Re: Trail tech temp death and rebirth
Alan Jackson /
i was given a dead tto without sensor.
i cut it open using the same approach to cutting away your skin to find a deeply embedded splinter.. ie very slowly. and carefully. i found the battery and terminals and managed to prise off the terminal from the back of the battery. the terminals seemed to be partly covered in a non conductive clear lacquer which at first i didnt realise and wondered why the display wouldnt light up after fitting a new battery.
i made a new back or cover out of clear perspex and used the 4 existing dummy screws to secure it.
then i needed a sensor. by trial and error and put on the right path by a few posts on this thread i tried NTC thermistors and found that as i went up in resistance the temperature dropped down from reading way too high to just right at 100k. for those who have the existing sensor this isnt necessary.
i then had to attach it to a plug washer and used a copper washer terminal with a crimp attached usually for wires. i trimmed this a bit and attached the thermistor with a blob of jb weld it is now ready to go under the spark plug but needs longer wires to reach the bars.
i am waiting for some fine cable to arrive.
  Trail tech temp death and rebirthTopic by: Totally normal JBOT Totally normal JBOT 02/27/18 09:58PM
  Re: Trail tech temp death and rebirthRe: Totally normal JBOT Totally normal JBOT 02/27/18 10:07PM
  Re: Trail tech temp death and rebirthRe: Tyler Dead Possums Tyler Dead Possums 03/01/18 12:33PM
  Re: Trail tech temp death and rebirthRe: Thomas TPRF Thomas TPRF 03/01/18 04:02PM
  Re: Trail tech temp death and rebirthRe: Totally normal JBOT Totally normal JBOT 03/01/18 09:47PM
  Re: Trail tech temp death and rebirthRe: cheetahchrome . cheetahchrome . 03/02/18 12:03AM
  Re: Trail tech temp death and rebirthRe: Born to be WillD Born to be WillD 02/28/18 10:23AM
  Re: Trail tech temp death and rebirthRe: Totally normal JBOT Totally normal JBOT 02/28/18 10:42AM
  Re: Trail tech temp death and rebirthRe: Totally normal JBOT Totally normal JBOT 02/28/18 10:50AM
  Re: Trail tech temp death and rebirthRe: Totally normal JBOT Totally normal JBOT 02/28/18 02:58PM
  Re: Trail tech temp death and rebirthRe: MPB Andyrew MPB Andyrew 02/28/18 03:22PM
  Re: Trail tech temp death and rebirthRe: todd amundson todd amundson 04/16/18 02:29PM
  Re: Trail tech temp death and rebirthRe: Totally normal JBOT Totally normal JBOT 04/16/18 02:34PM
  Re: Trail tech temp death and rebirthRe: Neil Verchot Neil Verchot 02/28/18 10:26AM
  Re: Trail tech temp death and rebirthRe: MPB Andyrew MPB Andyrew 02/28/18 03:23PM
  Re: Trail tech temp death and rebirthRe: Tyler Dead Possums Tyler Dead Possums 03/01/18 01:09PM
  Re: Trail tech temp death and rebirthRe: Totally normal JBOT Totally normal JBOT 03/01/18 01:13PM
  Re: Trail tech temp death and rebirthRe: Tyler Dead Possums Tyler Dead Possums 03/01/18 01:51PM
  Re: Trail tech temp death and rebirthRe: Totally normal JBOT Totally normal JBOT 03/01/18 02:39PM
  Re: Trail tech temp death and rebirthRe: Tyler Dead Possums Tyler Dead Possums 03/01/18 03:02PM
  Re: Trail tech temp death and rebirthRe: * * * * 03/01/18 09:33PM
  Re: Trail tech temp death and rebirthRe: Tyler Dead Possums Tyler Dead Possums 03/02/18 09:10AM
  Re: Trail tech temp death and rebirthRe: * * * * 03/02/18 03:33PM
  Re: Trail tech temp death and rebirthRe: P D P D 03/02/18 06:06PM
  Re: Trail tech temp death and rebirthRe: Totally normal JBOT Totally normal JBOT 03/02/18 08:50PM
  Re: Trail tech temp death and rebirthRe: * * * * 03/03/18 12:30AM
  Re: Trail tech temp death and rebirthRe: Totally normal JBOT Totally normal JBOT 03/03/18 12:34AM
  Re: Trail tech temp death and rebirthRe: Totally normal JBOT Totally normal JBOT 03/03/18 12:40AM
  Re: Trail tech temp death and rebirthRe: * * * * 03/03/18 02:12PM
  Re: Trail tech temp death and rebirthRe: Totally normal JBOT Totally normal JBOT 03/03/18 02:44PM
  Re: Trail tech temp death and rebirthRe: * * * * 03/03/18 07:30PM
  Re: Trail tech temp death and rebirthRe: Totally normal JBOT Totally normal JBOT 03/03/18 10:59PM
  Re: Trail tech temp death and rebirthRe: Thomas TPRF Thomas TPRF 03/03/18 03:04PM
  Re: Trail tech temp death and rebirthRe: frank dadog frank dadog 03/03/18 06:05PM
  Re: Trail tech temp death and rebirthRe: Thomas TPRF Thomas TPRF 03/03/18 09:06PM
  Re: Trail tech temp death and rebirthRe: Born to be WillD Born to be WillD 03/06/18 09:56AM
  Re: Trail tech temp death and rebirthRe: Totally normal JBOT Totally normal JBOT 03/06/18 12:02PM
  Re: Trail tech temp death and rebirthRe: Born to be WillD Born to be WillD 03/06/18 12:38PM
  Re: Trail tech temp death and rebirthRe: EH FCC of the QCB EH FCC of the QCB 04/08/18 10:48AM
  Re: Trail tech temp death and rebirthRe: Born to be WillD Born to be WillD 03/06/18 10:00AM
  Re: Trail tech temp death and rebirthRe: Lazy Pedaler Lazy Pedaler 04/08/18 10:34AM
  Re: Trail tech temp death and rebirthRe: Nick Sullivan Nick Sullivan 12/07/20 09:34PM
  Re: Trail tech temp death and rebirthRe: Nick Sullivan Nick Sullivan 12/07/20 09:37PM
  Re: Trail tech temp death and rebirthRe: todd amundson todd amundson 04/16/18 11:58PM
  Re: Trail tech temp death and rebirthRe: Max LGN Max LGN 04/17/18 06:29AM
  Re: Trail tech temp death and rebirthRe: Born to be WillD Born to be WillD 04/17/18 09:48AM
  Re: Trail tech temp death and rebirthRe: Max LGN Max LGN 04/17/18 12:32PM
  Re: Trail tech temp death and rebirthRe: Totally normal JBOT Totally normal JBOT 05/18/18 11:54PM
  Re: Trail tech temp death and rebirthRe: Totally normal JBOT Totally normal JBOT 03/06/21 05:48PM
  Re: Trail tech temp death and rebirthRe: Totally normal JBOT Totally normal JBOT 03/06/21 06:05PM
  Re: Trail tech temp death and rebirthRe: EH FCC of the QCB EH FCC of the QCB 03/06/21 06:32PM
  Re: Trail tech temp death and rebirthRe: weldwizard Jake weldwizard Jake 12/06/20 08:10PM
  Re: Trail tech temp death and rebirthRe: Totally normal JBOT Totally normal JBOT 12/06/20 08:38PM
  Re: Trail tech temp death and rebirthRe: Rick Bergsma Rick Bergsma 12/12/20 04:16PM
  Re: Trail tech temp death and rebirthRe: Totally normal JBOT Totally normal JBOT 12/12/20 04:21PM
  Re: Trail tech temp death and rebirthRe: Totally normal JBOT Totally normal JBOT 12/12/20 04:23PM
  Re: Trail tech temp death and rebirthRe: Totally normal JBOT Totally normal JBOT 12/12/20 04:28PM
  Re: Trail tech temp death and rebirthRe: Rick Bergsma Rick Bergsma 12/12/20 04:37PM
  Re: Trail tech temp death and rebirthRe: weldwizard Jake weldwizard Jake 12/06/20 08:31PM
  Re: Trail tech temp death and rebirthRe: weldwizard Jake weldwizard Jake 12/06/20 08:39PM
  Re: Trail tech temp death and rebirthRe: 🇮🇹💦 Of the Loin 🇮🇹💦 Of the Loin 12/07/20 12:59PM
  Re: Trail tech temp death and rebirthRe: Totally normal JBOT Totally normal JBOT 12/07/20 01:08PM
  Re: Trail tech temp death and rebirthRe: 🇮🇹💦 Of the Loin 🇮🇹💦 Of the Loin 12/07/20 04:38PM
  Re: Trail tech temp death and rebirthRe: Totally normal JBOT Totally normal JBOT 12/07/20 08:49PM
  Re: Trail tech temp death and rebirthRe: 🇮🇹💦 Of the Loin 🇮🇹💦 Of the Loin 12/08/20 01:06AM
  Re: Trail tech temp death and rebirthRe: Brian F Brian F 12/07/20 11:21PM
  Re: Trail tech temp death and rebirthRe: Totally normal JBOT Totally normal JBOT 12/08/20 12:45AM
  Re: Trail tech temp death and rebirthRe: weldwizard Jake weldwizard Jake 12/08/20 12:36AM
  Re: Trail tech temp death and rebirthRe: Brian F Brian F 12/08/20 11:36AM
  Re: Trail tech temp death and rebirthRe: Graham Motzing Graham Motzing 12/08/20 11:47AM
  Re: Trail tech temp death and rebirthRe: Brian F Brian F 12/09/20 10:45AM
  Re: Trail tech temp death and rebirthRe: Totally normal JBOT Totally normal JBOT 12/09/20 12:04PM
  Re: Trail tech temp death and rebirthRe: Brian F Brian F 12/09/20 02:53PM
  Re: Trail tech temp death and rebirthRe: Totally normal JBOT Totally normal JBOT 12/09/20 08:33PM
  Re: Trail tech temp death and rebirthRe: Brian F Brian F 12/11/20 11:34AM
  Re: Trail tech temp death and rebirthRe: Graham Motzing Graham Motzing 12/12/20 09:43PM
  Re: Trail tech temp death and rebirthRe: Papa _ Papa _ 12/13/20 09:41AM
  Re: Trail tech temp death and rebirthRe: Totally normal JBOT Totally normal JBOT 12/18/20 09:32PM
  Re: Trail tech temp death and rebirthRe: Johnny Braaapp Johnny Braaapp 01/16/21 11:11AM
  Re: Trail tech temp death and rebirthRe: P D P D 01/16/21 11:45AM
  Re: Trail tech temp death and rebirthRe: Jason Majernik Jason Majernik 01/12/21 09:26PM
  Re: Trail tech temp death and rebirthRe: Totally normal JBOT Totally normal JBOT 01/12/21 10:53PM
  Re: Trail tech temp death and rebirthRe: Jason Majernik Jason Majernik 01/16/21 12:04AM
  Re: Trail tech temp death and rebirthRe: Totally normal JBOT Totally normal JBOT 01/16/21 11:00AM
  Re: Trail tech temp death and rebirthRe: Marc Friedman Marc Friedman 01/19/21 12:05PM
  Re: Trail tech temp death and rebirthRe: Johnny Braaapp Johnny Braaapp 01/19/21 12:07PM
  Re: Trail tech temp death and rebirthRe: Totally normal JBOT Totally normal JBOT 01/19/21 01:47PM
  Re: Trail tech temp death and rebirthRe: Alan Jackson Alan Jackson 06/22/21 08:06AM
  Re: Trail tech temp death and rebirthRe: Totally normal JBOT Totally normal JBOT 06/22/21 11:36AM
  Re: Trail tech temp death and rebirthRe: - Joe - - Joe - 06/22/21 12:12PM
  Re: Trail tech temp death and rebirthRe: Totally normal JBOT Totally normal JBOT 06/22/21 12:22PM
  Re: Trail tech temp death and rebirthRe: - Joe - - Joe - 06/22/21 12:28PM
  Re: Trail tech temp death and rebirthRe: Totally normal JBOT Totally normal JBOT 06/22/21 12:34PM
  Re: Trail tech temp death and rebirthRe: - Joe - - Joe - 06/22/21 12:57PM
  Re: Trail tech temp death and rebirthRe: Brian F Brian F 06/23/21 01:31PM
  Re: Trail tech temp death and rebirthRe: - Joe - - Joe - 06/23/21 04:47PM
  Re: Trail tech temp death and rebirthRe: Marc Friedman Marc Friedman 06/23/21 05:38PM
  Re: Trail tech temp death and rebirthRe: Brian F Brian F 07/23/21 01:43PM
  Re: Trail tech temp death and rebirthRe: Marc Friedman Marc Friedman 07/23/21 02:39PM
  Re: Trail tech temp death and rebirthRe: Alan Jackson Alan Jackson 06/25/21 11:50AM
  Re: Trail tech temp death and rebirthRe: Alan Jackson Alan Jackson 06/25/21 11:54AM
  Re: Trail tech temp death and rebirthRe: Totally normal JBOT Totally normal JBOT 06/25/21 03:09PM
  Re: Trail tech temp death and rebirthRe: EH FCC of the QCB EH FCC of the QCB 06/25/21 10:26PM
  Re: Trail tech temp death and rebirthRe: Alan Jackson Alan Jackson 06/25/21 11:55AM
  Re: Trail tech temp death and rebirthRe: Alan Jackson Alan Jackson 06/25/21 11:57AM
  Re: Trail tech temp death and rebirthRe: Alan Jackson Alan Jackson 06/25/21 11:59AM
  Re: Trail tech temp death and rebirthRe: Alan Jackson Alan Jackson 06/25/21 12:58PM
  Re: Trail tech temp death and rebirthRe: Alan Jackson Alan Jackson 06/26/21 11:13AM
  Re: Trail tech temp death and rebirthRe: Marc Friedman Marc Friedman 06/26/21 11:24AM
  Re: Trail tech temp death and rebirthRe: Totally normal JBOT Totally normal JBOT 06/26/21 01:48PM
  Re: Trail tech temp death and rebirthRe: Alan Jackson Alan Jackson 06/29/21 11:02AM
  Re: Trail tech temp death and rebirthRe: Alan Jackson Alan Jackson 07/18/21 03:22PM
  Re: Trail tech temp death and rebirthRe: Alan Jackson Alan Jackson 07/23/21 07:46AM
  Re: Trail tech temp death and rebirthRe: Alan Jackson Alan Jackson 07/25/21 06:34AM
  Re: Trail tech temp death and rebirthRe: Marc Friedman Marc Friedman 07/25/21 12:33PM
  Re: Trail tech temp death and rebirthRe: Brian F Brian F 07/26/21 12:16AM
  Re: Trail tech temp death and rebirthRe: Alan Jackson Alan Jackson 07/25/21 04:19PM
  Re: Trail tech temp death and rebirthRe: Alex Fredericksen Alex Fredericksen 07/25/21 06:55PM
  Re: Trail tech temp death and rebirthRe: Totally normal JBOT Totally normal JBOT 07/25/21 06:57PM
  Re: Trail tech temp death and rebirthRe: Alex Fredericksen Alex Fredericksen 07/25/21 06:58PM
  Re: Trail tech temp death and rebirthRe: Totally normal JBOT Totally normal JBOT 07/25/21 07:36PM
  Re: Trail tech temp death and rebirthRe: Brian F Brian F 07/26/21 12:14AM
  Re: Trail tech temp death and rebirthRe: Alan Jackson Alan Jackson 07/27/21 03:06PM
  Re: Trail tech temp death and rebirthRe: Alan Jackson Alan Jackson 08/01/21 11:43AM
  Re: Trail tech temp death and rebirthRe: Marc Friedman Marc Friedman 08/01/21 11:56AM
  Re: Trail tech temp death and rebirthRe: Totally normal JBOT Totally normal JBOT 08/01/21 12:08PM
  Re: Trail tech temp death and rebirthRe: Totally normal JBOT Totally normal JBOT 08/01/21 01:11PM
  Re: Trail tech temp death and rebirthRe: Marc Friedman Marc Friedman 08/01/21 01:32PM
  Re: Trail tech temp death and rebirthRe: Totally normal JBOT Totally normal JBOT 08/01/21 01:47PM
  Re: Trail tech temp death and rebirthRe: Marc Friedman Marc Friedman 08/01/21 06:49PM
  Re: Trail tech temp death and rebirthRe: Totally normal JBOT Totally normal JBOT 08/02/21 10:30AM
  Re: Trail tech temp death and rebirthRe: josh n josh n 07/04/21 10:13PM
  Re: Trail tech temp death and rebirthRe: Totally normal JBOT Totally normal JBOT 07/25/21 03:59PM
  Re: Trail tech temp death and rebirthRe: Totally normal JBOT Totally normal JBOT 08/05/21 01:57PM
  Re: Trail tech temp death and rebirthRe: Alan Jackson Alan Jackson 08/05/21 04:06PM
  Re: Trail tech temp death and rebirthRe: Alan Jackson Alan Jackson 08/05/21 04:24PM
  Re: Trail tech temp death and rebirthRe: Matt Madden Matt Madden 08/11/21 10:00AM
  Re: Trail tech temp death and rebirthRe: Totally normal JBOT Totally normal JBOT 08/11/21 11:47AM
