Re: Trail tech temp death and rebirth
Alan Jackson /
first i looked at a pic of where the battery is situated and then cut a smaller square central to the battery in the plastic back with a dremel and cut off wheel, only going 2mm deep or so till i could see a hint of shiny metal (battery)
i cut this square completely off exposing part of the battery.
then i slowly increased the size of the hole.
for some reason i have developed decent hand eye coordination and can actually cut fingernails with a stihl saw. so a dremel is fairly easy for me to hold still.
once the battery was fully exposed i started scraping out the grey epoxy with a tiny jewellers screwdriver.
the terminal was firmly attached to the back of the battery and i had to very carefully prize it off the battery using the same very thin screwdriver.
once this was undone the battery could be removed.
and another simply popped in. except it didnt work.
the other terminal needed to be scraped clean of a kind of laquer that was hampering a good contact. i didnt realise the laquer was there until i got my jewellers eyepiece out and had a look.
then i just cut a clear bit of plastic and drilled 4 tiny holes for the 2mm self tapping screws and a larger hole for the blue reset button.
i suppose what helped me is that i started messing about changing cracked iphone screens a few years ago and its the same type of care and restraint and PATIENCE!!! that is required.
apparently the resistance of the thermistor is 10k at 25 degrees c.
so i should be able to plot a graph and work out what resistance the trail tech sensor is.
unless someone can test theirs at 25 deg c?
  Trail tech temp death and rebirthTopic by: Totally normal JBOT Totally normal JBOT 02/27/18 09:58PM
  Re: Trail tech temp death and rebirthRe: Totally normal JBOT Totally normal JBOT 02/27/18 10:07PM
  Re: Trail tech temp death and rebirthRe: Tyler Dead Possums Tyler Dead Possums 03/01/18 12:33PM
  Re: Trail tech temp death and rebirthRe: Thomas TPRF Thomas TPRF 03/01/18 04:02PM
  Re: Trail tech temp death and rebirthRe: Totally normal JBOT Totally normal JBOT 03/01/18 09:47PM
  Re: Trail tech temp death and rebirthRe: cheetahchrome . cheetahchrome . 03/02/18 12:03AM
  Re: Trail tech temp death and rebirthRe: Born to be WillD Born to be WillD 02/28/18 10:23AM
  Re: Trail tech temp death and rebirthRe: Totally normal JBOT Totally normal JBOT 02/28/18 10:42AM
  Re: Trail tech temp death and rebirthRe: Totally normal JBOT Totally normal JBOT 02/28/18 10:50AM
  Re: Trail tech temp death and rebirthRe: Totally normal JBOT Totally normal JBOT 02/28/18 02:58PM
  Re: Trail tech temp death and rebirthRe: MPB Andyrew MPB Andyrew 02/28/18 03:22PM
  Re: Trail tech temp death and rebirthRe: todd amundson todd amundson 04/16/18 02:29PM
  Re: Trail tech temp death and rebirthRe: Totally normal JBOT Totally normal JBOT 04/16/18 02:34PM
  Re: Trail tech temp death and rebirthRe: Neil Verchot Neil Verchot 02/28/18 10:26AM
  Re: Trail tech temp death and rebirthRe: MPB Andyrew MPB Andyrew 02/28/18 03:23PM
  Re: Trail tech temp death and rebirthRe: Tyler Dead Possums Tyler Dead Possums 03/01/18 01:09PM
  Re: Trail tech temp death and rebirthRe: Totally normal JBOT Totally normal JBOT 03/01/18 01:13PM
  Re: Trail tech temp death and rebirthRe: Tyler Dead Possums Tyler Dead Possums 03/01/18 01:51PM
  Re: Trail tech temp death and rebirthRe: Totally normal JBOT Totally normal JBOT 03/01/18 02:39PM
  Re: Trail tech temp death and rebirthRe: Tyler Dead Possums Tyler Dead Possums 03/01/18 03:02PM
  Re: Trail tech temp death and rebirthRe: * * * * 03/01/18 09:33PM
  Re: Trail tech temp death and rebirthRe: Tyler Dead Possums Tyler Dead Possums 03/02/18 09:10AM
  Re: Trail tech temp death and rebirthRe: * * * * 03/02/18 03:33PM
  Re: Trail tech temp death and rebirthRe: P D P D 03/02/18 06:06PM
  Re: Trail tech temp death and rebirthRe: Totally normal JBOT Totally normal JBOT 03/02/18 08:50PM
  Re: Trail tech temp death and rebirthRe: * * * * 03/03/18 12:30AM
  Re: Trail tech temp death and rebirthRe: Totally normal JBOT Totally normal JBOT 03/03/18 12:34AM
  Re: Trail tech temp death and rebirthRe: Totally normal JBOT Totally normal JBOT 03/03/18 12:40AM
  Re: Trail tech temp death and rebirthRe: * * * * 03/03/18 02:12PM
  Re: Trail tech temp death and rebirthRe: Totally normal JBOT Totally normal JBOT 03/03/18 02:44PM
  Re: Trail tech temp death and rebirthRe: * * * * 03/03/18 07:30PM
  Re: Trail tech temp death and rebirthRe: Totally normal JBOT Totally normal JBOT 03/03/18 10:59PM
  Re: Trail tech temp death and rebirthRe: Thomas TPRF Thomas TPRF 03/03/18 03:04PM
  Re: Trail tech temp death and rebirthRe: frank dadog frank dadog 03/03/18 06:05PM
  Re: Trail tech temp death and rebirthRe: Thomas TPRF Thomas TPRF 03/03/18 09:06PM
  Re: Trail tech temp death and rebirthRe: Born to be WillD Born to be WillD 03/06/18 09:56AM
  Re: Trail tech temp death and rebirthRe: Totally normal JBOT Totally normal JBOT 03/06/18 12:02PM
  Re: Trail tech temp death and rebirthRe: Born to be WillD Born to be WillD 03/06/18 12:38PM
  Re: Trail tech temp death and rebirthRe: EH FCC of the QCB EH FCC of the QCB 04/08/18 10:48AM
  Re: Trail tech temp death and rebirthRe: Born to be WillD Born to be WillD 03/06/18 10:00AM
  Re: Trail tech temp death and rebirthRe: Lazy Pedaler Lazy Pedaler 04/08/18 10:34AM
  Re: Trail tech temp death and rebirthRe: Nick Sullivan Nick Sullivan 12/07/20 09:34PM
  Re: Trail tech temp death and rebirthRe: Nick Sullivan Nick Sullivan 12/07/20 09:37PM
  Re: Trail tech temp death and rebirthRe: todd amundson todd amundson 04/16/18 11:58PM
  Re: Trail tech temp death and rebirthRe: Max LGN Max LGN 04/17/18 06:29AM
  Re: Trail tech temp death and rebirthRe: Born to be WillD Born to be WillD 04/17/18 09:48AM
  Re: Trail tech temp death and rebirthRe: Max LGN Max LGN 04/17/18 12:32PM
  Re: Trail tech temp death and rebirthRe: Totally normal JBOT Totally normal JBOT 05/18/18 11:54PM
  Re: Trail tech temp death and rebirthRe: Totally normal JBOT Totally normal JBOT 03/06/21 05:48PM
  Re: Trail tech temp death and rebirthRe: Totally normal JBOT Totally normal JBOT 03/06/21 06:05PM
  Re: Trail tech temp death and rebirthRe: EH FCC of the QCB EH FCC of the QCB 03/06/21 06:32PM
  Re: Trail tech temp death and rebirthRe: weldwizard Jake weldwizard Jake 12/06/20 08:10PM
  Re: Trail tech temp death and rebirthRe: Totally normal JBOT Totally normal JBOT 12/06/20 08:38PM
  Re: Trail tech temp death and rebirthRe: Rick Bergsma Rick Bergsma 12/12/20 04:16PM
  Re: Trail tech temp death and rebirthRe: Totally normal JBOT Totally normal JBOT 12/12/20 04:21PM
  Re: Trail tech temp death and rebirthRe: Totally normal JBOT Totally normal JBOT 12/12/20 04:23PM
  Re: Trail tech temp death and rebirthRe: Totally normal JBOT Totally normal JBOT 12/12/20 04:28PM
  Re: Trail tech temp death and rebirthRe: Rick Bergsma Rick Bergsma 12/12/20 04:37PM
  Re: Trail tech temp death and rebirthRe: weldwizard Jake weldwizard Jake 12/06/20 08:31PM
  Re: Trail tech temp death and rebirthRe: weldwizard Jake weldwizard Jake 12/06/20 08:39PM
  Re: Trail tech temp death and rebirthRe: 🇮🇹💦 Of the Loin 🇮🇹💦 Of the Loin 12/07/20 12:59PM
  Re: Trail tech temp death and rebirthRe: Totally normal JBOT Totally normal JBOT 12/07/20 01:08PM
  Re: Trail tech temp death and rebirthRe: 🇮🇹💦 Of the Loin 🇮🇹💦 Of the Loin 12/07/20 04:38PM
  Re: Trail tech temp death and rebirthRe: Totally normal JBOT Totally normal JBOT 12/07/20 08:49PM
  Re: Trail tech temp death and rebirthRe: 🇮🇹💦 Of the Loin 🇮🇹💦 Of the Loin 12/08/20 01:06AM
  Re: Trail tech temp death and rebirthRe: Brian F Brian F 12/07/20 11:21PM
  Re: Trail tech temp death and rebirthRe: Totally normal JBOT Totally normal JBOT 12/08/20 12:45AM
  Re: Trail tech temp death and rebirthRe: weldwizard Jake weldwizard Jake 12/08/20 12:36AM
  Re: Trail tech temp death and rebirthRe: Brian F Brian F 12/08/20 11:36AM
  Re: Trail tech temp death and rebirthRe: Graham Motzing Graham Motzing 12/08/20 11:47AM
  Re: Trail tech temp death and rebirthRe: Brian F Brian F 12/09/20 10:45AM
  Re: Trail tech temp death and rebirthRe: Totally normal JBOT Totally normal JBOT 12/09/20 12:04PM
  Re: Trail tech temp death and rebirthRe: Brian F Brian F 12/09/20 02:53PM
  Re: Trail tech temp death and rebirthRe: Totally normal JBOT Totally normal JBOT 12/09/20 08:33PM
  Re: Trail tech temp death and rebirthRe: Brian F Brian F 12/11/20 11:34AM
  Re: Trail tech temp death and rebirthRe: Graham Motzing Graham Motzing 12/12/20 09:43PM
  Re: Trail tech temp death and rebirthRe: Papa _ Papa _ 12/13/20 09:41AM
  Re: Trail tech temp death and rebirthRe: Totally normal JBOT Totally normal JBOT 12/18/20 09:32PM
  Re: Trail tech temp death and rebirthRe: Johnny Braaapp Johnny Braaapp 01/16/21 11:11AM
  Re: Trail tech temp death and rebirthRe: P D P D 01/16/21 11:45AM
  Re: Trail tech temp death and rebirthRe: Jason Majernik Jason Majernik 01/12/21 09:26PM
  Re: Trail tech temp death and rebirthRe: Totally normal JBOT Totally normal JBOT 01/12/21 10:53PM
  Re: Trail tech temp death and rebirthRe: Jason Majernik Jason Majernik 01/16/21 12:04AM
  Re: Trail tech temp death and rebirthRe: Totally normal JBOT Totally normal JBOT 01/16/21 11:00AM
  Re: Trail tech temp death and rebirthRe: Marc Friedman Marc Friedman 01/19/21 12:05PM
  Re: Trail tech temp death and rebirthRe: Johnny Braaapp Johnny Braaapp 01/19/21 12:07PM
  Re: Trail tech temp death and rebirthRe: Totally normal JBOT Totally normal JBOT 01/19/21 01:47PM
  Re: Trail tech temp death and rebirthRe: Alan Jackson Alan Jackson 06/22/21 08:06AM
  Re: Trail tech temp death and rebirthRe: Totally normal JBOT Totally normal JBOT 06/22/21 11:36AM
  Re: Trail tech temp death and rebirthRe: - Joe - - Joe - 06/22/21 12:12PM
  Re: Trail tech temp death and rebirthRe: Totally normal JBOT Totally normal JBOT 06/22/21 12:22PM
  Re: Trail tech temp death and rebirthRe: - Joe - - Joe - 06/22/21 12:28PM
  Re: Trail tech temp death and rebirthRe: Totally normal JBOT Totally normal JBOT 06/22/21 12:34PM
  Re: Trail tech temp death and rebirthRe: - Joe - - Joe - 06/22/21 12:57PM
  Re: Trail tech temp death and rebirthRe: Brian F Brian F 06/23/21 01:31PM
  Re: Trail tech temp death and rebirthRe: - Joe - - Joe - 06/23/21 04:47PM
  Re: Trail tech temp death and rebirthRe: Marc Friedman Marc Friedman 06/23/21 05:38PM
  Re: Trail tech temp death and rebirthRe: Brian F Brian F 07/23/21 01:43PM
  Re: Trail tech temp death and rebirthRe: Marc Friedman Marc Friedman 07/23/21 02:39PM
  Re: Trail tech temp death and rebirthRe: Alan Jackson Alan Jackson 06/25/21 11:50AM
  Re: Trail tech temp death and rebirthRe: Alan Jackson Alan Jackson 06/25/21 11:54AM
  Re: Trail tech temp death and rebirthRe: Totally normal JBOT Totally normal JBOT 06/25/21 03:09PM
  Re: Trail tech temp death and rebirthRe: EH FCC of the QCB EH FCC of the QCB 06/25/21 10:26PM
  Re: Trail tech temp death and rebirthRe: Alan Jackson Alan Jackson 06/25/21 11:55AM
  Re: Trail tech temp death and rebirthRe: Alan Jackson Alan Jackson 06/25/21 11:57AM
  Re: Trail tech temp death and rebirthRe: Alan Jackson Alan Jackson 06/25/21 11:59AM
  Re: Trail tech temp death and rebirthRe: Alan Jackson Alan Jackson 06/25/21 12:58PM
  Re: Trail tech temp death and rebirthRe: Alan Jackson Alan Jackson 06/26/21 11:13AM
  Re: Trail tech temp death and rebirthRe: Marc Friedman Marc Friedman 06/26/21 11:24AM
  Re: Trail tech temp death and rebirthRe: Totally normal JBOT Totally normal JBOT 06/26/21 01:48PM
  Re: Trail tech temp death and rebirthRe: Alan Jackson Alan Jackson 06/29/21 11:02AM
  Re: Trail tech temp death and rebirthRe: Alan Jackson Alan Jackson 07/18/21 03:22PM
  Re: Trail tech temp death and rebirthRe: Alan Jackson Alan Jackson 07/23/21 07:46AM
  Re: Trail tech temp death and rebirthRe: Alan Jackson Alan Jackson 07/25/21 06:34AM
  Re: Trail tech temp death and rebirthRe: Marc Friedman Marc Friedman 07/25/21 12:33PM
  Re: Trail tech temp death and rebirthRe: Brian F Brian F 07/26/21 12:16AM
  Re: Trail tech temp death and rebirthRe: Alan Jackson Alan Jackson 07/25/21 04:19PM
  Re: Trail tech temp death and rebirthRe: Alex Fredericksen Alex Fredericksen 07/25/21 06:55PM
  Re: Trail tech temp death and rebirthRe: Totally normal JBOT Totally normal JBOT 07/25/21 06:57PM
  Re: Trail tech temp death and rebirthRe: Alex Fredericksen Alex Fredericksen 07/25/21 06:58PM
  Re: Trail tech temp death and rebirthRe: Totally normal JBOT Totally normal JBOT 07/25/21 07:36PM
  Re: Trail tech temp death and rebirthRe: Brian F Brian F 07/26/21 12:14AM
  Re: Trail tech temp death and rebirthRe: Alan Jackson Alan Jackson 07/27/21 03:06PM
  Re: Trail tech temp death and rebirthRe: Alan Jackson Alan Jackson 08/01/21 11:43AM
  Re: Trail tech temp death and rebirthRe: Marc Friedman Marc Friedman 08/01/21 11:56AM
  Re: Trail tech temp death and rebirthRe: Totally normal JBOT Totally normal JBOT 08/01/21 12:08PM
  Re: Trail tech temp death and rebirthRe: Totally normal JBOT Totally normal JBOT 08/01/21 01:11PM
  Re: Trail tech temp death and rebirthRe: Marc Friedman Marc Friedman 08/01/21 01:32PM
  Re: Trail tech temp death and rebirthRe: Totally normal JBOT Totally normal JBOT 08/01/21 01:47PM
  Re: Trail tech temp death and rebirthRe: Marc Friedman Marc Friedman 08/01/21 06:49PM
  Re: Trail tech temp death and rebirthRe: Totally normal JBOT Totally normal JBOT 08/02/21 10:30AM
  Re: Trail tech temp death and rebirthRe: josh n josh n 07/04/21 10:13PM
  Re: Trail tech temp death and rebirthRe: Totally normal JBOT Totally normal JBOT 07/25/21 03:59PM
  Re: Trail tech temp death and rebirthRe: Totally normal JBOT Totally normal JBOT 08/05/21 01:57PM
  Re: Trail tech temp death and rebirthRe: Alan Jackson Alan Jackson 08/05/21 04:06PM
  Re: Trail tech temp death and rebirthRe: Alan Jackson Alan Jackson 08/05/21 04:24PM
  Re: Trail tech temp death and rebirthRe: Matt Madden Matt Madden 08/11/21 10:00AM
  Re: Trail tech temp death and rebirthRe: Totally normal JBOT Totally normal JBOT 08/11/21 11:47AM
