Re: Fuckin around in the shed
Anonymous User /
scootertrash
Microwave still works like a champ. I used it to heat up some french toast and it works. When ur cooking the bearing, don’t worry about it. Wrap it in a wet towel on the plate for 1:30. When it’s steaming, it’s 212*, it won’t get that hot.
A bunch of these bearings were done like that.
Sending them to that sculpture dude in buy and sell.
Great . You should have the re-purposed award for the month . ;)
Anonymous User /
scootertrash
Setting up,. Drilled it bigger to 3/8” then hammered in a smaller spacer. I’d like an 8mm bolt to thread into the crank end.
EyE sharpened the bits using my Safety Squints, drill, and a flap wheel on the right angle grinder.
Dull bit, its blade is crumbled.
Anonymous User /
scootertrash
Run them against each other to even the tip. holding steady
Sand off the lump of steel behind the blade. In red
The red part keeps the blade from engaging. Remove that part easy.
Anonymous User /
scootertrash
Take them out one at a time.
Drilled into the end of the crank 20mm deep so fast! The bit was in there munching, big chips were popping!
Heck yeaH that went good.
Anonymous User /
scootertrash
Sharpen them old bits up! mmmmmM
Anonymous User /
scootertrash
The 8mm tap went well.
CHECK!!
Anonymous User /
scootertrash
The needle bearings in the variator fit nice end to end.
Sometimes it’s better to be lucky than good!
Seems you may have both going for you . ;)
Anonymous User /
scootertrash
Yea! For the ignition, a 1/2” steel stick wrapped in a circle and ends welded. 4 spacers will be welded to the band then trimmed off to make the whole thing into a spacer. The bolts go thru it all to make an even surface to mount the stator. Fuck it almost rhymed..
Anonymous User /
scootertrash
Found another needle bearing that’ll fit with a little shimming.
Is that enuff bearings? I was thinking 1 more just in case. Hahaa!
Anonymous User /
scootertrash
BouT time to clip it back on the snow blower! I mean moped.
The carb might fit thru the frame with it in this pOzishh. Thad be cool, the only screws i could find that fit the intake to the engine are these tiny coil screws. Teeny tiiny threaads. Thinking about upping it to M6.
Hmm , A double down tube , oval shaped , with that carb sticking through would be interesting . A conversation piece , so to speak .
I'm curious to see how this will perform. I'm guessing "torque out the ass" but not very high rpm.
I'm hoping the carb fits through the Grande frame and gets Ram air induction
I know it's getting a little late but I'd love to see this reverted to stock
Anonymous User /
scootertrash
Added a few spacers to fill out the total width. Tapped the intake case threads. This subframe is bent up on both sides, I have a few more to swap it out with.
These snow blowers are about $40-60 at craigslist. The dude I got this from was kinda pissed that I took the engine and shit canned the rest. Hahaa! He left it here!! :))
Anonymous User /
scootertrash
Maybe I missed it , but , what size is that motor ?
Anonymous User /
scootertrash
96cc Tecumseh engine. 53.5mm bore 43.5 stroke
Good ideaR Will, make it sleeper stock with all the side covers and stufF. Turn the intake around, RaM aiR u sAy? Mmm that would be dope.
> stock
LOL!!! I second this
Thanks . :)
That should help get you past 30 MPH , maybe . LOL(edited)
Anonymous User /
scootertrash
Is that when u die?
Anonymous User /
scootertrash
Here she goes!
Let her rip! Tatter chip!!
Anonymous User /
scootertrash
CHECK IT
Rare moped artifact
> CHECK IT
> Rare moped artifact
So , you use that Listerine as a parts cleaner ? ;)
Anonymous User /
scootertrash
ULtra clean!
It went gooD
That’s all I have, the rest is a bunch of junk.
Rad art!!!! More food pics, m hungry af
Anonymous User /
scootertrash
Ran saCked the kids Halloween candy!
