Tomos Mad Max Gilardoni
Some crazy tuning from Europe (just sharing pictures, not mine)
stock gilardoni
Now enter the Valhalla #%&%$#
those Alien transfers ###
Moar power #$#&#
yep this should fit now
original topic here
Re: Tomos Mad Max Gilardoni
We need it be cheaper just to move to Jersey.
Charlie. €8•>
How to: Destroy Clutches 101.
all that fancy machine work and then they used red RTV between the cylinder and spacer
> cylinder and spacer
Looks to me like they used it all over . Hopefully it's a lot better than the RTV we have state side .
The bridges in the exhaust ports look like those things would burn out in the first 10 minutes of running then the whole thing will just self destruct.
Good luck.
Charlie
pretty cool. Probably should have just put a scooter kit on though.
When there's a will there's a way.
DrGeorgeTompson (Alan) /
I always think i do cool shit and then i see threads like this and i wanna die.
> destruct.
Yeah i also think those bridges are way too thin. yolo
That's exactly what I was thinking, unless they are trying to work through a "moped kits only" restriction. That would be the only reason all this work could make sense to me. It would certainly be an exercise in riding loopholes to the extreme!
Also yeah, the aux exhaust ports have way to thin of space between them and the transfers and the main exhaust port.
Pretty f'n neat though!
Like the powejet on the carb
This is very cool to see, rad bike! Did you forge the header or was that only to change the color?
I totally apreciate the workanship that went into this....it's going to explode...the razor thin Aux port/ trans will either wear the ring or expand and seize the piston....looks super cool though :)
Hope you can make gears,
Cuz those balsa wood guts in that gearbox are not gonna take the abuse.
Great looking work tho
I don't think they'll wear too bad.
Transfer and ex aux ports don't wear too bad compared to a center bridged exhaust.
My aux port cyls have very little wear on the cyl wall slivers between the main port and the aux
It says it’s not his build right at the top. Why’s everyone referring to it as his?
It's his thread
Guess if it’s his thread it’s his engine too.
Makes sense.
> Makes sense.
So , if I start a thread about the Maserati next door , do I own that car ?
> it as his?
He as in the builder? That's assuming it's a he...
> Charlie BUZZARD Wrote:
> to
> > it as his?
Touché
> referring
> > to
> > > it as his?
> Touché
I wouldn't say Touché. It COULD be a woman builder which would make this build even hotter!
ANY WORD On How It Turned Out ??
Yeah I saw that but I was wondering If someone knew (before I sit through 32+ pages of Euro speak.)
Want to reply to this thread?
