admin 03/26/18 11:43AM
  Re: New dual variated launch lever, brought to you by Crazy Wayne and JbotRe: DrGeorgeTompson (Alan) DrGeorgeTompson (Alan) 03/26/18 12:17PM
  Re: New dual variated launch lever, brought to you by Crazy Wayne and JbotRe: Thomas TPRF Thomas TPRF 03/26/18 03:57PM
  Re: New dual variated launch lever, brought to you by Crazy Wayne and JbotRe: JBOT Admin JBOT Admin 03/26/18 05:02PM
  Re: New dual variated launch lever, brought to you by Crazy Wayne and JbotRe: JBOT Admin JBOT Admin 03/26/18 09:22PM
  Re: New dual variated launch lever, brought to you by Crazy Wayne and JbotRe: Thomas TPRF Thomas TPRF 03/26/18 09:29PM
  Re: New dual variated launch lever, brought to you by Crazy Wayne and JbotRe: JBOT Admin JBOT Admin 03/26/18 09:42PM
  Re: New dual variated launch lever, brought to you by Crazy Wayne and JbotRe: JBOT Admin JBOT Admin 03/26/18 10:11PM
  Re: New dual variated launch lever, brought to you by Crazy Wayne and JbotRe: David Cox David Cox 03/26/18 11:03PM
  Re: New dual variated launch lever, brought to you by Crazy Wayne and JbotRe: Derek Cox Derek Cox 03/26/18 11:03PM
  Re: New dual variated launch lever, brought to you by Crazy Wayne and JbotRe: DrGeorgeTompson (Alan) DrGeorgeTompson (Alan) 03/26/18 11:16PM
  Re: New dual variated launch lever, brought to you by Crazy Wayne and JbotRe: Get Blatzed Get Blatzed 03/26/18 11:50PM
  Re: New dual variated launch lever, brought to you by Crazy Wayne and JbotRe: Born to be WillD Born to be WillD 03/27/18 10:06AM
  Re: New dual variated launch lever, brought to you by Crazy Wayne and JbotRe: JBOT Admin JBOT Admin 03/27/18 10:44AM
  Re: New dual variated launch lever, brought to you by Crazy Wayne and JbotRe: Derek Cox Derek Cox 03/27/18 12:19PM
  Re: New dual variated launch lever, brought to you by Crazy Wayne and JbotRe: Born to be WillD Born to be WillD 03/28/18 03:30PM
  Re: New dual variated launch lever, brought to you by Crazy Wayne and JbotRe: JBOT Admin JBOT Admin 03/28/18 09:47PM
  Re: New dual variated launch lever, brought to you by Crazy Wayne and JbotRe: Born to be WillD Born to be WillD 03/29/18 10:32AM
  Re: New dual variated launch lever, brought to you by Crazy Wayne and JbotRe: Dirty30 Dillon Dirty30 Dillon 03/27/18 12:58PM
  Re: New dual variated launch lever, brought to you by Crazy Wayne and JbotRe: JBOT Admin JBOT Admin 03/27/18 02:17PM
  Re: New dual variated launch lever, brought to you by Crazy Wayne and JbotRe: Graham Motzing Graham Motzing 03/27/18 01:11PM
  Re: New dual variated launch lever, brought to you by Crazy Wayne and JbotRe: Captain Janeway Captain Janeway 03/27/18 03:12PM
  Re: New dual variated launch lever, brought to you by Crazy Wayne and JbotRe: JBOT Admin JBOT Admin 03/27/18 04:38PM
  Re: New dual variated launch lever, brought to you by Crazy Wayne and JbotRe: Dirty30 Dibbs Dirty30 Dibbs 03/27/18 06:20PM
  Re: New dual variated launch lever, brought to you by Crazy Wayne and JbotRe: JBOT Admin JBOT Admin 03/27/18 07:12PM
  Re: New dual variated launch lever, brought to you by Crazy Wayne and JbotRe: Thomas TPRF Thomas TPRF 03/28/18 11:22AM
  Re: New dual variated launch lever, brought to you by Crazy Wayne and JbotRe: Ashlee P't Ashlee P't 03/28/18 12:39PM
  Re: New dual variated launch lever, brought to you by Crazy Wayne and JbotRe: JBOT Admin JBOT Admin 03/28/18 12:54PM
  Re: New dual variated launch lever, brought to you by Crazy Wayne and JbotRe: JBOT Admin JBOT Admin 03/28/18 01:03PM
  Re: New dual variated launch lever, brought to you by Crazy Wayne and JbotRe: Captain Janeway Captain Janeway 03/28/18 03:08PM
  Re: New dual variated launch lever, brought to you by Crazy Wayne and JbotRe: Graham Motzing Graham Motzing 03/29/18 12:28PM
  Re: New dual variated launch lever, brought to you by Crazy Wayne and JbotRe: JBOT Admin JBOT Admin 03/29/18 12:35PM
  Re: New dual variated launch lever, brought to you by Crazy Wayne and JbotRe: Graham Motzing Graham Motzing 03/29/18 12:43PM
  Re: New dual variated launch lever, brought to you by Crazy Wayne and JbotRe: JBOT Admin JBOT Admin 03/29/18 12:48PM
  Re: New dual variated launch lever, brought to you by Crazy Wayne and JbotRe: Thomas TPRF Thomas TPRF 03/29/18 11:02PM
  Re: New dual variated launch lever, brought to you by Crazy Wayne and JbotRe: Bas Autowas Bas Autowas 03/29/18 12:45PM
  Re: New dual variated launch lever, brought to you by Crazy Wayne and JbotRe: Jonathan Feldman Jonathan Feldman 03/31/18 03:25PM
  Re: New dual variated launch lever, brought to you by Crazy Wayne and JbotRe: JBOT Admin JBOT Admin 03/31/18 03:31PM
  Re: New dual variated launch lever, brought to you by Crazy Wayne and JbotRe: Flagrant - Flagrant - 03/31/18 05:32PM
  Re: New dual variated launch lever, brought to you by Crazy Wayne and JbotRe: JBOT Admin JBOT Admin 03/31/18 08:46PM
  Re: New dual variated launch lever, brought to you by Crazy Wayne and JbotRe: JBOT Admin JBOT Admin 03/31/18 08:48PM
  Re: New dual variated launch lever, brought to you by Crazy Wayne and JbotRe: P D P D 04/01/18 02:38PM
  Re: New dual variated launch lever, brought to you by Crazy Wayne and JbotRe: JBOT Admin JBOT Admin 04/01/18 03:46PM
  Re: New dual variated launch lever, brought to you by Crazy Wayne and JbotRe: P D P D 04/01/18 04:27PM
  Re: New dual variated launch lever, brought to you by Crazy Wayne and JbotRe: jayson sumpter jayson sumpter 04/04/18 09:36AM
  Re: New dual variated launch lever, brought to you by Crazy Wayne and JbotRe: JBOT Admin JBOT Admin 04/04/18 10:30AM
  Re: New dual variated launch lever, brought to you by Crazy Wayne and JbotRe: jayson sumpter jayson sumpter 04/04/18 12:43PM
  Re: New dual variated launch lever, brought to you by Crazy Wayne and JbotRe: JBOT Admin JBOT Admin 04/04/18 12:53PM
  Re: New dual variated launch lever, brought to you by Crazy Wayne and JbotRe: Charles Cole (OFMC) Charles Cole (OFMC) 04/04/18 02:02PM
  Re: New dual variated launch lever, brought to you by Crazy Wayne and JbotRe: Honest Mike Honest Mike 04/07/18 05:54AM
  Re: New dual variated launch lever, brought to you by Crazy Wayne and JbotRe: JBOT Admin JBOT Admin 04/09/18 07:37PM
  Re: New dual variated launch lever, brought to you by Crazy Wayne and JbotRe: JBOT Admin JBOT Admin 04/13/18 05:06PM
  Re: New dual variated launch lever, brought to you by Crazy Wayne and JbotRe: Derek Cox Derek Cox 04/13/18 06:03PM
  Re: New dual variated launch lever, brought to you by Crazy Wayne and JbotRe: P D P D 04/13/18 09:19PM
  Re: New dual variated launch lever, brought to you by Crazy Wayne and JbotRe: Charles Cole (OFMC) Charles Cole (OFMC) 05/03/18 10:14PM
  Re: New dual variated launch lever, brought to you by Crazy Wayne and JbotRe: JBOT Admin JBOT Admin 05/03/18 11:28PM
  Re: New dual variated launch lever, brought to you by Crazy Wayne and JbotRe: Eric Bloomquist Eric Bloomquist 05/04/18 01:22PM
  Re: New dual variated launch lever, brought to you by Crazy Wayne and JbotRe: JBOT Admin JBOT Admin 05/04/18 04:13PM
  Re: New dual variated launch lever, brought to you by Crazy Wayne and JbotRe: JBOT Admin JBOT Admin 05/07/18 09:16PM
  Re: New dual variated launch lever, brought to you by Crazy Wayne and JbotRe: JBOT Admin JBOT Admin 05/07/18 09:18PM
  Re: New dual variated launch lever, brought to you by Crazy Wayne and JbotRe: JBOT Admin JBOT Admin 05/08/18 07:36PM
  Re: New dual variated launch lever, brought to you by Crazy Wayne and JbotRe: JBOT Admin JBOT Admin 05/09/18 10:01PM
  Re: New dual variated launch lever, brought to you by Crazy Wayne and JbotRe: Charlie BUZZARD Charlie BUZZARD 05/10/18 05:51PM
  Re: New dual variated launch lever, brought to you by Crazy Wayne and JbotRe: JBOT Admin JBOT Admin 05/10/18 10:13PM
  Re: New dual variated launch lever, brought to you by Crazy Wayne and JbotRe: Charlie BUZZARD Charlie BUZZARD 05/12/18 12:27AM
  Re: New dual variated launch lever, brought to you by Crazy Wayne and JbotRe: JBOT Admin JBOT Admin 05/12/18 01:22AM
  Re: New dual variated launch lever, brought to you by Crazy Wayne and JbotRe: first name last name first name last name 05/12/18 01:26PM
  Re: New dual variated launch lever, brought to you by Crazy Wayne and JbotRe: JBOT Admin JBOT Admin 05/12/18 03:51PM
  Re: New dual variated launch lever, brought to you by Crazy Wayne and JbotRe: JBOT Admin JBOT Admin 05/12/18 03:55PM
  Re: New dual variated launch lever, brought to you by Crazy Wayne and JbotRe: JBOT Admin JBOT Admin 05/12/18 06:27PM
  Re: New dual variated launch lever, brought to you by Crazy Wayne and JbotRe: Chris . Chris . 11/08/18 04:16PM
  Re: New dual variated launch lever, brought to you by Crazy Wayne and JbotRe: Ada Dictome Ada Dictome 11/08/18 06:52PM
  Re: New dual variated launch lever, brought to you by Crazy Wayne and JbotRe: JBOT Admin JBOT Admin 11/08/18 08:06PM
  Re: New dual variated launch lever, brought to you by Crazy Wayne and JbotRe: Ada Dictome Ada Dictome 11/08/18 08:25PM
  Re: New dual variated launch lever, brought to you by Crazy Wayne and JbotRe: JBOT Admin JBOT Admin 11/08/18 10:06PM
  Re: New dual variated launch lever, brought to you by Crazy Wayne and JbotRe: Graham Motzing Graham Motzing 11/09/18 10:29AM
  Re: New dual variated launch lever, brought to you by Crazy Wayne and JbotRe: JBOT Admin JBOT Admin 11/09/18 12:04PM
  Re: New dual variated launch lever, brought to you by Crazy Wayne and JbotRe: Crazy Wayne Crazy Wayne 11/09/18 04:32PM
  Re: New dual variated launch lever, brought to you by Crazy Wayne and JbotRe: JBOT Admin JBOT Admin 11/09/18 05:19PM
  Re: New dual variated launch lever, brought to you by Crazy Wayne and JbotRe: Crazy Wayne Crazy Wayne 11/09/18 09:04PM
  Re: New dual variated launch lever, brought to you by Crazy Wayne and JbotRe: Crazy Wayne Crazy Wayne 11/09/18 11:29PM
  Re: New dual variated launch lever, brought to you by Crazy Wayne and JbotRe: JBOT Admin JBOT Admin 11/09/18 11:42PM
  Re: New dual variated launch lever, brought to you by Crazy Wayne and JbotRe: JBOT Admin JBOT Admin 11/10/18 12:33PM
  Re: New dual variated launch lever, brought to you by Crazy Wayne and JbotRe: Crazy Wayne Crazy Wayne 11/10/18 04:26PM
  Re: New dual variated launch lever, brought to you by Crazy Wayne and JbotRe: JBOT Admin JBOT Admin 11/10/18 06:26PM
  Re: New dual variated launch lever, brought to you by Crazy Wayne and JbotRe: Ada Dictome Ada Dictome 11/12/18 11:52PM
  Re: New dual variated launch lever, brought to you by Crazy Wayne and JbotRe: Crazy Wayne Crazy Wayne 11/13/18 11:23AM
  Re: New dual variated launch lever, brought to you by Crazy Wayne and JbotRe: Ada Dictome Ada Dictome 11/13/18 11:47AM
  Re: New dual variated launch lever, brought to you by Crazy Wayne and JbotRe: Crazy Wayne Crazy Wayne 11/13/18 11:59AM
  Re: New dual variated launch lever, brought to you by Crazy Wayne and JbotRe: Ada Dictome Ada Dictome 11/13/18 12:24PM
  Re: New dual variated launch lever, brought to you by Crazy Wayne and JbotRe: JBOT Admin JBOT Admin 11/13/18 12:33PM
  Re: New dual variated launch lever, brought to you by Crazy Wayne and JbotRe: JBOT Admin JBOT Admin 11/13/18 01:27PM
  Re: New dual variated launch lever, brought to you by Crazy Wayne and JbotRe: Ada Dictome Ada Dictome 11/13/18 06:47PM
  Re: New dual variated launch lever, brought to you by Crazy Wayne and JbotRe: Ada Dictome Ada Dictome 11/13/18 10:30PM
  Re: New dual variated launch lever, brought to you by Crazy Wayne and JbotRe: Brandon Love Brandon Love 11/09/18 11:30AM
  Re: New dual variated launch lever, brought to you by Crazy Wayne and JbotRe: Brandon Love Brandon Love 11/09/18 11:32AM
  Re: New dual variated launch lever, brought to you by Crazy Wayne and JbotRe: Wild Card Wild Card 11/11/18 12:46AM
  Re: New dual variated launch lever, brought to you by Crazy Wayne and JbotRe: JBOT Admin JBOT Admin 11/11/18 12:58AM
  Re: New dual variated launch lever, brought to you by Crazy Wayne and JbotRe: Wild Card Wild Card 11/11/18 10:57AM
  Re: New dual variated launch lever, brought to you by Crazy Wayne and JbotRe: Mo Peds Mo Peds 11/11/18 07:25PM
  Re: New dual variated launch lever, brought to you by Crazy Wayne and JbotRe: Crazy Wayne Crazy Wayne 11/11/18 08:04PM
  Re: New dual variated launch lever, brought to you by Crazy Wayne and JbotRe: Mo Peds Mo Peds 11/11/18 08:41PM
  Re: New dual variated launch lever, brought to you by Crazy Wayne and JbotRe: JBOT Admin JBOT Admin 11/11/18 08:46PM
  Re: New dual variated launch lever, brought to you by Crazy Wayne and JbotRe: Mo Peds Mo Peds 11/11/18 09:01PM
  Re: New dual variated launch lever, brought to you by Crazy Wayne and JbotRe: jayson sumpter jayson sumpter 11/12/18 02:59PM
  Re: New dual variated launch lever, brought to you by Crazy Wayne and JbotRe: JBOT Admin JBOT Admin 03/01/19 10:49PM
  Re: New dual variated launch lever, brought to you by Crazy Wayne and JbotRe: CtpEDsHED . CtpEDsHED . 03/02/19 02:37PM
