Re: AV7, 15mm SHA, 50cc Airsal, stock sha filter, stock exhaust, 60-jet too rich?
Rebel Moby /
To remove the stock exit pipe just cut the stub off on the outside of the end cap with a hacksaw and then use a drill bit into the exit pipe and it will cut out. Optimum inside diameter for a single exit is around 11mm or 7/16 inch, you would want it to go inside the exhause about 1/2 the distance as the original exit pipe so you dont have to concern about the baffles.
> Kenneth Hill Wrote:
> Modified the exhaust baffle a bit more. I had no way to replace/re-weld
> the exit pipe (to one with larger diameter, so I used a bicycle quick
> release rear axle (larger diameter bore) as an "additional exit tube"
> ... bike runs a LOT better and the (once) rich jet now seems perfect.
> Definitely runs in the higher rev range happier.
  AV7, 15mm SHA, 50cc Airsal, stock sha filter, stock exhaust, 60-jet too rich?Topic by: Kenneth Hill Kenneth Hill 11/16/17 11:14AM
  Re: AV7, 15mm SHA, 50cc Airsal, stock sha filter, stock exhaust, 60-jet too rich?Re: Dirty30 Dillon Dirty30 Dillon 11/16/17 11:54AM
  Re: AV7, 15mm SHA, 50cc Airsal, stock sha filter, stock exhaust, 60-jet too rich?Re: Kenneth Hill Kenneth Hill 11/16/17 12:20PM
  Re: AV7, 15mm SHA, 50cc Airsal, stock sha filter, stock exhaust, 60-jet too rich?Re: Dirty30 Dillon Dirty30 Dillon 11/16/17 02:13PM
  Re: AV7, 15mm SHA, 50cc Airsal, stock sha filter, stock exhaust, 60-jet too rich?Re: Kenneth Hill Kenneth Hill 11/16/17 10:56PM
  Re: AV7, 15mm SHA, 50cc Airsal, stock sha filter, stock exhaust, 60-jet too rich?Re: Russell Huddy Russell Huddy 11/17/17 10:42AM
  Re: AV7, 15mm SHA, 50cc Airsal, stock sha filter, stock exhaust, 60-jet too rich?Re: Kenneth Hill Kenneth Hill 11/17/17 11:20AM
  Re: AV7, 15mm SHA, 50cc Airsal, stock sha filter, stock exhaust, 60-jet too rich?Re: frank dadog frank dadog 11/16/17 12:42PM
  Re: AV7, 15mm SHA, 50cc Airsal, stock sha filter, stock exhaust, 60-jet too rich?Re: Toledo Riot Toledo Riot 11/16/17 07:47PM
  Re: AV7, 15mm SHA, 50cc Airsal, stock sha filter, stock exhaust, 60-jet too rich?Re: Kenneth Hill Kenneth Hill 11/16/17 11:00PM
  Re: AV7, 15mm SHA, 50cc Airsal, stock sha filter, stock exhaust, 60-jet too rich?Re: Toledo Riot Toledo Riot 11/16/17 11:18PM
  Re: AV7, 15mm SHA, 50cc Airsal, stock sha filter, stock exhaust, 60-jet too rich?Re: Kenneth Hill Kenneth Hill 11/17/17 11:52PM
  Re: AV7, 15mm SHA, 50cc Airsal, stock sha filter, stock exhaust, 60-jet too rich?Re: Rebel Moby Rebel Moby 11/21/17 07:59PM
Click here to login.
