Re: So yeah there's this crank for Puchs you might want to check out
timothy rendall /
I am still building my Z50 it's taken over 2yr's now. Other peoples e50's are getting in the way :( but i will be getting there clutch kit soon as i am aiming at 50-60mph, so the engine is a bit tuned high comp head , 50cc 6port full crank, 19mm phgb carb, H4pipe & Hpi :)
  So yeah there's this crank for Puchs you might want to check outTopic by: will warn will warn 12/13/17 11:24AM
  Re: So yeah there's this crank for Puchs you might want to check outRe: Ken Roff Ken Roff 12/13/17 11:41AM
  Re: So yeah there's this crank for Puchs you might want to check outRe: Brandon Weiss (aka B-Man) Brandon Weiss (aka B-Man) 12/13/17 11:41AM
  Re: So yeah there's this crank for Puchs you might want to check outRe: Derek Stahl Derek Stahl 12/13/17 12:46PM
  Re: So yeah there's this crank for Puchs you might want to check outRe: Ken Roff Ken Roff 12/13/17 04:43PM
  Re: So yeah there's this crank for Puchs you might want to check outRe: Graham Motzing Graham Motzing 12/14/17 03:07PM
  Re: So yeah there's this crank for Puchs you might want to check outRe: ♫ Maize BLK ♫ ♫ Maize BLK ♫ 12/14/17 05:28PM
  Re: So yeah there's this crank for Puchs you might want to check outRe: will warn will warn 12/15/17 12:56AM
  Re: So yeah there's this crank for Puchs you might want to check outRe: Graham Motzing Graham Motzing 12/15/17 10:41AM
  Re: So yeah there's this crank for Puchs you might want to check outRe: will warn will warn 12/15/17 08:04PM
  Re: So yeah there's this crank for Puchs you might want to check outRe: ! ! ! ! 12/15/17 03:04AM
  Re: So yeah there's this crank for Puchs you might want to check outRe: Ken Roff Ken Roff 12/14/17 06:10PM
  Re: So yeah there's this crank for Puchs you might want to check outRe: Leland Kriz Leland Kriz 12/16/17 02:51AM
  Re: So yeah there's this crank for Puchs you might want to check outRe: timothy rendall timothy rendall 12/23/17 05:28PM
  Re: So yeah there's this crank for Puchs you might want to check outRe: will warn will warn 12/24/17 01:07AM
  Re: So yeah there's this crank for Puchs you might want to check outRe: timothy rendall timothy rendall 12/29/17 05:45PM
  Re: So yeah there's this crank for Puchs you might want to check outRe: Rocco Taco Rocco Taco 12/24/17 12:17AM
  Re: So yeah there's this crank for Puchs you might want to check outRe: Ben Whittle Ben Whittle 12/24/17 10:45AM
Click here to login.
