Re: Fastest Suzuki FA50? Hoping to hit 70mph
«tyler » /
> Graham Motzing Wrote:
> i'm more concerned about synthetic or conventional two stroke, typically
> you should run a conventional (mineral) two stroke oil that is TCW-3
> rated in an oil injector with cast iron cylinder, but at these speeds
> you may want to consider a synthetic oil that is compatable with oil
> injectors
> it sounds like you're not putting much thought into the oil you are
> going to use and whether or not you're going to use a funnel to get it
> into the reservior, you might have to upgrade your oil injector hoses to
> handle higher volume.
Hm I'm going to have to disagree with you here. Synthetic is far more often recommended in most injected systems. If Brent wants the best performance he's going to have to go para-synthetic. It's a mix between conventional and synthetic and is really the best option. Here is a short article with the information he might need to know what's best.
1. Preliminary Considerations
The oil in a 2-stroke engine performs two distinctly different functions. First and foremost, it lubricates the moving parts of the engine while it is running. Without a thin film of oil for lubrication between the pistons and the cylinder walls, the engine would self destruct in short order. Equally important to the life of the engine is the lubrication of rod bearings, crankshaft bearings, and piston pins.
The other function is that of protecting the internal parts of the engine as it sits quietly between flights, sometimes for weeks or even months at a time. The oil should cling to the internal parts, forming a thin film that protects against moisture and prevents rust.
Unfortunately, an oil that has excellent lubricating properties may not exhibit the best ability to form the protective film. Or, an oil that has good film characteristics may not provide the best lubrication. It's a tradeoff.
For 2-stroke engines, there is the practical matter of getting the oil into the engine. The oil is mixed with the fuel in a definite proportion and is then carried to the inside of the engine by the fuel as it passes through the crankcase on the way to the cylinders. The oil may be mixed with the fuel prior to putting the fuel into the tank (premix), or a special injector pump mounted on the engine may inject the oil into the fuel-air stream after it passes through the carburetor. When an injector is used, the oil is stored in a small tank or bottle mounted on or near the engine.
Injector pumps are favored by those who dislike the task of mixing the oil and the fuel, but others are skeptical of them because of their complexity and the nagging uncertainty as to whether the pump is really doing its job. At any rate, there are two methods (premix and injector) used to introduce the oil, and the method of introduction may impact the decision about which oil is preferred.
Yet another consideration arises because almost all the oil introduced into a 2-stroke engine is burned in the cylinders, quite unlike a 4-stroke engine. Therefore, a suitable oil for 2-strokes must burn clean without producing excessive deposits of carbon on the pistons and especially on the piston rings. A secondary consideration is the amount of oil residue that blows out the exhaust to be deposited on the tail feathers, the prop, and the rearward surfaces of the plane.
So, "Which oil should I use?" is not such a simple question after all! There are many things to consider, many competing factors, and in the end, a compromise must be made.
2. Three Different "Types" of Oil
There are basically three different types of oil available. We have straight mineral based oils, straight synthetic oils, and then we have something called a para-synthetic. The para-synthetic oil is a blend of both mineral and synthetic oils.
Mineral based oils are generally known for good lubrication properties while the engine is running and then, while the engine is sitting between flights, the mineral oils do a great job of keeping the internal parts of the engine coated with a fine film that keeps rust from forming. However, there have been complaints about excessive carbon deposits and stuck rings in some cases when straight mineral-based oils are used.
Synthetic oils are generally known for having excellent lubrication properties with low deposits while the engine is running. But, the super slick nature of straight synthetics has been accused of not being very good at leaving the fine film on the internal parts while the engine is inactive. The para-synthetics are touted as being the best of both worlds by providing the pro's and limiting the con's of both the mineral and synthetic oils.
3. The Most Popular Oils used in Ultralight Engines
There seem to be two main oils that ultralighters use. They are Pennzoil for Air Cooled Engines and Amsoil synthetic oil for 2-stroke engines. The Pennzoil is mixed at 50:1 while the Amsoil is mixed at 100:1.
Some reports state that Pennzoil gives the best lubrication while Amsoil or synthetics give the least carbon buildup and tail feather deposits. Mechanics have stated opinions from "no problems at all with Amsoil" to "Pennzoil gives better wear protection than Amsoil".
One contributor to this article writes, "I am inclined to listen to Tom Olenik when he says that he sees a little more engine wear with Amsoil at 100:1. I also note that Amsoil does recommend increasing the mix ratio to 80:1 for severe service conditions, which may include improper warm-ups or perhaps running at full throttle most of the time."
There have even been a few bad reports on Pennzoil and Amsoil but most, by far, are very positive. Early synthetics were reported to have an affinity for moisture. This problem is supposed to have been overcome many years ago. An obvious advantage to using synthetic is less carbon buildup and much less residue on the tail feathers, due to the simple fact that, at 100 : 1, there is less oil in the fuel to burn.
Some folks swear by Pennzoil, and other swear by Amsoil. Some swear at both so "your mileage may vary".
4. The Tried and True: A Recommendation
Now, for the person who just wants to know what oil to use in his engine without getting into all the esoteric details, here it is:
Pennzoil for Aircooled Engines mixed 50 : 1
Please understand, this is not saying that Amsoil, or any other oil is bad, and we're not saying that Pennzoil is the best, we're just saying that, overall, you will be "safe" with Pennzoil.
This recommendation is based upon years of experience with Pennzoil and the favorable reports of its use in hundreds or even thousands of engines.
To give you an idea of the strength of the convictions represented here, one contributor to this article does not use Pennzoil in his plane. He prefers a synthetic. However, all agree that, indeed, you will be "safe" with Pennzoil because of its track record, and also because the 50:1 mix ratio is a little less critical than 100:1 for the synthetic Amsoil.
5. Other Available Oils
There are Pennzoil 2-stroke oils formulated for marine or outboard use. While they may work, they are not recommended as the formulation is not set up for the air cooled engines. Some folks have used regular 2-stroke engine oils such as those from Walmart and other stores. Good results have been reported by some as well as bad results by others.
Other oils in popular use are Yamalube, AV2, Valvoline, Quaker State, Shell, Advance, and Golden Spectro, which is a blend of organic and synthetic oil.
One person writes, "I have been using the Golden Spectro for close to 20 years myself. My satisfaction is based on the performance and condition of the engines upon routine breakdown inspections."
6. Other Variables
There are lots of brands and lots of claims. However, keep in mind that there are many other variables that come into play that can allow someone to have success or failure with any of the oils. Here's some food for thought.
Say we have a guy in the North-Eastern, colder, wetter climates that uses a straight synthetic oil. He discovers rust on the inside of his engine upon tearing it down. A guy in the dry South-West, using the very same oil, might report that his engine is clean as a whistle and rust free. We might prematurely conclude that the straight synthetic might not be the way to go in the wetter climates.
What might the guy in the North-East do to change the outcome of his tear-down inspections? For one, he might follow the most recent guidelines from Rotax for storing the engine when not in use. Some of the recommended items include carb covers and plugs for the muffler to keep moisture from entering the engine when not in use. Long term storage should include draining the fuel system, fogging the engine with oil, and so forth.
Several years back, Ultralight Flying magazine did a survey on engine oils. This was an attempt to determine what oils were being used and what complaints the users had that might be associated with various oils.
Surprisingly, three oils were touted as having the least number of complaints that could be attributed to oils. Belray had two products included in the three, and the third oil was Golden Spectro's para-synthetic.
It should be pointed out that the results of this survey probably fall far short of being scientific. It would be interesting to see truly unbiased results of a survey of all the oils that are in use in various scenarios and climates.
Perhaps it's a bit too easy for manufacturers to construct tests to make their own oils outshine those of the competition under specific circumstances. In turn, this makes it nearly impossible for a consumer to do a meaningful evaluation of one oil relative to another.
More important than the oil issue is the carb tuning and proper fuel mixture. Most of the oils available today can do a fine job of lubricating the internal parts of the engine. If a guy were to select a premium low ash oil known for having a cleaner burn, he can negate the benefits of the oil by running the engine too rich which can cause more deposits than normal.
By the same token, someone could have better than average results with a low end oil if his carburetor was carefully and expertly tuned. Two many variables come into play for it to be possible to guarantee certain results with Brand "X." Jetting, fuel octane, temperature, altitude, and many other factors can enhance or negate the success achieved with a particular oil.
7. Conclusion
Hopefully, this article has added to your understanding of the complexities associated with the apparently simple matter of choosing an oil for your engine. Admittedly, we have not provided a lot of firm answers. But, we did make a recommendation to get you started.
As you gain experience with your engine and acquire knowledge of its peculiar traits and mannerisms, all the while talking to the local experts, you may come to prefer one oil over another. That is just fine. After all, the variables to which your engine is subjected may be quite different from a similar one not all that far away.
Contributors to this Article: Bud Connolly,
Mike Harrison,
Jim Hayward,
and Ralph Shultz.
  Fastest Suzuki FA50? Hoping to hit 70mphTopic by: Brent Saxsma Brent Saxsma 01/22/18 02:45AM
  Re: Fastest Suzuki FA50? Hoping to hit 70mphRe: Mikey Antonakakis Mikey Antonakakis 01/22/18 04:30AM
  Re: Fastest Suzuki FA50? Hoping to hit 70mphRe: Brent Saxsma Brent Saxsma 01/23/18 03:05PM
  Re: Fastest Suzuki FA50? Hoping to hit 70mphRe: Dirty30 Dillon Dirty30 Dillon 01/22/18 09:20AM
  Re: Fastest Suzuki FA50? Hoping to hit 70mphRe: Brent Saxsma Brent Saxsma 01/23/18 03:08PM
  Re: Fastest Suzuki FA50? Hoping to hit 70mphRe: Derek Stahl Derek Stahl 01/22/18 11:33AM
  Re: Fastest Suzuki FA50? Hoping to hit 70mphRe: P D P D 01/22/18 11:54AM
  Re: Fastest Suzuki FA50? Hoping to hit 70mphRe: Brent Saxsma Brent Saxsma 01/23/18 02:53PM
  Re: Fastest Suzuki FA50? Hoping to hit 70mphRe: Brent Saxsma Brent Saxsma 01/23/18 02:52PM
  Re: Fastest Suzuki FA50? Hoping to hit 70mphRe: Ollie Tabooger Ollie Tabooger 01/22/18 01:01PM
  Re: Fastest Suzuki FA50? Hoping to hit 70mphRe: Brent Saxsma Brent Saxsma 01/23/18 03:11PM
  Re: Fastest Suzuki FA50? Hoping to hit 70mphRe: Dave & Bummerzz Dave & Bummerzz 01/23/18 04:59PM
  Re: Fastest Suzuki FA50? Hoping to hit 70mphRe: Brent Saxsma Brent Saxsma 01/23/18 05:07PM
  Re: Fastest Suzuki FA50? Hoping to hit 70mphRe: P D P D 01/24/18 12:40PM
  Re: Fastest Suzuki FA50? Hoping to hit 70mphRe: Dave & Bummerzz Dave & Bummerzz 01/24/18 12:56PM
  Re: Fastest Suzuki FA50? Hoping to hit 70mphRe: Brent Saxsma Brent Saxsma 01/24/18 07:52PM
  Re: Fastest Suzuki FA50? Hoping to hit 70mphRe: Dave & Bummerzz Dave & Bummerzz 01/22/18 02:32PM
  Re: Fastest Suzuki FA50? Hoping to hit 70mphRe: Brent Saxsma Brent Saxsma 01/23/18 03:12PM
  Re: Fastest Suzuki FA50? Hoping to hit 70mphRe: Chris . Chris . 01/22/18 06:46PM
  Re: Fastest Suzuki FA50? Hoping to hit 70mphRe: Brent Saxsma Brent Saxsma 01/23/18 03:13PM
  Re: Fastest Suzuki FA50? Hoping to hit 70mphRe: alex . alex . 01/23/18 02:24PM
  Re: Fastest Suzuki FA50? Hoping to hit 70mphRe: Brent Saxsma Brent Saxsma 01/23/18 03:16PM
  Re: Fastest Suzuki FA50? Hoping to hit 70mphRe: Graham Motzing Graham Motzing 01/23/18 03:25PM
  Re: Fastest Suzuki FA50? Hoping to hit 70mphRe: Mikey Antonakakis Mikey Antonakakis 01/23/18 03:36PM
  Re: Fastest Suzuki FA50? Hoping to hit 70mphRe: Brent Saxsma Brent Saxsma 01/24/18 07:48PM
  Re: Fastest Suzuki FA50? Hoping to hit 70mphRe: Ben Whittle Ben Whittle 01/24/18 11:11PM
  Re: Fastest Suzuki FA50? Hoping to hit 70mphRe: «tyler » «tyler » 01/25/18 12:28PM
  Re: Fastest Suzuki FA50? Hoping to hit 70mphRe: Graham Motzing Graham Motzing 01/25/18 12:52PM
  Re: Fastest Suzuki FA50? Hoping to hit 70mphRe: alex . alex . 01/25/18 03:56PM
  Re: Fastest Suzuki FA50? Hoping to hit 70mphRe: Brent Saxsma Brent Saxsma 01/25/18 08:37PM
  Re: Fastest Suzuki FA50? Hoping to hit 70mphRe: Brent Saxsma Brent Saxsma 01/25/18 08:51PM
  Re: Fastest Suzuki FA50? Hoping to hit 70mphRe: alex . alex . 01/25/18 11:56PM
  Re: Fastest Suzuki FA50? Hoping to hit 70mphRe: Dirty30 Dillon Dirty30 Dillon 01/26/18 10:49AM
  Re: Fastest Suzuki FA50? Hoping to hit 70mphRe: Graham Motzing Graham Motzing 01/26/18 11:20AM
  Re: Fastest Suzuki FA50? Hoping to hit 70mphRe: Brent Saxsma Brent Saxsma 01/23/18 05:10PM
  Re: Fastest Suzuki FA50? Hoping to hit 70mphRe: jayson sumpter jayson sumpter 01/23/18 10:15PM
  Re: Fastest Suzuki FA50? Hoping to hit 70mphRe: Brent Saxsma Brent Saxsma 01/23/18 10:34PM
  Re: Fastest Suzuki FA50? Hoping to hit 70mphRe: Brent Saxsma Brent Saxsma 01/23/18 02:49PM
  Re: Fastest Suzuki FA50? Hoping to hit 70mphRe: alex . alex . 01/23/18 04:42PM
  Re: Fastest Suzuki FA50? Hoping to hit 70mphRe: Joe Schuitema Joe Schuitema 01/23/18 10:51PM
  Re: Fastest Suzuki FA50? Hoping to hit 70mphRe: alex . alex . 01/24/18 12:49AM
  Re: Fastest Suzuki FA50? Hoping to hit 70mphRe: Brent Saxsma Brent Saxsma 01/24/18 07:50PM
  Re: Fastest Suzuki FA50? Hoping to hit 70mphRe: Jack Rutherford Jack Rutherford 01/24/18 12:50PM
  Re: Fastest Suzuki FA50? Hoping to hit 70mphRe: Mikey Antonakakis Mikey Antonakakis 01/25/18 01:26AM
  Re: Fastest Suzuki FA50? Hoping to hit 70mphRe: Brent Saxsma Brent Saxsma 01/25/18 08:31PM
  Re: Fastest Suzuki FA50? Hoping to hit 70mphRe: Mikey Antonakakis Mikey Antonakakis 01/25/18 10:30PM
  Re: Fastest Suzuki FA50? Hoping to hit 70mphRe: DrGeorgeTompson (Alan) DrGeorgeTompson (Alan) 01/24/18 02:04PM
  Re: Fastest Suzuki FA50? Hoping to hit 70mphRe: Ben Whittle Ben Whittle 01/24/18 03:51PM
  Re: Fastest Suzuki FA50? Hoping to hit 70mphRe: Brent Saxsma Brent Saxsma 01/24/18 07:54PM
  Re: Fastest Suzuki FA50? Hoping to hit 70mphRe: alex . alex . 01/25/18 08:48PM
  Re: Fastest Suzuki FA50? Hoping to hit 70mphRe: Brent Saxsma Brent Saxsma 01/25/18 08:54PM
  Re: Fastest Suzuki FA50? Hoping to hit 70mphRe: Brent Saxsma Brent Saxsma 01/25/18 08:58PM
  Re: Fastest Suzuki FA50? Hoping to hit 70mphRe: Brent Saxsma Brent Saxsma 01/25/18 11:15PM
  Re: Fastest Suzuki FA50? Hoping to hit 70mphRe: Brent Saxsma Brent Saxsma 01/26/18 01:56AM
  Re: Fastest Suzuki FA50? Hoping to hit 70mphRe: Brent Saxsma Brent Saxsma 01/26/18 02:02AM
  Re: Fastest Suzuki FA50? Hoping to hit 70mphRe: Brandon Weiss (Detective brandon to you) Brandon Weiss (Detective brandon to you) 01/26/18 02:03AM
  Re: Fastest Suzuki FA50? Hoping to hit 70mphRe: Brent Saxsma Brent Saxsma 01/26/18 02:12AM
  Re: Fastest Suzuki FA50? Hoping to hit 70mphRe: Brent Saxsma Brent Saxsma 01/26/18 02:18AM
  Re: Fastest Suzuki FA50? Hoping to hit 70mphRe: Brent Saxsma Brent Saxsma 01/26/18 02:22AM
  Re: Fastest Suzuki FA50? Hoping to hit 70mphRe: Brent Saxsma Brent Saxsma 01/26/18 02:27AM
  Re: Fastest Suzuki FA50? Hoping to hit 70mphRe: Brent Saxsma Brent Saxsma 01/26/18 02:30AM
  Re: Fastest Suzuki FA50? Hoping to hit 70mphRe: Brent Saxsma Brent Saxsma 01/26/18 02:32AM
  Re: Fastest Suzuki FA50? Hoping to hit 70mphRe: Brent Saxsma Brent Saxsma 01/26/18 02:36AM
  Re: Fastest Suzuki FA50? Hoping to hit 70mphRe: Dave & Bummerzz Dave & Bummerzz 01/26/18 09:49AM
  Re: Fastest Suzuki FA50? Hoping to hit 70mphRe: Mikey Antonakakis Mikey Antonakakis 01/26/18 03:02AM
  Re: Fastest Suzuki FA50? Hoping to hit 70mphRe: Graham Motzing Graham Motzing 01/26/18 10:47AM
  Re: Fastest Suzuki FA50? Hoping to hit 70mphRe: «tyler » «tyler » 01/26/18 11:04AM
  Re: Fastest Suzuki FA50? Hoping to hit 70mphRe: Mikey Antonakakis Mikey Antonakakis 01/26/18 05:55PM
  Re: Fastest Suzuki FA50? Hoping to hit 70mphRe: P D P D 01/26/18 06:00PM
  Re: Fastest Suzuki FA50? Hoping to hit 70mphRe: Mikey Antonakakis Mikey Antonakakis 01/26/18 06:02PM
  Re: Fastest Suzuki FA50? Hoping to hit 70mphRe: alex . alex . 01/26/18 11:25AM
  Re: Fastest Suzuki FA50? Hoping to hit 70mphRe: Graham Motzing Graham Motzing 01/26/18 11:32AM
  Re: Fastest Suzuki FA50? Hoping to hit 70mphRe: Ty 🏍 Ty 🏍 01/26/18 05:38PM
  Re: Fastest Suzuki FA50? Hoping to hit 70mphRe: Graham Motzing Graham Motzing 01/26/18 09:11PM
  Re: Fastest Suzuki FA50? Hoping to hit 70mphRe: Brent Saxsma Brent Saxsma 01/26/18 08:51PM
  Re: Fastest Suzuki FA50? Hoping to hit 70mphRe: Blake MD No PM Plz Blake MD No PM Plz 01/28/18 12:04PM
  Re: Fastest Suzuki FA50? Hoping to hit 70mphRe: Ben Whittle Ben Whittle 01/28/18 12:06PM
  Re: Fastest Suzuki FA50? Hoping to hit 70mphRe: Ben Whittle Ben Whittle 01/28/18 04:13PM
  Re: Fastest Suzuki FA50? Hoping to hit 70mphRe: DrGeorgeTompson (Alan) DrGeorgeTompson (Alan) 01/28/18 04:21PM
  Re: Fastest Suzuki FA50? Hoping to hit 70mphRe: Dave Steele Dave Steele 01/28/18 01:07PM
  Re: Fastest Suzuki FA50? Hoping to hit 70mphRe: P D P D 01/28/18 01:15PM
  Re: Fastest Suzuki FA50? Hoping to hit 70mphRe: Probably Fred Probably Fred 01/28/18 02:10PM
  Re: Fastest Suzuki FA50? Hoping to hit 70mphRe: michael riggs michael riggs 01/28/18 02:49PM
  Re: Fastest Suzuki FA50? Hoping to hit 70mphRe: P D P D 01/28/18 03:46PM
  Re: Fastest Suzuki FA50? Hoping to hit 70mphRe: jayson sumpter jayson sumpter 01/28/18 10:13PM
  Re: Fastest Suzuki FA50? Hoping to hit 70mphRe: Graham Motzing Graham Motzing 01/28/18 11:11PM
  Re: Fastest Suzuki FA50? Hoping to hit 70mphRe: Dave & Bummerzz Dave & Bummerzz 01/29/18 09:29AM
  Re: Fastest Suzuki FA50? Hoping to hit 70mphRe: jayson sumpter jayson sumpter 01/29/18 02:14PM
  Re: Fastest Suzuki FA50? Hoping to hit 70mphRe: «tyler » «tyler » 01/30/18 06:04PM
  Re: Fastest Suzuki FA50? Hoping to hit 70mphRe: P D P D 01/30/18 06:40PM
  Re: Fastest Suzuki FA50? Hoping to hit 70mphRe: LSLB RXb LSLB RXb 01/29/18 12:39AM
  Re: Fastest Suzuki FA50? Hoping to hit 70mphRe: Mikey Antonakakis Mikey Antonakakis 01/29/18 11:43AM
  Re: Fastest Suzuki FA50? Hoping to hit 70mphRe: Dave & Bummerzz Dave & Bummerzz 01/29/18 12:53PM
  Re: Fastest Suzuki FA50? Hoping to hit 70mphRe: Graham Motzing Graham Motzing 01/29/18 01:10PM
  Re: Fastest Suzuki FA50? Hoping to hit 70mphRe: Doug Wilhelm Doug Wilhelm 01/29/18 01:15PM
  Re: Fastest Suzuki FA50? Hoping to hit 70mphRe: alex . alex . 01/30/18 12:34AM
  Re: Fastest Suzuki FA50? Hoping to hit 70mphRe: Derek Stahl Derek Stahl 01/30/18 01:01AM
  Re: Fastest Suzuki FA50? Hoping to hit 70mphRe: Ty 🏍 Ty 🏍 01/30/18 04:42PM
  Re: Fastest Suzuki FA50? Hoping to hit 70mphRe: Ike Pipe Ike Pipe 01/31/18 07:40AM
  Re: Fastest Suzuki FA50? Hoping to hit 70mphRe: Derek Stahl Derek Stahl 01/31/18 10:55AM
  Re: Fastest Suzuki FA50? Hoping to hit 70mphRe: Born to be WillD Born to be WillD 01/31/18 12:02PM
  Re: Fastest Suzuki FA50? Hoping to hit 70mphRe: Born to be WillD Born to be WillD 01/30/18 03:37PM
  Re: Fastest Suzuki FA50? Hoping to hit 70mphRe: Graham Motzing Graham Motzing 01/31/18 11:06AM
  Re: Fastest Suzuki FA50? Hoping to hit 70mphRe: Born to be WillD Born to be WillD 01/31/18 09:36AM
  Re: Fastest Suzuki FA50? Hoping to hit 70mphRe: Brent Saxsma Brent Saxsma 02/03/18 06:33PM
  Re: Fastest Suzuki FA50? Hoping to hit 70mphRe: Mikey Antonakakis Mikey Antonakakis 02/03/18 07:16PM
  Re: Fastest Suzuki FA50? Hoping to hit 70mphRe: Mikey Antonakakis Mikey Antonakakis 02/03/18 07:17PM
  Re: Fastest Suzuki FA50? Hoping to hit 70mphRe: Brent Saxsma Brent Saxsma 02/06/18 06:11PM
  Re: Fastest Suzuki FA50? Hoping to hit 70mphRe: Thomas TPRF Thomas TPRF 02/04/18 04:33PM
  Re: Fastest Suzuki FA50? Hoping to hit 70mphRe: Uncle Benito Upjet Uncle Benito Upjet 02/05/18 04:28PM
  Re: Fastest Suzuki FA50? Hoping to hit 70mphRe: Douglas Binder Douglas Binder 02/06/18 02:32PM
  Re: Fastest Suzuki FA50? Hoping to hit 70mphRe: Brent Saxsma Brent Saxsma 02/06/18 05:45PM
  Re: Fastest Suzuki FA50? Hoping to hit 70mphRe: «tyler » «tyler » 02/07/18 03:43PM
  Re: Fastest Suzuki FA50? Hoping to hit 70mphRe: Brent Saxsma Brent Saxsma 02/07/18 04:41PM
  Re: Fastest Suzuki FA50? Hoping to hit 70mphRe: EH FCC of the QCB EH FCC of the QCB 02/07/18 07:10PM
  Re: Fastest Suzuki FA50? Hoping to hit 70mphRe: Brent Saxsma Brent Saxsma 02/08/18 12:32AM
  Re: Fastest Suzuki FA50? Hoping to hit 70mphRe: alex . alex . 02/08/18 01:02AM
  Re: Fastest Suzuki FA50? Hoping to hit 70mphRe: EH FCC of the QCB EH FCC of the QCB 02/08/18 06:38AM
  Re: Fastest Suzuki FA50? Hoping to hit 70mphRe: Born to be WillD Born to be WillD 02/08/18 02:10PM
  Re: Fastest Suzuki FA50? Hoping to hit 70mphRe: EH FCC of the QCB EH FCC of the QCB 02/08/18 02:52PM
  Re: Fastest Suzuki FA50? Hoping to hit 70mphRe: Mikey Antonakakis Mikey Antonakakis 02/08/18 08:15PM
  Re: Fastest Suzuki FA50? Hoping to hit 70mphRe: Lou MAGNETO Lou MAGNETO 02/21/18 04:22PM
  Re: Fastest Suzuki FA50? Hoping to hit 70mphRe: - Joe - - Joe - 02/22/18 11:42AM
  Re: Fastest Suzuki FA50? Hoping to hit 70mphRe: Brent Saxsma Brent Saxsma 02/06/18 05:51PM
  Re: Fastest Suzuki FA50? Hoping to hit 70mphRe: Mikey Antonakakis Mikey Antonakakis 02/06/18 06:16PM
  Re: Fastest Suzuki FA50? Hoping to hit 70mphRe: Brent Saxsma Brent Saxsma 02/06/18 06:43PM
  Re: Fastest Suzuki FA50? Hoping to hit 70mphRe: Mikey Antonakakis Mikey Antonakakis 02/06/18 06:47PM
  Re: Fastest Suzuki FA50? Hoping to hit 70mphRe: Brent Saxsma Brent Saxsma 02/06/18 06:59PM
  Re: Fastest Suzuki FA50? Hoping to hit 70mphRe: Mikey Antonakakis Mikey Antonakakis 02/06/18 07:02PM
  Re: Fastest Suzuki FA50? Hoping to hit 70mphRe: Brent Saxsma Brent Saxsma 02/06/18 07:06PM
  Re: Fastest Suzuki FA50? Hoping to hit 70mphRe: Mikey Antonakakis Mikey Antonakakis 02/06/18 07:26PM
  Re: Fastest Suzuki FA50? Hoping to hit 70mphRe: Russell Huddy Russell Huddy 02/06/18 07:43PM
  Re: Fastest Suzuki FA50? Hoping to hit 70mphRe: Brent Saxsma Brent Saxsma 02/06/18 08:13PM
  Re: Fastest Suzuki FA50? Hoping to hit 70mphRe: Mikey Antonakakis Mikey Antonakakis 02/06/18 08:27PM
  Re: Fastest Suzuki FA50? Hoping to hit 70mphRe: Brent Saxsma Brent Saxsma 02/06/18 09:17PM
  Re: Fastest Suzuki FA50? Hoping to hit 70mphRe: Mikey Antonakakis Mikey Antonakakis 02/06/18 09:43PM
  Re: Fastest Suzuki FA50? Hoping to hit 70mphRe: Mikey Antonakakis Mikey Antonakakis 02/06/18 09:50PM
  Re: Fastest Suzuki FA50? Hoping to hit 70mphRe: Brent Saxsma Brent Saxsma 02/06/18 11:03PM
  Re: Fastest Suzuki FA50? Hoping to hit 70mphRe: Brent Saxsma Brent Saxsma 02/06/18 11:00PM
  Re: Fastest Suzuki FA50? Hoping to hit 70mphRe: Brent Saxsma Brent Saxsma 02/06/18 07:59PM
  Re: Fastest Suzuki FA50? Hoping to hit 70mphRe: Mikey Antonakakis Mikey Antonakakis 02/06/18 08:26PM
  Re: Fastest Suzuki FA50? Hoping to hit 70mphRe: Mikey Antonakakis Mikey Antonakakis 02/06/18 06:55PM
  Re: Fastest Suzuki FA50? Hoping to hit 70mphRe: Brent Saxsma Brent Saxsma 02/06/18 07:08PM
  Re: Fastest Suzuki FA50? Hoping to hit 70mphRe: jayson sumpter jayson sumpter 02/06/18 10:07PM
  Re: Fastest Suzuki FA50? Hoping to hit 70mphRe: Mikey Antonakakis Mikey Antonakakis 02/06/18 10:38PM
  Re: Fastest Suzuki FA50? Hoping to hit 70mphRe: jayson sumpter jayson sumpter 02/07/18 08:22AM
  Re: Fastest Suzuki FA50? Hoping to hit 70mphRe: Brent Saxsma Brent Saxsma 02/07/18 12:39PM
  Re: Fastest Suzuki FA50? Hoping to hit 70mphRe: jayson sumpter jayson sumpter 02/07/18 12:46PM
  Re: Fastest Suzuki FA50? Hoping to hit 70mphRe: Brent Saxsma Brent Saxsma 02/07/18 01:36PM
  Re: Fastest Suzuki FA50? Hoping to hit 70mphRe: Brent Saxsma Brent Saxsma 02/06/18 11:04PM
  Re: Fastest Suzuki FA50? Hoping to hit 70mphRe: Graham Motzing Graham Motzing 02/07/18 03:22PM
  Re: Fastest Suzuki FA50? Hoping to hit 70mphRe: DrGeorgeTompson (Alan) DrGeorgeTompson (Alan) 02/07/18 03:28PM
  Re: Fastest Suzuki FA50? Hoping to hit 70mphRe: Dave & Bummerzz Dave & Bummerzz 02/07/18 04:37PM
  Re: Fastest Suzuki FA50? Hoping to hit 70mphRe: Brent Saxsma Brent Saxsma 02/07/18 04:44PM
  Re: Fastest Suzuki FA50? Hoping to hit 70mphRe: Dave & Bummerzz Dave & Bummerzz 02/07/18 04:46PM
  Re: Fastest Suzuki FA50? Hoping to hit 70mphRe: Dave & Bummerzz Dave & Bummerzz 02/07/18 04:56PM
  Re: Fastest Suzuki FA50? Hoping to hit 70mphRe: DrGeorgeTompson (Alan) DrGeorgeTompson (Alan) 02/07/18 05:09PM
  Re: Fastest Suzuki FA50? Hoping to hit 70mphRe: Brent Saxsma Brent Saxsma 02/07/18 04:37PM
  Re: Fastest Suzuki FA50? Hoping to hit 70mphRe: Kim Jong illest Kim Jong illest 02/08/18 06:23AM
  Re: Fastest Suzuki FA50? Hoping to hit 70mphRe: jayson sumpter jayson sumpter 02/08/18 09:26AM
  Re: Fastest Suzuki FA50? Hoping to hit 70mphRe: Dave & Bummerzz Dave & Bummerzz 02/08/18 10:06AM
  Re: Fastest Suzuki FA50? Hoping to hit 70mphRe: Graham Motzing Graham Motzing 02/08/18 10:37AM
  Re: Fastest Suzuki FA50? Hoping to hit 70mphRe: Mikey Antonakakis Mikey Antonakakis 02/08/18 12:26PM
  Re: Fastest Suzuki FA50? Hoping to hit 70mphRe: Douglas Binder Douglas Binder 02/08/18 12:40PM
  Re: Fastest Suzuki FA50? Hoping to hit 70mphRe: EH FCC of the QCB EH FCC of the QCB 02/08/18 01:00PM
  Re: Fastest Suzuki FA50? Hoping to hit 70mphRe: Born to be WillD Born to be WillD 02/08/18 02:03PM
  Re: Fastest Suzuki FA50? Hoping to hit 70mphRe: Nick / Ratbone Nick / Ratbone 02/09/18 09:43AM
  Re: Fastest Suzuki FA50? Hoping to hit 70mphRe: jayson sumpter jayson sumpter 02/14/18 08:58AM
  Re: Fastest Suzuki FA50? Hoping to hit 70mphRe: Born to be WillD Born to be WillD 02/14/18 04:59PM
  Re: Fastest Suzuki FA50? Hoping to hit 70mphRe: Marc Friedman Marc Friedman 02/14/18 05:01PM
  Re: Fastest Suzuki FA50? Hoping to hit 70mphRe: P D P D 02/14/18 05:21PM
  Re: Fastest Suzuki FA50? Hoping to hit 70mphRe: Born to be WillD Born to be WillD 02/22/18 01:13PM
  Re: Fastest Suzuki FA50? Hoping to hit 70mphRe: Lou MAGNETO Lou MAGNETO 02/22/18 01:34PM
  Re: Fastest Suzuki FA50? Hoping to hit 70mphRe: Derek Cox Derek Cox 02/22/18 01:57PM
  Re: Fastest Suzuki FA50? Hoping to hit 70mphRe: DrGeorgeTompson (Alan) DrGeorgeTompson (Alan) 02/23/18 09:25AM
  Re: Fastest Suzuki FA50? Hoping to hit 70mphRe: Marc Friedman Marc Friedman 02/14/18 04:38PM
  Re: Fastest Suzuki FA50? Hoping to hit 70mphRe: Brent Saxsma Brent Saxsma 06/12/18 02:35PM
  Re: Fastest Suzuki FA50? Hoping to hit 70mphRe: Born to be WillD Born to be WillD 06/14/18 10:55AM
  Re: Fastest Suzuki FA50? Hoping to hit 70mphRe: Derek Cox Derek Cox 06/14/18 11:22AM
  Re: Fastest Suzuki FA50? Hoping to hit 70mphRe: Brent Saxsma Brent Saxsma 06/14/18 07:05PM
  Re: Fastest Suzuki FA50? Hoping to hit 70mphRe: David Cox David Cox 06/14/18 06:06PM
  Re: Fastest Suzuki FA50? Hoping to hit 70mphRe: Brent Saxsma Brent Saxsma 06/14/18 07:28PM
  Re: Fastest Suzuki FA50? Hoping to hit 70mphRe: P D P D 06/14/18 07:30PM
  Re: Fastest Suzuki FA50? Hoping to hit 70mphRe: Brent Saxsma Brent Saxsma 06/14/18 07:31PM
  Re: Fastest Suzuki FA50? Hoping to hit 70mphRe: P D P D 06/14/18 08:32PM
  Re: Fastest Suzuki FA50? Hoping to hit 70mphRe: Brent Saxsma Brent Saxsma 06/15/18 01:46AM
  Re: Fastest Suzuki FA50? Hoping to hit 70mphRe: David Cox David Cox 06/15/18 05:44AM
  Re: Fastest Suzuki FA50? Hoping to hit 70mphRe: EH FCC of the QCB EH FCC of the QCB 06/15/18 10:17AM
  Re: Fastest Suzuki FA50? Hoping to hit 70mphRe: Brent Saxsma Brent Saxsma 06/14/18 07:02PM
  Re: Fastest Suzuki FA50? Hoping to hit 70mphRe: Ryan . Ryan . 06/14/18 12:01PM
  Re: Fastest Suzuki FA50? Hoping to hit 70mphRe: Brent Saxsma Brent Saxsma 06/14/18 07:25PM
  Re: Fastest Suzuki FA50? Hoping to hit 70mphRe: ***VANILLA BLUNDER*** ***VANILLA BLUNDER*** 06/13/18 07:15PM
  Re: Fastest Suzuki FA50? Hoping to hit 70mphRe: Brent Saxsma Brent Saxsma 06/14/18 12:21AM
  Re: Fastest Suzuki FA50? Hoping to hit 70mphRe: scrot rash scrot rash 06/15/18 07:42PM
  Re: Fastest Suzuki FA50? Hoping to hit 70mphRe: scrot rash scrot rash 06/15/18 07:59PM
  Re: Fastest Suzuki FA50? Hoping to hit 70mphRe: scrot rash scrot rash 06/15/18 09:13PM
  Re: Fastest Suzuki FA50? Hoping to hit 70mphRe: Dirty30 Dillon Dirty30 Dillon 06/14/18 11:57AM
  Re: Fastest Suzuki FA50? Hoping to hit 70mphRe: Brent Saxsma Brent Saxsma 06/14/18 07:23PM
  Re: Fastest Suzuki FA50? Hoping to hit 70mphRe: Dirty30 Dillon Dirty30 Dillon 06/15/18 09:06AM
  Re: Fastest Suzuki FA50? Hoping to hit 70mphRe: Brent Saxsma Brent Saxsma 06/15/18 09:05PM
  Re: Fastest Suzuki FA50? Hoping to hit 70mphRe: scrot rash scrot rash 06/16/18 08:43AM
  Re: Fastest Suzuki FA50? Hoping to hit 70mphRe: Brent Saxsma Brent Saxsma 06/16/18 03:30PM
  Re: Fastest Suzuki FA50? Hoping to hit 70mphRe: scrot rash scrot rash 06/16/18 11:30PM
  Re: Fastest Suzuki FA50? Hoping to hit 70mphRe: scrot rash scrot rash 06/17/18 09:40AM
  Re: Fastest Suzuki FA50? Hoping to hit 70mphRe: Dave & Bummerzz Dave & Bummerzz 06/15/18 02:48PM
  Re: Fastest Suzuki FA50? Hoping to hit 70mphRe: Brent Saxsma Brent Saxsma 06/15/18 09:00PM
  Re: Fastest Suzuki FA50? Hoping to hit 70mphRe: Brent Saxsma Brent Saxsma 06/16/18 08:48PM
  Re: Fastest Suzuki FA50? Hoping to hit 70mphRe: Brent Saxsma Brent Saxsma 06/17/18 04:50PM
  Re: Fastest Suzuki FA50? Hoping to hit 70mphRe: Brent Saxsma Brent Saxsma 06/18/18 07:55PM
  Re: Fastest Suzuki FA50? Hoping to hit 70mphRe: scrot rash scrot rash 06/19/18 02:43PM
  Re: Fastest Suzuki FA50? Hoping to hit 70mphRe: Brent Saxsma Brent Saxsma 06/20/18 04:40PM
  Re: Fastest Suzuki FA50? Hoping to hit 70mphRe: Totally normal JBOT Totally normal JBOT 08/19/18 05:07PM
  Re: Fastest Suzuki FA50? Hoping to hit 70mphRe: Brent Saxsma Brent Saxsma 08/19/18 05:26PM
  Re: Fastest Suzuki FA50? Hoping to hit 70mphRe: Totally normal JBOT Totally normal JBOT 08/19/18 08:00PM
  Re: Fastest Suzuki FA50? Hoping to hit 70mphRe: Brent Saxsma Brent Saxsma 08/19/18 10:51PM
  Re: Fastest Suzuki FA50? Hoping to hit 70mphRe: Totally normal JBOT Totally normal JBOT 08/19/18 10:53PM
  Re: Fastest Suzuki FA50? Hoping to hit 70mphRe: Brent Saxsma Brent Saxsma 08/19/18 11:05PM
  Re: Fastest Suzuki FA50? Hoping to hit 70mphRe: Marc Friedman Marc Friedman 08/20/18 08:56AM
  Re: Fastest Suzuki FA50? Hoping to hit 70mphRe: Barn Fresh Barn Fresh 08/20/18 10:17PM
  Re: Fastest Suzuki FA50? Hoping to hit 70mphRe: jayson sumpter jayson sumpter 08/21/18 08:37AM
  Re: Fastest Suzuki FA50? Hoping to hit 70mphRe: Brent Saxsma Brent Saxsma 08/21/18 08:41AM
  Re: Fastest Suzuki FA50? Hoping to hit 70mphRe: Totally normal JBOT Totally normal JBOT 08/19/18 08:18PM
  Re: Fastest Suzuki FA50? Hoping to hit 70mphRe: Brent Saxsma Brent Saxsma 08/19/18 10:59PM
  Re: Fastest Suzuki FA50? Hoping to hit 70mphRe: Totally normal JBOT Totally normal JBOT 08/19/18 11:29PM
  Re: Fastest Suzuki FA50? Hoping to hit 70mphRe: Totally normal JBOT Totally normal JBOT 08/19/18 11:32PM
  Re: Fastest Suzuki FA50? Hoping to hit 70mphRe: Brent Saxsma Brent Saxsma 08/20/18 11:44AM
  Re: Fastest Suzuki FA50? Hoping to hit 70mphRe: Totally normal JBOT Totally normal JBOT 08/20/18 12:30PM
  Re: Fastest Suzuki FA50? Hoping to hit 70mphRe: Totally normal JBOT Totally normal JBOT 08/20/18 12:35PM
  Re: Fastest Suzuki FA50? Hoping to hit 70mphRe: Brent Saxsma Brent Saxsma 08/20/18 03:31PM
  Re: Fastest Suzuki FA50? Hoping to hit 70mphRe: Dirty30 Dillon Dirty30 Dillon 08/21/18 09:25AM
  Re: Fastest Suzuki FA50? Hoping to hit 70mphRe: Brent Saxsma Brent Saxsma 08/21/18 12:26PM
  Re: Fastest Suzuki FA50? Hoping to hit 70mphRe: Dirty30 Dillon Dirty30 Dillon 08/21/18 04:05PM
  Re: Fastest Suzuki FA50? Hoping to hit 70mphRe: live ɘvil live ɘvil 08/21/18 05:02PM
  Re: Fastest Suzuki FA50? Hoping to hit 70mphRe: Dirty30 Dillon Dirty30 Dillon 08/22/18 08:55AM
  Re: Fastest Suzuki FA50? Hoping to hit 70mphRe: Brandon Weiss (Detective brandon to you) Brandon Weiss (Detective brandon to you) 08/22/18 09:42AM
  Re: Fastest Suzuki FA50? Hoping to hit 70mphRe: Brent Saxsma Brent Saxsma 08/22/18 05:20PM
  Re: Fastest Suzuki FA50? Hoping to hit 70mphRe: D L D L 08/22/18 05:29PM
  Re: Fastest Suzuki FA50? Hoping to hit 70mphRe: Brent Saxsma Brent Saxsma 08/22/18 05:31PM
  Re: Fastest Suzuki FA50? Hoping to hit 70mphRe: Brent Saxsma Brent Saxsma 08/22/18 05:19PM
  Re: Fastest Suzuki FA50? Hoping to hit 70mphRe: alex . alex . 08/21/18 12:13PM
  Re: Fastest Suzuki FA50? Hoping to hit 70mphRe: Brent Saxsma Brent Saxsma 08/21/18 12:24PM
  Re: Fastest Suzuki FA50? Hoping to hit 70mphRe: Totally normal JBOT Totally normal JBOT 08/21/18 03:17PM
  Re: Fastest Suzuki FA50? Hoping to hit 70mphRe: live ɘvil live ɘvil 08/21/18 10:15PM
  Re: Fastest Suzuki FA50? Hoping to hit 70mphRe: Jacob Westphal Jacob Westphal 06/18/18 09:52PM
  Re: Fastest Suzuki FA50? Hoping to hit 70mphRe: Brent Saxsma Brent Saxsma 06/27/18 01:06PM
  Re: Fastest Suzuki FA50? Hoping to hit 70mphRe: Brent Saxsma Brent Saxsma 06/27/18 01:09PM
  Re: Fastest Suzuki FA50? Hoping to hit 70mphRe: Brent Saxsma Brent Saxsma 06/27/18 01:15PM
  Re: Fastest Suzuki FA50? Hoping to hit 70mphRe: Brent Saxsma Brent Saxsma 06/27/18 01:20PM
  Re: Fastest Suzuki FA50? Hoping to hit 70mphRe: Brent Saxsma Brent Saxsma 06/27/18 01:23PM
  Re: Fastest Suzuki FA50? Hoping to hit 70mphRe: Brent Saxsma Brent Saxsma 07/18/18 01:58PM
  Re: Fastest Suzuki FA50? Hoping to hit 70mphRe: Dirty30 Dillon Dirty30 Dillon 07/18/18 04:47PM
  Re: Fastest Suzuki FA50? Hoping to hit 70mphRe: DrGeorgeTompson (Alan) DrGeorgeTompson (Alan) 07/18/18 04:59PM
  Re: Fastest Suzuki FA50? Hoping to hit 70mphRe: alex ganz alex ganz 07/18/18 11:07PM
  Re: Fastest Suzuki FA50? Hoping to hit 70mphRe: Brent Saxsma Brent Saxsma 07/21/18 11:48AM
  Re: Fastest Suzuki FA50? Hoping to hit 70mphRe: Dirty30 Dillon Dirty30 Dillon 07/23/18 10:23AM
  Re: Fastest Suzuki FA50? Hoping to hit 70mphRe: Brent Saxsma Brent Saxsma 07/24/18 11:31AM
  Re: Fastest Suzuki FA50? Hoping to hit 70mphRe: Brent Saxsma Brent Saxsma 07/21/18 11:50AM
  Re: Fastest Suzuki FA50? Hoping to hit 70mphRe: Brent Saxsma Brent Saxsma 07/31/18 09:24PM
  Re: Fastest Suzuki FA50? Hoping to hit 70mphRe: Ty 🏍 Ty 🏍 08/06/18 06:43PM
  Re: Fastest Suzuki FA50? Hoping to hit 70mphRe: EH FCC of the QCB EH FCC of the QCB 08/06/18 10:52PM
  Re: Fastest Suzuki FA50? Hoping to hit 70mphRe: Ty 🏍 Ty 🏍 08/07/18 06:35PM
  Re: Fastest Suzuki FA50? Hoping to hit 70mphRe: EH FCC of the QCB EH FCC of the QCB 08/07/18 11:29PM
  Re: Fastest Suzuki FA50? Hoping to hit 70mphRe: Dirty30 Dillon Dirty30 Dillon 08/08/18 12:08PM
  Re: Fastest Suzuki FA50? Hoping to hit 70mphRe: Dave & Bummerzz Dave & Bummerzz 08/13/18 09:23AM
  Re: Fastest Suzuki FA50? Hoping to hit 70mphRe: live ɘvil live ɘvil 08/13/18 03:11PM
  Re: Fastest Suzuki FA50? Hoping to hit 70mphRe: Jesse Stephenson Jesse Stephenson 08/13/18 09:01PM
  Re: Fastest Suzuki FA50? Hoping to hit 70mphRe: live ɘvil live ɘvil 08/15/18 07:47PM
  Re: Fastest Suzuki FA50? Hoping to hit 70mphRe: matt brann matt brann 08/14/18 10:59PM
  Re: Fastest Suzuki FA50? Hoping to hit 70mphRe: Alex hernandez Alex hernandez 08/15/18 04:10PM
  Re: Fastest Suzuki FA50? Hoping to hit 70mphRe: Adam Strait Adam Strait 08/15/18 11:17PM
  Re: Fastest Suzuki FA50? Hoping to hit 70mphRe: Brent Saxsma Brent Saxsma 08/17/18 09:11AM
  Re: Fastest Suzuki FA50? Hoping to hit 70mphRe: Douglas Binder Douglas Binder 08/17/18 09:39AM
  Re: Fastest Suzuki FA50? Hoping to hit 70mphRe: Brent Saxsma Brent Saxsma 08/17/18 11:40AM
  Re: Fastest Suzuki FA50? Hoping to hit 70mphRe: Douglas Binder Douglas Binder 08/17/18 11:46AM
  Re: Fastest Suzuki FA50? Hoping to hit 70mphRe: Dave & Bummerzz Dave & Bummerzz 08/17/18 12:17PM
  Re: Fastest Suzuki FA50? Hoping to hit 70mphRe: Dirty30 Dillon Dirty30 Dillon 08/17/18 01:07PM
  Re: Fastest Suzuki FA50? Hoping to hit 70mphRe: Brent Saxsma Brent Saxsma 08/19/18 04:53PM
  Re: Fastest Suzuki FA50? Hoping to hit 70mphRe: EH FCC of the QCB EH FCC of the QCB 08/17/18 05:41PM
  Re: Fastest Suzuki FA50? Hoping to hit 70mphRe: Dirty30 Dillon Dirty30 Dillon 08/17/18 10:09AM
  Re: Fastest Suzuki FA50? Hoping to hit 70mphRe: Jesse Stephenson Jesse Stephenson 08/18/18 03:18AM
  Re: Fastest Suzuki FA50? Hoping to hit 70mphRe: live ɘvil live ɘvil 08/18/18 03:52AM
  Re: Fastest Suzuki FA50? Hoping to hit 70mphRe: Ben Whittle Ben Whittle 08/18/18 06:25PM
  Re: Fastest Suzuki FA50? Hoping to hit 70mphRe: P D P D 08/18/18 06:35PM
  Re: Fastest Suzuki FA50? Hoping to hit 70mphRe: Joe Schuitema Joe Schuitema 08/17/18 05:41PM
  Re: Fastest Suzuki FA50? Hoping to hit 70mphRe: Douglas Binder Douglas Binder 08/17/18 05:57PM
  Re: Fastest Suzuki FA50? Hoping to hit 70mphRe: jayson sumpter jayson sumpter 08/19/18 05:39PM
  Re: Fastest Suzuki FA50? Hoping to hit 70mphRe: Brent Saxsma Brent Saxsma 08/18/18 06:21PM
  Re: Fastest Suzuki FA50? Hoping to hit 70mphRe: EH FCC of the QCB EH FCC of the QCB 08/18/18 08:46PM
  Re: Fastest Suzuki FA50? Hoping to hit 70mphRe: Brent Saxsma Brent Saxsma 08/18/18 09:25PM
  Re: Fastest Suzuki FA50? Hoping to hit 70mphRe: Marc Friedman Marc Friedman 08/18/18 11:01PM
  Re: Fastest Suzuki FA50? Hoping to hit 70mphRe: Barn Fresh Barn Fresh 08/19/18 05:54PM
  Re: Fastest Suzuki FA50? Hoping to hit 70mphRe: Brent Saxsma Brent Saxsma 08/19/18 11:32PM
  Re: Fastest Suzuki FA50? Hoping to hit 70mphRe: Totally normal JBOT Totally normal JBOT 08/19/18 11:36PM
  Re: Fastest Suzuki FA50? Hoping to hit 70mphRe: Totally normal JBOT Totally normal JBOT 08/19/18 11:39PM
  Re: Fastest Suzuki FA50? Hoping to hit 70mphRe: Brent Saxsma Brent Saxsma 08/20/18 12:40AM
  Re: Fastest Suzuki FA50? Hoping to hit 70mphRe: Brent Saxsma Brent Saxsma 08/20/18 01:48PM
  Re: Fastest Suzuki FA50? Hoping to hit 70mphRe: Brent Saxsma Brent Saxsma 08/19/18 11:38PM
  Re: Fastest Suzuki FA50? Hoping to hit 70mphRe: Totally normal JBOT Totally normal JBOT 08/19/18 11:42PM
  Re: Fastest Suzuki FA50? Hoping to hit 70mphRe: Totally normal JBOT Totally normal JBOT 08/19/18 11:49PM
  Re: Fastest Suzuki FA50? Hoping to hit 70mphRe: Totally normal JBOT Totally normal JBOT 08/19/18 11:57PM
  Re: Fastest Suzuki FA50? Hoping to hit 70mphRe: Brent Saxsma Brent Saxsma 08/20/18 12:15AM
  Re: Fastest Suzuki FA50? Hoping to hit 70mphRe: Totally normal JBOT Totally normal JBOT 08/20/18 12:19AM
  Re: Fastest Suzuki FA50? Hoping to hit 70mphRe: Brent Saxsma Brent Saxsma 08/20/18 12:20AM
  Re: Fastest Suzuki FA50? Hoping to hit 70mphRe: Totally normal JBOT Totally normal JBOT 08/20/18 12:29AM
  Re: Fastest Suzuki FA50? Hoping to hit 70mphRe: Brent Saxsma Brent Saxsma 08/20/18 12:19AM
  Re: Fastest Suzuki FA50? Hoping to hit 70mphRe: Brent Saxsma Brent Saxsma 08/20/18 12:35AM
  Re: Fastest Suzuki FA50? Hoping to hit 70mphRe: Brent Saxsma Brent Saxsma 08/20/18 01:36AM
  Re: Fastest Suzuki FA50? Hoping to hit 70mphRe: Totally normal JBOT Totally normal JBOT 08/20/18 12:29PM
  Re: Fastest Suzuki FA50? Hoping to hit 70mphRe: Brent Saxsma Brent Saxsma 08/20/18 02:23PM
  Re: Fastest Suzuki FA50? Hoping to hit 70mphRe: Dirty30 Dillon Dirty30 Dillon 08/20/18 03:06AM
  Re: Fastest Suzuki FA50? Hoping to hit 70mphRe: Brent Saxsma Brent Saxsma 08/20/18 10:58AM
  Re: Fastest Suzuki FA50? Hoping to hit 70mphRe: jayson sumpter jayson sumpter 08/20/18 11:09AM
  Re: Fastest Suzuki FA50? Hoping to hit 70mphRe: Dirty30 Dillon Dirty30 Dillon 08/20/18 12:06PM
  Re: Fastest Suzuki FA50? Hoping to hit 70mphRe: Brent Saxsma Brent Saxsma 08/20/18 02:29PM
  Re: Fastest Suzuki FA50? Hoping to hit 70mphRe: Dave & Bummerzz Dave & Bummerzz 08/20/18 01:59PM
  Re: Fastest Suzuki FA50? Hoping to hit 70mphRe: Brent Saxsma Brent Saxsma 08/20/18 02:18PM
  Re: Fastest Suzuki FA50? Hoping to hit 70mphRe: Dave & Bummerzz Dave & Bummerzz 08/20/18 03:30PM
  Re: Fastest Suzuki FA50? Hoping to hit 70mphRe: Brent Saxsma Brent Saxsma 08/20/18 03:39PM
  Re: Fastest Suzuki FA50? Hoping to hit 70mphRe: jayson sumpter jayson sumpter 08/20/18 03:54PM
  Re: Fastest Suzuki FA50? Hoping to hit 70mphRe: Marc Friedman Marc Friedman 08/20/18 04:13PM
  Re: Fastest Suzuki FA50? Hoping to hit 70mphRe: live ɘvil live ɘvil 08/21/18 12:51AM
  Re: Fastest Suzuki FA50? Hoping to hit 70mphRe: Brent Saxsma Brent Saxsma 08/21/18 03:48AM
  Re: Fastest Suzuki FA50? Hoping to hit 70mphRe: Brent Saxsma Brent Saxsma 08/20/18 08:07AM
  Re: Fastest Suzuki FA50? Hoping to hit 70mphRe: jayson sumpter jayson sumpter 08/20/18 08:30AM
  Re: Fastest Suzuki FA50? Hoping to hit 70mphRe: alex . alex . 08/20/18 11:04AM
  Re: Fastest Suzuki FA50? Hoping to hit 70mphRe: jayson sumpter jayson sumpter 08/20/18 02:24PM
  Re: Fastest Suzuki FA50? Hoping to hit 70mphRe: Brent Saxsma Brent Saxsma 08/20/18 02:32PM
  Re: Fastest Suzuki FA50? Hoping to hit 70mphRe: Brent Saxsma Brent Saxsma 08/20/18 04:37PM
  Re: Fastest Suzuki FA50? Hoping to hit 70mphRe: Alex hernandez Alex hernandez 08/20/18 11:20PM
  Re: Fastest Suzuki FA50? Hoping to hit 70mphRe: Barn Fresh Barn Fresh 08/21/18 12:48AM
  Re: Fastest Suzuki FA50? Hoping to hit 70mphRe: Max LGN Max LGN 08/21/18 07:44AM
  Re: Fastest Suzuki FA50? Hoping to hit 70mphRe: Brent Saxsma Brent Saxsma 08/21/18 08:35AM
  Re: Fastest Suzuki FA50? Hoping to hit 70mphRe: Brent Saxsma Brent Saxsma 08/21/18 01:25PM
  Re: Fastest Suzuki FA50? Hoping to hit 70mphRe: Brent Saxsma Brent Saxsma 08/21/18 07:46PM
  Re: Fastest Suzuki FA50? Hoping to hit 70mphRe: Totally normal JBOT Totally normal JBOT 08/21/18 08:16PM
  Re: Fastest Suzuki FA50? Hoping to hit 70mphRe: Totally normal JBOT Totally normal JBOT 08/21/18 08:19PM
  Re: Fastest Suzuki FA50? Hoping to hit 70mphRe: Brent Saxsma Brent Saxsma 08/21/18 10:38PM
  Re: Fastest Suzuki FA50? Hoping to hit 70mphRe: EH FCC of the QCB EH FCC of the QCB 08/21/18 11:10PM
  Re: Fastest Suzuki FA50? Hoping to hit 70mphRe: Brent Saxsma Brent Saxsma 08/22/18 02:33AM
  Re: Fastest Suzuki FA50? Hoping to hit 70mphRe: D L D L 08/21/18 07:52PM
  Re: Fastest Suzuki FA50? Hoping to hit 70mphRe: Brent Saxsma Brent Saxsma 08/21/18 10:36PM
  Re: Fastest Suzuki FA50? Hoping to hit 70mphRe: Totally normal JBOT Totally normal JBOT 08/21/18 10:52PM
  Re: Fastest Suzuki FA50? Hoping to hit 70mphRe: Brent Saxsma Brent Saxsma 08/22/18 02:32AM
  Re: Fastest Suzuki FA50? Hoping to hit 70mphRe: Totally normal JBOT Totally normal JBOT 08/22/18 02:42AM
  Re: Fastest Suzuki FA50? Hoping to hit 70mphRe: Totally normal JBOT Totally normal JBOT 08/22/18 02:58AM
  Re: Fastest Suzuki FA50? Hoping to hit 70mphRe: Brent Saxsma Brent Saxsma 08/22/18 06:40AM
  Re: Fastest Suzuki FA50? Hoping to hit 70mphRe: Chöschi21 C.K. Chöschi21 C.K. 08/22/18 07:11AM
  Re: Fastest Suzuki FA50? Hoping to hit 70mphRe: Brent Saxsma Brent Saxsma 08/22/18 05:18PM
  Re: Fastest Suzuki FA50? Hoping to hit 70mphRe: Barn Fresh Barn Fresh 08/22/18 09:30PM
  Re: Fastest Suzuki FA50? Hoping to hit 70mphRe: Totally normal JBOT Totally normal JBOT 08/22/18 09:35PM
  Re: Fastest Suzuki FA50? Hoping to hit 70mphRe: Totally normal JBOT Totally normal JBOT 08/22/18 10:52PM
  Re: Fastest Suzuki FA50? Hoping to hit 70mphRe: cheetahchrome . cheetahchrome . 08/23/18 12:18AM
  Re: Fastest Suzuki FA50? Hoping to hit 70mphRe: Totally normal JBOT Totally normal JBOT 08/23/18 12:20AM
  Re: Fastest Suzuki FA50? Hoping to hit 70mphRe: alex . alex . 08/23/18 12:22AM
  Re: Fastest Suzuki FA50? Hoping to hit 70mphRe: Totally normal JBOT Totally normal JBOT 08/23/18 12:28AM
  Re: Fastest Suzuki FA50? Hoping to hit 70mphRe: Totally normal JBOT Totally normal JBOT 08/23/18 12:32AM
  Re: Fastest Suzuki FA50? Hoping to hit 70mphRe: Totally normal JBOT Totally normal JBOT 08/23/18 12:49AM
  Re: Fastest Suzuki FA50? Hoping to hit 70mphRe: alex . alex . 08/23/18 12:56AM
  Re: Fastest Suzuki FA50? Hoping to hit 70mphRe: Totally normal JBOT Totally normal JBOT 08/23/18 12:59AM
  Re: Fastest Suzuki FA50? Hoping to hit 70mphRe: Chöschi21 C.K. Chöschi21 C.K. 08/23/18 07:04AM
  Re: Fastest Suzuki FA50? Hoping to hit 70mphRe: Brent Saxsma Brent Saxsma 08/23/18 07:33AM
  Re: Fastest Suzuki FA50? Hoping to hit 70mphRe: Barn Fresh Barn Fresh 08/23/18 08:49AM
  Re: Fastest Suzuki FA50? Hoping to hit 70mphRe: Douglas Binder Douglas Binder 08/23/18 09:17AM
  Re: Fastest Suzuki FA50? Hoping to hit 70mphRe: Born to be WillD Born to be WillD 08/22/18 02:47PM
  Re: Fastest Suzuki FA50? Hoping to hit 70mphRe: Marc Friedman Marc Friedman 08/22/18 03:25PM
  Re: Fastest Suzuki FA50? Hoping to hit 70mphRe: Brent Saxsma Brent Saxsma 08/22/18 05:27PM
  Re: Fastest Suzuki FA50? Hoping to hit 70mphRe: Born to be WillD Born to be WillD 08/22/18 03:04PM
  Re: Fastest Suzuki FA50? Hoping to hit 70mphRe: alex . alex . 08/22/18 03:49PM
  Re: Fastest Suzuki FA50? Hoping to hit 70mphRe: Born to be WillD Born to be WillD 08/22/18 05:05PM
  Re: Fastest Suzuki FA50? Hoping to hit 70mphRe: Brent Saxsma Brent Saxsma 08/22/18 05:37PM
  Re: Fastest Suzuki FA50? Hoping to hit 70mphRe: Totally normal JBOT Totally normal JBOT 08/22/18 05:52PM
  Re: Fastest Suzuki FA50? Hoping to hit 70mphRe: live ɘvil live ɘvil 08/22/18 05:54PM
  Re: Fastest Suzuki FA50? Hoping to hit 70mphRe: alex ganz alex ganz 08/22/18 07:15PM
  Re: Fastest Suzuki FA50? Hoping to hit 70mphRe: Jesse Stephenson Jesse Stephenson 08/22/18 08:13PM
  Re: Fastest Suzuki FA50? Hoping to hit 70mphRe: Brent Saxsma Brent Saxsma 08/23/18 01:02AM
  Re: Fastest Suzuki FA50? Hoping to hit 70mphRe: Totally normal JBOT Totally normal JBOT 08/23/18 01:28AM
  Re: Fastest Suzuki FA50? Hoping to hit 70mphRe: Brent Saxsma Brent Saxsma 08/23/18 01:12AM
  Re: Fastest Suzuki FA50? Hoping to hit 70mphRe: EH FCC of the QCB EH FCC of the QCB 08/23/18 06:45AM
  Re: Fastest Suzuki FA50? Hoping to hit 70mphRe: Brent Saxsma Brent Saxsma 08/23/18 07:31AM
  Re: Fastest Suzuki FA50? Hoping to hit 70mphRe: Dave & Bummerzz Dave & Bummerzz 08/23/18 09:32AM
  Re: Fastest Suzuki FA50? Hoping to hit 70mphRe: Brent Saxsma Brent Saxsma 08/23/18 09:37AM
  Re: Fastest Suzuki FA50? Hoping to hit 70mphRe: Chöschi21 C.K. Chöschi21 C.K. 08/23/18 01:08PM
  Re: Fastest Suzuki FA50? Hoping to hit 70mphRe: Barn Fresh Barn Fresh 08/23/18 02:06PM
  Re: Fastest Suzuki FA50? Hoping to hit 70mphRe: Born to be WillD Born to be WillD 08/23/18 10:42AM
  Re: Fastest Suzuki FA50? Hoping to hit 70mphRe: alex . alex . 08/23/18 10:50AM
  Re: Fastest Suzuki FA50? Hoping to hit 70mphRe: jayson sumpter jayson sumpter 08/23/18 10:51AM
  Re: Fastest Suzuki FA50? Hoping to hit 70mphRe: Brent Saxsma Brent Saxsma 08/23/18 11:17AM
  Re: Fastest Suzuki FA50? Hoping to hit 70mphRe: DrGeorgeTompson (Alan) DrGeorgeTompson (Alan) 08/23/18 10:52AM
  Re: Fastest Suzuki FA50? Hoping to hit 70mphRe: Brandon Weiss (Detective brandon to you) Brandon Weiss (Detective brandon to you) 08/23/18 10:53AM
  Re: Fastest Suzuki FA50? Hoping to hit 70mphRe: Totally normal JBOT Totally normal JBOT 08/23/18 12:40PM
  Re: Fastest Suzuki FA50? Hoping to hit 70mphRe: Barn Fresh Barn Fresh 08/23/18 01:49PM
  Re: Fastest Suzuki FA50? Hoping to hit 70mphRe: Brent Saxsma Brent Saxsma 08/23/18 09:14PM
  Re: Fastest Suzuki FA50? Hoping to hit 70mphRe: Totally normal JBOT Totally normal JBOT 08/23/18 10:24PM
  Re: Fastest Suzuki FA50? Hoping to hit 70mphRe: live ɘvil live ɘvil 08/23/18 11:36PM
  Re: Fastest Suzuki FA50? Hoping to hit 70mphRe: Totally normal JBOT Totally normal JBOT 08/24/18 01:21AM
  Re: Fastest Suzuki FA50? Hoping to hit 70mphRe: Born to be WillD Born to be WillD 08/23/18 10:36PM
  Re: Fastest Suzuki FA50? Hoping to hit 70mphRe: Born to be WillD Born to be WillD 08/23/18 10:41PM
  Re: Fastest Suzuki FA50? Hoping to hit 70mphRe: Brent Saxsma Brent Saxsma 08/23/18 10:43PM
  Re: Fastest Suzuki FA50? Hoping to hit 70mphRe: Yung Spil Yung Spil 08/24/18 02:19AM
  Re: Fastest Suzuki FA50? Hoping to hit 70mphRe: cheetahchrome . cheetahchrome . 08/24/18 01:41PM
  Re: Fastest Suzuki FA50? Hoping to hit 70mphRe: cheetahchrome . cheetahchrome . 08/24/18 01:44PM
  Re: Fastest Suzuki FA50? Hoping to hit 70mphRe: cheetahchrome . cheetahchrome . 08/24/18 01:45PM
  Re: Fastest Suzuki FA50? Hoping to hit 70mphRe: cheetahchrome . cheetahchrome . 08/24/18 01:46PM
  Re: Fastest Suzuki FA50? Hoping to hit 70mphRe: cheetahchrome . cheetahchrome . 08/24/18 01:47PM
  Re: Fastest Suzuki FA50? Hoping to hit 70mphRe: cheetahchrome . cheetahchrome . 08/24/18 01:48PM
  Re: Fastest Suzuki FA50? Hoping to hit 70mphRe: cheetahchrome . cheetahchrome . 08/24/18 01:49PM
  Re: Fastest Suzuki FA50? Hoping to hit 70mphRe: cheetahchrome . cheetahchrome . 08/24/18 01:54PM
  Re: Fastest Suzuki FA50? Hoping to hit 70mphRe: cheetahchrome . cheetahchrome . 08/24/18 01:55PM
  Re: Fastest Suzuki FA50? Hoping to hit 70mphRe: cheetahchrome . cheetahchrome . 08/24/18 01:56PM
  Re: Fastest Suzuki FA50? Hoping to hit 70mphRe: cheetahchrome . cheetahchrome . 08/24/18 04:28PM
  Re: Fastest Suzuki FA50? Hoping to hit 70mphRe: alex . alex . 08/24/18 05:08PM
  Re: Fastest Suzuki FA50? Hoping to hit 70mphRe: EH FCC of the QCB EH FCC of the QCB 08/24/18 05:29PM
  Re: Fastest Suzuki FA50? Hoping to hit 70mphRe: cheetahchrome . cheetahchrome . 08/24/18 05:45PM
  Re: Fastest Suzuki FA50? Hoping to hit 70mphRe: cheetahchrome . cheetahchrome . 08/24/18 05:46PM
  Re: Fastest Suzuki FA50? Hoping to hit 70mphRe: cheetahchrome . cheetahchrome . 08/24/18 05:47PM
  Re: Fastest Suzuki FA50? Hoping to hit 70mphRe: Ben Whittle Ben Whittle 08/24/18 10:59PM
  Re: Fastest Suzuki FA50? Hoping to hit 70mphRe: Totally normal JBOT Totally normal JBOT 08/24/18 02:06PM
  Re: Fastest Suzuki FA50? Hoping to hit 70mphRe: Totally normal JBOT Totally normal JBOT 08/24/18 03:21PM
  Re: Fastest Suzuki FA50? Hoping to hit 70mphRe: D L D L 08/24/18 03:16PM
  Re: Fastest Suzuki FA50? Hoping to hit 70mphRe: Dirty30 Dillon Dirty30 Dillon 08/24/18 03:17PM
  Re: Fastest Suzuki FA50? Hoping to hit 70mphRe: jayson sumpter jayson sumpter 08/24/18 03:41PM
  Re: Fastest Suzuki FA50? Hoping to hit 70mphRe: cheetahchrome . cheetahchrome . 08/24/18 03:55PM
  Re: Fastest Suzuki FA50? Hoping to hit 70mphRe: cheetahchrome . cheetahchrome . 08/24/18 03:56PM
  Re: Fastest Suzuki FA50? Hoping to hit 70mphRe: cheetahchrome . cheetahchrome . 08/24/18 03:57PM
  Re: Fastest Suzuki FA50? Hoping to hit 70mphRe: cheetahchrome . cheetahchrome . 08/24/18 03:58PM
  Re: Fastest Suzuki FA50? Hoping to hit 70mphRe: cheetahchrome . cheetahchrome . 08/24/18 04:01PM
  Re: Fastest Suzuki FA50? Hoping to hit 70mphRe: cheetahchrome . cheetahchrome . 08/24/18 04:02PM
  Re: Fastest Suzuki FA50? Hoping to hit 70mphRe: Totally normal JBOT Totally normal JBOT 08/20/18 12:41PM
  Re: Fastest Suzuki FA50? Hoping to hit 70mphRe: Brent Saxsma Brent Saxsma 08/20/18 01:46PM
  Re: Fastest Suzuki FA50? Hoping to hit 70mphRe: Dirty30 Dillon Dirty30 Dillon 08/20/18 01:50PM
  Re: Fastest Suzuki FA50? Hoping to hit 70mphRe: Brent Saxsma Brent Saxsma 08/20/18 02:17PM
  Re: Fastest Suzuki FA50? Hoping to hit 70mphRe: Totally normal JBOT Totally normal JBOT 08/20/18 02:10PM
  Re: Fastest Suzuki FA50? Hoping to hit 70mphRe: Brent Saxsma Brent Saxsma 08/20/18 02:19PM
  Re: Fastest Suzuki FA50? Hoping to hit 70mphRe: Totally normal JBOT Totally normal JBOT 08/20/18 02:23PM
  Re: Fastest Suzuki FA50? Hoping to hit 70mphRe: Brent Saxsma Brent Saxsma 08/20/18 02:25PM
  Re: Fastest Suzuki FA50? Hoping to hit 70mphRe: Totally normal JBOT Totally normal JBOT 08/20/18 02:27PM
  Re: Fastest Suzuki FA50? Hoping to hit 70mphRe: Brent Saxsma Brent Saxsma 08/20/18 02:31PM
Sorry, you can't reply to this topic. It has been closed by simon.
