Re: Fuckin around in the shed
Cheesy carb plate doubles as squirrel bait
πΏπ‘–π‘˜π‘Ž-πΏπ‘œπ‘‘π‘Žπ‘ π‘Žπ‘’π‘Ÿ π‘€π‘’π‘”π‘Žπ‘π‘’π‘  πŸ¦– /
He wants to come over, I heard him stalking the other day. He thinks he’s hiding. Hahaa!
Hacked some off the pogo,
Digging thru a bin, I found a hardened sleeve leftover. Welded a nyloc nut upside down to the end. The rim around the nyloc fit nice to hold it centered.
The hole in the sides to plug weld it together.
After the stem is good, the bolt pulls the thing together and holds it while I double check the measurements and fit.
This plate laminates to the underside to carry the spring braces on each side.
Beasty nib
Hammered it into the stem, side welded and sanded then pulled into the triple TIGHT! it went good
The triple top is bolted down onto the end of the stem and legs so I welded in a nut.
Hammered it in then welded around.
It’s ready now to measure the space between the bearings. weeeeee!
Heavy Duty, for a heavy dudey.
Oh yeah!
The tube cut off for length and the ends squared with a file. The headset hardware and tube from the Chinese commode tacked into the frame using the Vespa head tube guide. ;)
Fuct around with some other fun things, the pullstart from the snow blower with the catch stuck to the flywheel. Hobbit head/cylinder studs welded out to hang the assembly by the corners.
Tried to get a pic of the gap between the fan and rope.
I’ll wrap around to fill in the rest.
..and a tank hanger
Hangs the tank as on a hobbit, there’s 3 bolts welded out from the frame to connect the sheet. A couple rails to hold the tank aligned. There’s more pieces to add after I trim the fat.
Hookt up the throttle cable and rear brake, plated the electricks. It runs mean, I opened it up the other day. Holy fuck! I need the damn pipe done
Couldn't sleep so I read this thread start to finish. What a journey, so awesome.
Sleep tight.
If u can’t bucket, fuckeT!
Did a bunch to get the forks and shock mounts more complete. I donno what the hell happUned after that, I found an old light that’s been kicked around here for years. Trying to do something with it or throw it back in the pile. Hacked and melted a shitty old ace hardware bucket onto it to see what it dooz. \/0\/
Purdy.
Hope I don’t find anything else out there, I need the pipe on. :) Sorry for the videlay guys U gotta hear iT! my son is hype on shooting it but he’s been skateboarding after school since it’s been nice.
Found a triple top plate from a Honda fifty shifty minibike that fit the shit. Welded some nuts on the back of a sheetmetal strip then welded the strip to the edge of the plate to give the bucket some more attachment points.
Still on the forks and shocks..
Dang!!!!!
497
498
499
Doesnt count
Josiah Radebaugh /
You know what you should try.? You should try hydro-forming an exhaust for this build. Sure you've got one but why not?
If you can hydro-form a pulse jet, you could probably make an exhaust
alotta pipes re hydroformed anyway
Josiah Radebaugh /
Well, actually the pulse jet is what gave ne the idea. Same shape.
I would like to try it, looks like fun. Earlier I gathered some Junk for a quick pipe bender. The pipe filled with volcano ash, I didn’t want to use sand blasting media, was all I had. Capped it and packed it with an end bolt.
Just junK strapped to the fence
The braided hose came out from the kitchen sink, got a new faucet last week I think and the hose was built into the new one. I used it as a reference for the bend.
Gottm cut and tacked to see wtf.
FIT
Even length tubes and a long bolt thru the shock eye to hold them parallel.
I’ll fix it with a hammer.
Welded the shocks in place then cut the tubes off about an inch above the connection point. I went out and bent some more tube to finish it out. Tube coping, birds mouth, heat and beat.
