Re: NU50 Custom 26mm Intake Build
Derek Cox /
> frank dadog Wrote:
> > David Cox Wrote:
> > Well, another day of testing, and we need to say, even tho dereks bike
> > rips hard with the vm26 combination, driveabilty just isnt what it was
> > with the smaller carbs overall.
> Might be helpful to explain specifically what you mean. I would expect
> some pep until you get the needle up, then a flat spot until you're on
> the main. But that's just a guess.
Actually, it was a flat ripper from take off to top speed, as long as u r final shift was at maximum rpm, it would pull like crazy, any lower and it would bog when notched variator went fully out. Off the line was excellent, lean forward or it might flip. But after it broke in half i am just not comfortable at those speeds on this bike anymore. So driving midrange and cruising it was peaky and not as smooth as the 20mm. Yes, jetting was spot on. All in all i drive in town and going block to block that fast wasnt as much fun as i thought. The variator weights had to be stupid light, revved to the moon all the time. For racing its great, for in town driving it sucked. The vm22 was real good too. But i will prolly run the 20mm carb and new kit (just purchased last nite from treats) not case matched. Once we did the case matching rpm range went up. David put a new new H20 kit on bone stock yesterday with vm20 and torque was much better, it didnt lose speed on final shift if it wasnt revved to the moon. Just want a good in town 55mph driver, if i need extreme power thats what the bottle is for. We wasted alot if money but learned alot too, and we werent bored. Next chapter, Serious Baddassery 2!, details later
  NU50 Custom 26mm Intake BuildTopic by: David Cox David Cox 03/08/18 07:10PM
  Re: NU50 Custom 26mm Intake BuildRe: Charles Cole (OFMC) Charles Cole (OFMC) 03/08/18 07:17PM
  Re: NU50 Custom 26mm Intake BuildRe: alex ganz alex ganz 03/08/18 11:56PM
  Re: NU50 Custom 26mm Intake BuildRe: David Cox David Cox 03/09/18 06:12AM
  Re: NU50 Custom 26mm Intake BuildRe: Captain Janeway Captain Janeway 03/09/18 01:16PM
  Re: NU50 Custom 26mm Intake BuildRe: David Cox David Cox 03/09/18 01:55PM
  Re: NU50 Custom 26mm Intake BuildRe: David Cox David Cox 03/09/18 02:39PM
  Re: NU50 Custom 26mm Intake BuildRe: David Cox David Cox 03/09/18 04:31PM
  Re: NU50 Custom 26mm Intake BuildRe: Born to be WillD Born to be WillD 03/09/18 04:52PM
  Re: NU50 Custom 26mm Intake BuildRe: David Cox David Cox 03/09/18 05:39PM
  Re: NU50 Custom 26mm Intake BuildRe: Jack Rutherford Jack Rutherford 03/09/18 07:58PM
  Re: NU50 Custom 26mm Intake BuildRe: David Cox David Cox 03/09/18 08:37PM
  Re: NU50 Custom 26mm Intake BuildRe: Joe Schuitema Joe Schuitema 03/09/18 07:01AM
  Re: NU50 Custom 26mm Intake BuildRe: David Cox David Cox 03/09/18 09:54AM
  Re: NU50 Custom 26mm Intake BuildRe: Born to be WillD Born to be WillD 03/09/18 10:00AM
  Re: NU50 Custom 26mm Intake BuildRe: P D P D 03/09/18 11:38AM
  Re: NU50 Custom 26mm Intake BuildRe: David Cox David Cox 03/09/18 11:43AM
  Re: NU50 Custom 26mm Intake BuildRe: Born to be WillD Born to be WillD 03/09/18 04:47PM
  Re: NU50 Custom 26mm Intake BuildRe: David Cox David Cox 03/09/18 05:28PM
  Re: NU50 Custom 26mm Intake BuildRe: Derek Cox Derek Cox 03/09/18 05:42PM
  Re: NU50 Custom 26mm Intake BuildRe: Born to be WillD Born to be WillD 03/09/18 09:06AM
  Re: NU50 Custom 26mm Intake BuildRe: frank dadog frank dadog 03/09/18 12:17PM
  Re: NU50 Custom 26mm Intake BuildRe: Born to be WillD Born to be WillD 03/09/18 09:07AM
  Re: NU50 Custom 26mm Intake BuildRe: Jack Rutherford Jack Rutherford 03/09/18 01:17PM
  Re: NU50 Custom 26mm Intake BuildRe: - Summerai - Drew - Summerai - Drew 03/10/18 02:45AM
  Re: NU50 Custom 26mm Intake BuildRe: David Cox David Cox 03/10/18 05:56AM
  Re: NU50 Custom 26mm Intake BuildRe: David Cox David Cox 03/10/18 07:13PM
  Re: NU50 Custom 26mm Intake BuildRe: frank dadog frank dadog 03/11/18 06:21PM
  Re: NU50 Custom 26mm Intake BuildRe: Derek Cox Derek Cox 03/11/18 07:04PM
  Re: NU50 Custom 26mm Intake BuildRe: David Cox David Cox 03/11/18 07:13PM
  Re: NU50 Custom 26mm Intake BuildRe: Born to be WillD Born to be WillD 03/12/18 05:18PM
  Re: NU50 Custom 26mm Intake BuildRe: Jack Rutherford Jack Rutherford 03/11/18 10:04AM
  Re: NU50 Custom 26mm Intake BuildRe: Graham Motzing Graham Motzing 03/12/18 09:51AM
  Re: NU50 Custom 26mm Intake BuildRe: Derek Cox Derek Cox 03/21/18 04:39PM
  Re: NU50 Custom 26mm Intake BuildRe: Derek Cox Derek Cox 03/23/18 07:07PM
  Re: NU50 Custom 26mm Intake BuildRe: Ryan . Ryan . 03/24/18 10:45AM
  Re: NU50 Custom 26mm Intake BuildRe: David Cox David Cox 03/24/18 02:42PM
  Re: NU50 Custom 26mm Intake BuildRe: Derek Cox Derek Cox 03/30/18 06:10PM
