Re: Fuckin around in the shed
Anonymous User /
scootertrash
3 exhaust holes out the side.
Anonymous User /
scootertrash
Look at this casting. Ha!
Transfer on the other side
Anonymous User /
scootertrash
Tiny!
yeah they aren't made to rip hard, i ported an outboard that was made like that, just squared/ovaled off the holes to make the bridges a more constant thickness and raised exhaust a fair bit.
ran well until some scrapper stole it.
> Sçütaur Rackęt Wrote:
> The wire feed trigger switch shorted out. It’s a Miller handle hacked
> onto a Clarke welder. There was a problem with the sheath so I cut off
> the bad part then stripped it away. Resoldered the brass end onto the
> shortened cable. Found a moped button and wired it in for a temporary
> fix. Not bad, it’s kinda like a drill now!
our first swoops shared welder had a brake switch button to feed. it was always charged though, even when it wasn't feeding. whatever. worked til we got better stuffs.
youre a maniac tho, good shit.
that engine needs a fan
phillips head screws on the cylinder bolts? man' i'd like to punch whoever designed that.
haha
the economics of those engines are insane. i work with a few guys from Briggs- they are about 2 blocks down the road from us here- and the stories they tell would blow your mind
that whole engine probably cost less than 5 bucks to make, if they can save .001 on a screw it works out to big money in that industry.
Anonymous User /
scootertrash
Every bolt on the engine was hand tight! The magneto ignition and points with an 8” aluminum flywheel. It has built in fan blades like a lawn mower engine. I’d like to fit something moped sized to it.
Anonymous User /
scootertrash
Check it out, went into the stator pile looking for anything non honda, grabbed these 2. The damn taper fits on the 5 pin CDI. How’s the hecK!
Anonymous User /
scootertrash
With the stator plate drilled out a fuzz to fit,
This’ll be good, weld some 6mm coupler nuts to the steel cover plate to attach it.
Anonymous User /
scootertrash
With the stator out of there, the flywheel fits all the way. CooL I can make that shit work
Tobias Doesn't Care (ง •̀_•́)ง /
Hot damn Scoot, this is great. Seriously loving that frame build.
Anonymous User /
scootertrash
But uhhh...
Anonymous User /
scootertrash
Right on thank yoU
Kinda was thinking of a frame name:
C.ant U.nderstand N.ormal T.hinking
Anonymous User /
scootertrash
Ohh Fuck!!
Anonymous User /
scootertrash
This is how I cut the hobbit frame. The 2 on the left matched up for the bottom, then the longer one for the seat. “Smoke’em if u gott’em”
Anonymous User /
scootertrash
Cut the tip off the grande and right behind the cross over tube.
Anonymous User /
scootertrash
Broke the grinder..
Found the 1973 ciao headlight with the bracket still on it. Veshhpah! 35w halogen
I was thinking the same about a fan. Cooling fins don't look like much, but i guess you don't need much when your forcing 30 degree air across them in the snow. Run a temp gauge if you're not running the original fan and shroud to see what happens. I ran the fan and shroud on the bike i made, but it was geared for low speed high torque dirt action.
Anonymous User /
scootertrash
Sounds like a lot of fun Awesome!!
Fan CHECK
Anonymous User /
scootertrash
This lighting might come in handy. A harbor freight bump foot switch with a 3 way outlet to turn on the saw and light simultaneously. A 12v wall wart powers 2 LEDs 40mm x 60mm.
Anonymous User /
scootertrash
Anonymous User /
scootertrash
I found the saw online. The things I like about it is the variable speed, locking trigger, and it has a square sides to get a clamp on it quick. + NO SPARKS!! :)
Anonymous User /
scootertrash
One of the performance builds on the side is this electric bed.
Anonymous User /
scootertrash
Calm dowN,
She has a boyfriend.
Nice Firebird. Kinda lost me a bit w/ the beds tho; so you made 2 of em? Got pics of em in action? And whaja make em outta?
Good stuff right here.
Anonymous User /
scootertrash
I found the beds on the street. 19:1 linear actuators. Not too powerful but I needs an adjustable moped table. :)
This cable lift has me spoiled.
It’s also from a bed with 115:1 gearing so it lifts the moped easily. I ran a 1/4” steel cable thru the pulleys and a spool welded onto the gearbox shaft. Based off the $10 bicycle lift from harbor freight but all the cheap pulleys replaced with better stuff.
Anonymous User /
scootertrash
A better pic of the cable.
Hot damn, very nice work. And made from free crap someone else tossed away. Really dig the cable-rig too.
