Re: Fuckin around in the shed
Anonymous User /
scootertrash
She’s lookin mean, rRaaAAHH!!!
Added onto the general tank one day.
Anonymous User /
scootertrash
Almost fucking forgot, I got a hydraulic ram off a snow plow lift to fit in there.
Anonymous User /
scootertrash
Here’s the “ReDufus” 3 step bell bracing.
2mm strip 1/2” x 12-1/2” hose clamp, drill..
Same thing with a 1” wide strip
DrGeorgeTompson (Alan) /
lol i fuckin love this thread. Shotgun crossbars for all.
Anonymous User /
scootertrash
Yea I like it!, might need it for road hunting. The snow plow ram is theft deterrent “ejection seat ideaR #22” key fob control.
Not the trunk button!!
Anonymous User /
scootertrash
The gun is for a magnum moped tho, it even says IN MAGNUM.
Anonymous User /
scootertrash
Take a look at this intake.
Trying to figure out where I went wrong.?
I've created a shortcut to this thread on my home screen.
Just needs a bit of duct tape and some bailing wire . LOL
Anonymous User /
scootertrash
Intake Adapter 101
The round sides are wrapped around a 1/2” drill bit while clamped straight. HammAhh
Anonymous User /
scootertrash
Anonymous User /
scootertrash
Then the burr with some oil will eat that extra stuff up nice. The belt sander to deck it flat on both ends.
Anonymous User /
scootertrash
Needs some trimming for the depth as well, but it lines up good.
Anonymous User /
scootertrash
Found another hobbit needle bearing for the clutch pulley and coller to lock the clutch onto the shaft.
The studs sticking out of the engine will have to be trimmed. This stuff should fit right in there.
Anonymous User /
scootertrash
Having a shit fiT!
Anonymous User /
scootertrash
Here’s how to catch them. Keep on blinking until u can get close. Grab him when he charges and hold down one of the arms.
Anonymous User /
scootertrash
Then u can handle this animaL
Made a quick jig to hold the case. Screwed it down to plywood and ran the router over it to even the sides. The steel plate motor mount bolts onto this flat or with spacers, can’t remember..
Anonymous User /
scootertrash
6203 bearings, big ass con rod!
Anonymous User /
scootertrash
The router did a nice job.
The other side is ready to go.
The plates had to get cut down cuz they were hitting the fins and blocking the side exhaust.
Anonymous User /
scootertrash
This thing is wild
Anonymous User /
scootertrash
Did some cooking of my own!
Wrapped it in a wet towel and cooked it in the microwave for 1:30. Right oN!
Anonymous User /
scootertrash
I'm digging this build, keep it up.
Anonymous User /
scootertrash
Slammed a few glasses of SwissMiss then cut out and bent up another intake adapter.
Down the hatcH!
Anonymous User /
scootertrash
The hacked up mountain bike bars are dry. I used this old can of florist paint to see what happens. Mixed with clear engine enamel.
LowwwrriZzzh
^Amazing! Squirrel grabbing is weird though... :)
Anonymous User /
scootertrash
Yea, had to get them rats out of here.
Went outside and found a 7’ stick of steel rod. It happens to be the motor shaft size o.d., a 3” piece is about all it takes. I’ll have to check which tap size fits the drill bit, 8mm.? It would be an awesome drill guide if it works.
The pulley is on there to couple the shafts.
Had to dig thru a pile of shit to find the pulley!
This build is so crazy; even the side notes boggle the mind. e.g. So you cought the sqrl by hand??? Holy shit dude, that's some Kung Fu grabbing right there. Also, when u nuked te bearing - did the wet towel stop the metal from torching the microwave???
keep up the awesome work.
Anonymous User /
scootertrash
Yea, the bearing wrapped in a wet towel for 1:30 gets it hot quick about 2 thousandsthsasus bigger to drop it on. About 175*f. Grabbem around the neck too, tight!
My first car was a 76’ firebird. This ones a 77’ my dad bought it for me. It was for sale on the side of the road a couple miles over. In the mean time the fire moped moved in. The car is constantly in the way cuz I don’t drive it! 35,000miles :/
Bitter/Sweet
