Re: Fuckin around in the shed
Ungapped rings to bind them all /
.. intriguing use of vageometry in the framework to straddle the cylinder head.... great thread.
something about that frame... those lines... that color.... what does it remind me of?
Anonymous User /
scootertrash
Not too shabby for a 1am rattle can fucker.
There was rust under the the original Vespa powder that had to be stripped. I used the DA with 80 grit, which is the sanding finish in the pics. This is a ruff ideaR, another layer of rondo on the seams to fill them out flush before the finer sanding. LoTs of steel grinding here to remove the old frame bits, had some tunes jamming in my ear buds, mask, glasses, vacuum, magnets.. anything to catch the shit flyiNg.
The rondo plastic shit is HARD! (Resin+Bondo) It’s consistency is like pancake batter. Fucking awesome! Went on with a 2” throw away brush. Shaved it down with a rasp then DA 80. I’m thinking about fixing the dent in the General tank with it. Mix a little batch.
Anonymous User /
scootertrash
The RigNition is going good. It’s a jog box on a Yamaha Razz stator coils with an external sparkulator. I’ll have it all Jbot styled with the 12x54x1mm strip welded to the flywheel on Fire while holding TDC with the key in kinda shit.
The 2 stator mounting screws are hitting the back of the flywheel. I’ll have to take the 1/2 spacer out and trim it to 1/4” or something like that.
Anonymous User /
scootertrash
How about this lickwid meTL
Pounds baby PoUnds! Hahaa
Just hope it stays where ya put it . ;)
Maybe you drilled a few holes in some of those ribs , so there'd be some cross catch .
Maybe I'm not seeing what you're trying to do .
Anonymous User /
scootertrash
Just playing around with Mercury for a minute. :)
Ahh ... I kinda wondered if it was mercury by the way it 'pooled' at the edges .
You wear good gloves when messing with that stuff , right ?
There is such a thing as mercury poisoning , in case you didn't know .
> edges .
He's already mad as a hatter
Anonymous User /
scootertrash
The seat base worked out good. There’s a thin foam layer under the fabric.
Anonymous User /
scootertrash
Broke my tooth off eating the candy. :(E
This 60 second glue might work to put it back together?
The shaft is so nice! It’s polished by hand with super duper fine carborundum stone. The 4th bearing on there and the needle bearings shimmed. Fuck it was a lot!
Anonymous User /
scootertrash
The rear pulley with the red spring??
Heck yeah, Miss O. Jenny, the clutch locks onto the shaft and there’s plenty of room back there. The end of the engine studs will have to be sawed off for the clutch to spin. Still working on the shaft, drill and tap a couple set screws to lock the clutch on tight? I’ll try that first. Fuck YeaHh
Anonymous User /
scootertrash
I have a side cover ideaRr. Cut some strips and lay it on there. Ya know jgeeSs the plastic is not going to cut ur fucking leg.
Hahaa! It’ll be fun.
this is the best thread ever
Anonymous User /
scootertrash
Ha! Started the front wheel. It’s spinning great but I’m still going to install a new set of bearings. That’s easy, the disk brake rotor and caliper setup is already figured out. The thing thats noT figured out is how the front wheel is paintEd. I heated up a couple cans florist silver and hammered gold. The forks are clamped so I can spin the wheel and spray the fuck out of it at different angles. :)
TryN to come up with something fitting.
Anonymous User /
scootertrash
The clutch pieces are coming together. forgot I worked on the sumbich!
The holes thru the washer I’s going to thread thru for a clutch puller. The 2 holes on the coller, with a nut welded over the hole then thread thru them. I don’t want the fucker to come lo0se!
That gold-silver-gold from center to edge looks neat.......
Anonymous User /
scootertrash
Swiss Miss O. Jenny
4 cups of that shitll get u going !
Anonymous User /
scootertrash
Someone wrote CUT on the other side of the clutch. I wonder what that was all about..
> was all about..
Maybe some hacker had a dream , but then thought better of it ?
Anonymous User /
scootertrash
Here’s what i was planning on. Cleaned it up then reinforce it with the washer.
The washer sits nice and flat. The clutch will be facing the same direction as on a hobbit. To change the springs, I’ll have to loosen the set screws and pull it off the shaft. On the hobbit engine, it wedges onto the shaft so it prolly won’t have that pop this way.
Sounds like a plan . Might have to take a little bit of that washer to insure spring clearance . Maybe the washer just looks thicker than it is .
Anonymous User /
scootertrash
I see what u mean. Fuck it, more Jbot mods, move the spring hole oveR ;)
This plastic GY6 variator fan tacked in the back side of the clutch. I torched it til it was loosy goosy and flattened it out. Mauled out the center hole bigger using a little belt sander. Trying to throw some wind, the exhaust is right there ^ from this shit.
Anytime you can break up the heat plume is usually a good thing .
Anonymous User /
scootertrash
GotR all drilled, tapped, welded, torched the steel center to harden it. It’s all red hot and I toss it in some transmission fluid. The fucker burst into flames like a Hollywood fake explosion. BiG ass burst!!
Anonymous User /
scootertrash
It’s all juicy now. Now I gottta find the springs. I think I had some black ones.
reminds me of a Georgia o'keefe
Anonymous User /
scootertrash
Washed it up and torched the moisture til it evaporated. heated up a can of epoxy.
It’s a lot easier to see when it’s painted.
Kinda like the mini bike clutch. lock it iN
I’ll hit up ACE is the place for the 3 set screws and 4 bolts to finish the intake.
Anonymous User /
scootertrash
This looks good!
