Re: Fuckin around in the shed
πΏπ‘–π‘˜π‘Ž-πΏπ‘œπ‘‘π‘Žπ‘ π‘Žπ‘’π‘Ÿ π‘€π‘’π‘”π‘Žπ‘π‘’π‘  πŸ¦– /
Grave Digger is about right hA! I pretty much got the hinge ideaR from this toy. A little rear steer hmm..
Definitely locking the dif Diffley! (edited)
Engaged
I don't see why that wouldn't work .
Maybe the first articulating moped . LOL
The rigid mini bike fork bars hacked into a frame brace went well. This side is a inch wider so the chain guard fits in there still.
If that rear chain has a tendancy to slacken and jump off of the sprocket over bumps now, you can move the swingarm pivot up a few inches and put it in line with the front sprocket.
Right on, I’m glad it was close but we’ll shim it over a fuzz. Thanks a lot!
I found an oil filter on the outskirts of an engine block. Moped size oil filter? A couple 1/8” barbs would do.
Or clog it up and use the threaded end
Had a pile going on the side to change the 1978 Express sprocket sizes and chain. Got around to et that will be fukan assom if it works out. The bell has a bearing now too, I might add another if there’s enuff space to fit into the clutch without hitting the center
I put a taller 12t sprocket on the clutch with the 415 chain, check it
Moby pulley, I cut the sprocket off the steel donut keeper and the express clutch bell.
The damn moby sprocket fits perfect onto the express bell, a GY6 bearing fits the damn sprocket I.D. and the shaft O.D. Kick asS!
The chain slack is about like it was stock. I’m gonna order a 13 tooth to tighten it up a fuzz, 18t puch sprocket on back.
DPC! (edited)
Ha . Luck favors a good parts stash . ;)
Imagination > lack of material ;)
I broke a few teeth out of the rim taking it apart and adding the Vespa hub between the hobbit hub and mb5 spokes. Snappedem off. Fuck! I guess I’m going to leave the welds this time and run over the other spikers again. After that I’m gonna bead blast them clean then I was thinking about this red with some black rim would be neat.
My daughter picked it out
Then you have to go with it . That would put a smile on her face , for sure .
I promise I'm gonna go read this from the beginning because after skimming through it I'm thoroughly impressed!
But hey, check your messages and give me your old lady's PayPal info so she can ship me those wheels!
Wow the red is nice. ,whatever getsR done Dirty. Ha! different cheapo pic filter
A quick color test with this rattlacquer from autozone, then black out the rest of it or mabe some gun metal color with black.
Didn’t really like the seat so I cut it off. That’s what I love about this shit, β€˜cut twice, don’t even measure’
If CW wasn’t trapped in the desert he’d be calling you right now.
This shit rocks socks!
I love the shadow tint! It’s Super nice outside today.
Added a shot to the 1973 Vespa brow headlight bucket. There’s a good 1 1/2” to 0 wedge that I cut out of the tank sides to make it moped size. A buncha welding and fitting to do to seam it and repair a few spots from previous hackages. Something nice to look forward to. Had to disassemble the rear wheel again cuz I put the hub into the mb5 spokes backward. The mb5 rear has longer spokes on the brake side of the wheel to hold the wheel center. 3.25x18 Sava MC7
It must be red day, I took care of Steve’s urban forks then squirted a touch up. Super Cadillacky suspensions. Awesome!
That Coleman doesn't look like a hack job; it's what the design should have been.
Right on! It’s going good
Urban light sewed on an urban cover
Urban triple top cut apart hobbit clamps Express bars
Still gotta weld the swingarm in place
I hope he buys you lots of beer or whatever you drink .
That thing is worth more than twice retail . ;)
CT200 (crushed taint x 200)
Love those fat tires
Now can you send me the old lady's PayPal info???
Brent,, what if u could go bacK<<<<<<<in time?...
I’d party rock with Jesus if I could go back in time.
Slam some beers an write Christmas songs hallōłüñįkuhhh!!
Kosta Constant /
Is that a trike rear end?
Hopefully you'd send me the wheels lol
Check iT single-speed
Getting ready to weld the spider gears in the differential box. I removed the optional transmission stuff and was able to chuck up the variator more direct and connected onto the side input shaft where the disk brake had been attached. Same shaft spline on top and side CooL
9:1
Send me the PayPal info!
