New Toro Racing Division Puch cylinder 3rd eye transfers.
I started following this company a while back since they post some cool cylinders that they design in house. They just posted the molds a few days ago that looked similar to Puch and they confirmed they are indeed Puch cylinders. Given that they are investment molds I assume they are looking to produce a decent number of these. Not sure if they are case inducted only or not though. Gotta get treats to hit them up and get some in stock.
Check them out on Facebook https://www.facebook.com/ToroRacingDivision/
(edited)
Re: New Toro Racing Division Puch cylinder 3rd eye transfers.
Totally normal JBOT /
Has to be case reeded tho?
Yea I dont know if it does or not. I mean they haven't machined the cylinder yet?
> cylinder yet?
By the looks of the castings pictured , it would seem they are case reed only . I see no other provision .
There is no provision for an intake on the cylinder to machine, so it's case inducted only.
Probably Fred /
Case inducted with huge transfers means you got to do a lot of work on your cases.
I really only run za50s anymore so even harder to do on a za50 then e50,
Have them make some bolt on and go cylinders that just need case matching and make more power than a 64cc polini kit or copy a 64cc Polini design into larger 70-74cc displacement
Transfers look cool. 50cc? Definitely pics after casting withbout clean up.
hey guys nice to see that you follow us on facebook!!!
googlde our name and your site came on super cool!!!
just for the sake of clarity they are prototypes
membrane seat comes in the production models
Give us a linky to your site, I'd love to keep up, I'll probably case induct an e50 next winter, why not?
do you mean membrane seat like cylinder induction or GME style? Polini style ones could be cool lots of options for reeds and intakes.
Yes like the polini the 50cc model will have a smoler intake as the 70cc model
Yes case induct is a super whe made 16bhp whit a simple dmp 50cc cilinder whit a case induct ..lots of porting t.r.d exoust
i think by 'membrane seat' he means the reed valve... french, german translations of 'reed' is membrane.
very cool! cant wait to see these for sale.
Yeah I'm just trying to figure out if they are going to make non-case inducted after the prototype. GME is how they refer to case induction.
Yes it wil be made non case induct
yeah if anyone could make something along the lines of the athena AJH but with a proper gila-sized reed, good split transfers and an exhaust with boosts.... it would be a game changer.
If you guys tell me what u want i will make it i love imput from the customers
timothy rendall /
There's a whole load of Puch maxi owners in the "UK" would like one too
Als Nederlander zal ik maar als eerste over geld beginnen; al een idee wat ze ongeveer gaan kosten?
Zal ergenst op 450 legge
First look then talk
Ik ben benieuwt! het is altijd mooi als er weer nieuwe producten voor de puch worden gemaakt.
Help me here does "non case inducted " = reeds ?
Does case inducted = piston port ?
I think the best intake pattern or design would be this one from polini
This gives people many options on produced intakes for many applications allowing it to be easier to fit to various bikes. Remember this cylinder will also bolt up to tomos too. This intake design would allow people to run a single pedal reed
4 pedal reeds
or running bigger (dio) kx65 vforce reeds
(edited)
is there a reason these couldn't be bored out further?
From their Facebook it looks like there will be 38mm and 45mm versions, and the cylinder inducted versions will use a vl14? Reed block, like from a Yamaha aerox / mbk nitro/ piaggio nrg. Not sure if those are minarelli horizontal or what the common motor between those is, but it looks like there will be some options for reed blocks...
Jimmy Cincinnati /
You should fix the Polini curse... i swear hot spotting comes from the location of the piston pin. Currently it runs directly through the intake port which cause a bulge of the ring and friction when it leaves the open port. Relocate that pin, and increase CC's and you would have a killer kit.
From their Facebook:
Okay..... I would like to try something like that for sure
