Re: Fuckin around in the shed
πΏπ‘–π‘˜π‘Ž-πΏπ‘œπ‘‘π‘Žπ‘ π‘Žπ‘’π‘Ÿ π‘€π‘’π‘”π‘Žπ‘π‘’π‘  πŸ¦– /
Oh my poow ittl hunH?
Shaft has a set of 6203 rs press into the brown tube. (From an old adjustable bed actuator)
The bell locks the end and chain locks the middle. The pulley and clutch are on a GY6 pulley bearings reinstalled after chopping the clutch holder off.
Looks a bit shy on threads ...
Looks presentable , otherwise . ;)
GOOD EYYEE P D !
trimming 1/2” off the length of the clutch holder piece. Coming together solid! A few more things to check on it.
I might hijack the express, cause an apocalypse
I suggested the adderal to help focus on the pink tecumseh banana massacre, but then i remembered that after all, this thread is about just fuckin' around in the shed.
Carry on.
I’ll have to set it aside and get back on O Jenny.
Yeah, good 1 it clogs up some brain shit to slow the flow something.. i have a 10 more that work against it. Hahaaa! Yo know, damN
Agreed, and not to digress too much, but I find that Adderall styfles creativity a bit. Best used to plow through menial work once you've planned things out.
I’m happier on Modafinil than I was on amphetamine based meds.
I must be lucky . The only 'meds' I take are a baby aspirin almost every night .
That's not including the copious amounts of caffeine , nicotine and other 'preservatives' . ;)
Oh Jesus scooter that bmx is the bike I wish I had in grade school fuck dude
Everytime I open this thread I can’t belive my eyes.
Best thing on the Internet.
Did u guys hear the holy rollers brapcast?, that’s the 2 guys that came over when I was REAlly fucked in the head. They came all the way here, over an hour drive and did about 8 exorcisms on me. All my shit busted up, nerves tore and frayed, didn’t grow back end on end. Causing all kinds of hell, mysterious electric shock and brain freeze, sometimes like my back muscles are hanging from a wire coat hanger inserted thru my brain stem, shit. The dudes came by and did all that praying stuff, then said they baptized me 6 or 7 times I thunk.
first name last name /
Unclogging the kstar and Sachs
I wrapped a steel strip band around the edge of the case to flush with the cover stator. It has a thru bolt and nut welded to tighten it like a hose clamp. To find the timing all I had to do was hold the crank TDC, transfer the flywheel marks to the steel strip, rotate the damn cover til the ignition check hole line, lines up with the mark drawn on the strip. Pretty damn cool, now I’m looking around for mORe.
It’s on time, I’ll pull the cdi plug then weld the coupler nuts to the band.
That fuckin Wayne.., I’ll tell u what! Sumbich calls and says if the stator slides that easy then I could control it with springs and levers and shit. Prolly how Jbots Apocalypse came to be. Fucker calls every 15 minuteS seems like!
Haha yeah, the old stator moving via cable story. Heard it. Multiple times haha
> times haha
Some old cars had an on dash timing control that worked sort of like that....
Hello. Are you ok? Hope you got all the doc shite sorted.
Well maybe this will fill in till he gets back.
I got talked into the stator on a cable idea. I put it on a jawa cuz that was the bike I didn't care about but ran well, and it's an internal rotor so it was way easier to install. used a bicycle positron shifter from an old huffy. it's a real simple push/pull solid cable. You could actively make it run crappier or better which I guess was kinda cool but the bike didn't have nearly enough performance to be worth a damn and I didn't even ride it that way, just revved it around a bit before chickening out.
Thanks scooter for everything.
WaiT! Will, I wanted to show u this fancy get up.
SACHS see it’s a sacks. I fit the badge on with extra hackage attachment filler.
What the heck is it??!?!??
It is a GY6 transmission piece hacked the part that supports the clutch pulley shaft and bearings with the 3 bolt pattern surrounding it and pressing it back together as it was.
I looked it up and found out this was a Sachs A2 42mm stroke 2 speed. With the transmission cut off, I drilled and tapped some holes on the back for hanging a 2’ x 24” bulletin board.
More hack for clutch pulley
I got another thing that’s funny as hell I’ll show u in a little bit.
It’ll have a stick jammed in there to push off the engine mount I thank.
I’ll have to see how the sprockets work out, a 40 or 36 swapped from the 54 on the rim.
blood on the floor?
NOSE BLEED! From getting up too fast I guess.
I messed with this clip thing that might work for changing the size easier.
I think to cut the ^ top bent over piece totally off,,
It covers the ramp end..
Think it’ll do it?
