Re: DOS Cycles Derbi/Honda variator - More range for 16x13 weights
Totally normal JBOT /
You can turn down the clutch bell pulley at least 2mm to get the belt all the way down.
Did my hobbit and it ruled.
Then if the spacing is too great just add a garbage plastic washer between the vari back hub and the ramp plate with the washer floating on the center, just using it to cinch up the belt
