Larger intake pipe than port
I just got an carb kit that came with a 20mm intake pipe and my cylinder has a 19mm port. Would this cause any problems like build up of any kind?
Re: Larger intake pipe than port
Use a Dremel and match the port to the intake.
Can I Dremel justbthe intake port opening or do I have to dremel the entire port hole to the cylinder?
Make the small hole the same size as the large hole
That would be best .
If you can't do that , then at least make the transition conical .
Mikey Antonakakis /
Honestly I doubt you would notice a difference unless you're making crazy power and have access to a dyno
Want to reply to this thread?
