How wide of a tire can I fit on a Tomos targa or Puch?
I want to make my 2011 targa lx look a little more sports bike-ish With a 110/90 tire and for my Puch Maxi I want to do a dragster flat slick look . How fat of a tire can I get with the colibri mono shock on the tomos and a robot swing arm on the Maxi? I'm willing to cut the Maxi if needed. I'd like to get a 3.25-3.50 inch wide back tire, do I have much options or do I need different parts?
Re: How wide of a tire can I fit on a Tomos targa or Puch?
Robot swing arm
Big mods needed
Search first.
The colibri swingarm won't allow a very big tire, 110/90 is way too large. I think you're probably going to max out around 2.50 on the tomos. I imagine 2.50 is probably the limit on the puch robot swingarm also.
Thanks Saabsonetguy, i appreciate the advice, do you know if there's a swing arm that can accommodate that size? I can accept if the wheel is too large but it would be nice to see a moped with that gixxser look on a tomos, mono shock isn't too important just want that fat back tire or as fat as I can.
Sorry MA I know it's frustrating talking to someone with less than experience but there a sale on treats and I want to get some stuff while it's on discount, natural instinct. Tried searching wiki didn't know which exact phrase or technical words fits the search engine, spent 20-30 minutes searching before asking because I know I'll get flak, only saw something on Puchs and even then my question is split in a specific question on a specific tire.
Joe Schuitema /
The largest you can fit on a puch in general is about 3.25". Any bigger than that and you'll run into the chain. Of course swingarm modifications are necessary.
rear: tomos hit the chain around 2.75 w/out dished sprockets. puch maxi can do some 2.5s. 2.25s are easier. with stock equipment.
front: do you want a fender?
Streetmate/Revival came with 3.25 stock, and some came without the dished sprocket. With a dished sprocket and the streetmate/revival swingarm you could do a tad wider, but not by much.
I've fitted a 100/80-16 Heidenau k66 on my Streetmate at the moment, which as it sits on the rim is the same width as the original Savas at... 86mm / 3.4". Next tyre change I may try a 110/90-16.
RAD!!! Very cool to see those fat tires! Does anyone have more pics of their stuff? It's dope to see.
I don't care for a fender I just want this looking exaggerated.
Can I do a colibri sub frame on a tomos targa a55 frame?
And if I have a robot swing arm or a puch magnum swing arm what do I need to alter on them to fit a 3.25 on it?
I want my maxi back tire to look like this jk but it would be nice
Lol
Badass bikes man, wich one is on the right in the picture? And what type of tire is taht and is the exhaust homemade?
you don't want to put a 110 tire on that narrow of a rim
...and your top speed will be about 18mph.
Want to reply to this thread?
