Re: Fuckin around in the shed
> Moore Burns & Payne Crematorium Wrote:
> Guys I have the super duper rare hobbit transmashion
> wooooOoo yea!
Hill climb today, LSR tomorrow! Whoop whoop!
If that's pizza and jerky , it's no wonder he likes you so much . LOL
Charles Cole (OFMC) /
Can't wait for a video of you crushing it out on the street
He stole my pizza bones!
The belts haven’t arrived to test the pulley but I’ve been having fun anyway trying to tune the carbs. I fuck the vids up every time, I need my kids to help.
Rear engine sounds faster!!
Yea! The upside down shit! :)
Madness and Mania
My son was getting seriouS, watching me yank the cables he says Dad how can u stand that sound! (edited)
Totally normal JBOT /
So are both engines going to have no rollers in the variators to basically be static pullies? and then variate off the bottom vari with the pulley that moves?
I'm not quite understanding
Would a vacuum crossover between the carbs and the reeds help with getting them to run in sync?
Never seen that :o
At idle swinging pulley and lever will be held down with springs, the variators fight with 24g rollers in each so far, prolly won’t need that much.. mabe 2-3g in each to swing the pulley up
The foot lever against the swing spring and belt force to launch, wont need as heavy weights since it’s not directly connected to the transmission. Sounds fuN! FucTifIknow
Plus the pulley moves :)
So the bottom pulley assembly swings up when the engine vari's start to variate? To accommodate the shortening belts?
Yup, the 2 engines pull it up about 1” to top out the bell variators, spin the thing fast enuff to top out the Jog pulleys idk
Annnnhhhh!!! Blew the head gasket on the front, started chirping and spitting it out. Found the culprit, the case threads stripped to the stud where it blowed ouT. I gotta tear it down and rethread the sumbich with a 7mm stud, fuc-tit-up
Comes apart easy as any.
The stud may have rattled loose then ripped the threads out. My bad, I shoulda retightened them sooner.
Fickst thaT prOLem tho
Looking at cutting a piece of the skirt out before I put it back together. The other engine is rippin’ with the whole top busted out. I’ll use a hammer like the other guy did. Hammer porting 101
My son sent this NOS video, it’s a dumb 4 stroke but the guy has a CLEAR HEAD. I want some!!
SON-0F-Ahhh
Looks good still, wtf?
The damn thing, thought it snagged a ring and locked up. Na it was only the clutch exploding. :)
It was chomping to bits
Snapped the arm in half like a twig
Looks like you ran it with no bell.
It does !
Fucker popped a hole in the transfer too! :)
Here I go again..
Just pack some jb over that
Sucksafoney
So much for having clean cases!
I brush painted the hole with acid then scuff sanded around to prep it for the alumaweld.
Found this in the junk pile yesterday. A razor scooter brake and treats finger lever.
Does it brake the pulley?
,or the lever?
I made a new foot lever pitman to replace the car bracket. It already had the hook cut in it, I trimmed off the shit, drilled a hole then spiffed it up, rounded the edges, get rid of anything that doesn’t look like a cute wittle moped part..
SSDD
