Re: Puch gila piston ring gap?
Ben Whittle /
Put the ring halfway in the cylinder. Make sure it’s level by putting the piston in the bore and touching the ring. Use a feeler to check the gap.
There’s a wiki page about ring gap. Use the chart listed on there.
Use very fine sandpaper (~400) to remove any material evenly from both sides of the ring. Check verrrry often
Click here to login.
