Re: Fuckin around in the shed
first name last name /
This is what happens when moped's start cross breeding with snowblowers
Mike Piarowski /
That’s a lot of comments that I don’t want to read. Is this snow blowing hobbit done or what
That telephone though!
πΏπ‘–π‘˜π‘Ž-πΏπ‘œπ‘‘π‘Žπ‘ π‘Žπ‘’π‘Ÿ π‘€π‘’π‘”π‘Žπ‘π‘’π‘  πŸ¦– /
Mike I got caught up, did a few laps on the swing set, but uhhh, I’m on it. Be blowin snow again before too long buddy.
If u got a minute, come on by and help me with the timing.
Jayson, 1-900-BRING-TRUCK
Yea, so that and I need to build a lift kit for the garage couch so the skirt don’t get grass stains on it.
It’s always somethin!
Great . I see you installed a mobile phone , too . ;)
Crazy Wayne direct line, lol.
ScooterTs pics need to be in a coffee table book
Heck yeah, Thad be fun! When Wayne e-mails me, and I’m on the go. bonus pic
*Running Windows 98 SE
Autonomous mopeds ... what will they think of next ? LOL
Scooter Computer!
Floating Genie head-light FTW!
This here urban footrest was in the pile, pile it oN
stabilize and hold the fenderish
Might even double for highway pegs . ;)
I went and grabbed 2 forks I won’t use and made 1 set I might. :)
Gy6 forks embedded into the hobbit set 3-1/4” and plug welded some.
Is it really hip to be square or was that guy fuckin around?
Omg you're killing me over here
Things will never be the same again.
Ha . Proof positive : everything changes , always . ;)
Lol, I feel very sorry for the guy that askes you about this bike at the gas station...
I’m cutting off a tube for a motor mount. I use this tool a lot for evenly marking around and it stays really sharp after years of cramming into steel and even hardened steel. It leaves precise lines. I used it to do the forks, frames,, that steel it will cut all the way thru if u got the time to spin it around. Great for marking tho ChecKit.
Charlie I love it! Hahaa! I used to watch that hard. I say I don’t know, it came like thaT!!m
Can’t wait to see what u guys jam together! (edited)
Thought of a good name for it, sounds real important now. Almost industrial check it
Also trying to finish the fork on Jenny.
Pipe/tube cutter ... Had one for ever . Like yours , still sharp . Mine has a reamer to take the inside burr off . Neat tool .
It’s together enuff to roll out and finish later. Some of the stuff I shaped up,
Quad bars narrowed about 3” in the center then 2-1/2” cut off each end.
My wife found the new tire. I cut out the coil mount and pressed both sides flat. Fixed them up some with a hammer and cut out the air box.
Drilled thru the sides and cut a spacer to fit. I used a 10mm bolt thru that then welded a shock mount to it. I can rotate it to adjust the angle and height then build braces around it to hang on.
I leave it outside now that it’s rolling. Trying to figure out what I don’t need and get rid of it. ;)
Thinking about adding onto these coils. I made a dumb little thing to hang onto the bobbin. A 1” square tube crumpled up and chucked in the drill. The stator attachment screw lined up and drilled thru each side of the steel. Shimmed the pick-ups curved edge in the hole to hold it straight while it’s winding then dogged the nut to give it a little squeeze. SuRe..
A divot on each side of the donor.
A U shaped piece to hold the spool.
That should work . Looks like some pretty fine wire . Guess you won't be gunning that drill much .
I did similar when a head light coil didn't have any output . Only I had to strip the OE core . Wound the wire on a tomato cage and then coated the wire . Then off the cage onto a coffee can with a coat hanger spindle through it and from there back onto the OE core after I cleaned it . No more 'no output' . Just a decent headlight . ;)
