Re: Fuckin around in the shed
πΏπ‘–π‘˜π‘Ž-πΏπ‘œπ‘‘π‘Žπ‘ π‘Žπ‘’π‘Ÿ π‘€π‘’π‘”π‘Žπ‘π‘’π‘  πŸ¦– /
Tore it down to the plastic tubes, fits the intakes like it was made for it. Wtf!?! cooL
Stator side hobbit mounts combined by a 5/8” spacer to offset the engines.
The other side was easier, I got it tacked good. It’s gonna take a shit load of bolts and nuts for this one. Also cutting a square notch out of the frame using the tile cutter.
Variator side
It fits so far, thinking of lowering the engine and having the pulley as close, line up the rear and work backward.
Tie wired the pipes in. They are the same length for now, it’s going to be a challenge to keep’m.
Patched the tank, The engine is going to be a tight fit, even with the center shifted to the stator side. Sledgehammer!
Proma circus side pipes looks to fit with some modifuckation and fuckery.
Maybe if you time the motors to spark in opposition , you could get away with a single pipe .
That might be a challenge . ;)
YES
YES
MOAR
I feel like the pipe would need to be tuned for twice the actual rpm for that to work. Maybe sync them and run a pipe tuned to total displacement?
Backed up a fuzz.. Straightened up the engine mount. All the bolts tight, engines parallel and level with each other. Welded to the spacer block. I can sheet the bottom and make it a lot stronger and easier to fuck with attaching the pulley.
The thing WANTS to be in there, levitation, it stuck between the heads. I don’t know if that’s good or bad.
Tightened it up, added the intake adapters. Lc head, another one of them’d be neat.
It’s lodged in there all nice and shit wtf!
I love reading this thread.
I gotta get back to building soon.
This is soo good. Evetime I open up this thread it just gets better.
Right on guys I bent up one of the thicker sheets for the bottom, the triangle bearing pillow block fits great so far.
The dual variator pulley pics. Need to check on belt availability, it’s gonna be short!
More pics of the pulley.
Combining the shafts and cheeks, truing it up. The center movable piece is hollow steel like this thing.
It might work if I can get it right oN. I’m going to be spinning it til it’s right. Weld the fuq out of it. I think the 2 other belts would stress it more than the rear pulley belt action. But I’m going to brace the bearing block as good, it’s going to need it every which way !
Neat pulley find and use! :)
I hacked off the junk crank that fits the variator boss I.d. Gotr cleaned up, the cheek diameter fits in the back side of the other cheek nice.
Check the 120mm diameter laying on top, compared to a GY6 pulley. It’s the same thickness of material, only difference is the center. Good to know it’s in the neighborhood of size stuff.
(edited)
It’s all together, I added 4 plug welds, drilled thru the cheek, around the variator boss to lock in the center even more. it’s on there! :)
Now I’m really gonna have to brace the bearing block. and still hope the pulleys line up. Ha :/
But Heck yeaH! That was a big deal.
Looks like I’m gonna have to hack more frame bars, rearrange it for the thing to fit.
Stator side
Belt angle dangle
The pulley height ain’t bad but could be better
I figured out how much the frame needs to move up.
Rear pulley center
Front
Cut out 2” up
Keeping it tight!
Now u know it’s straight up measured
So take the tape and scribe the other bar straight down 2” and it’ll fit when it gets there,
add on 1/8” for birds mouth coping small tubing.
Know whad I mean
If u like it I love it, nail it!
By the time I mount the engine, it should line up.
Fine with me ;)
nom nom noMOPED! UUUuuuuutttT!!
It don’t look like much but I had to slice off another inch, move it forward, tack the frame piece in good. Suspend it in place to check the belt outcome, that’s more like it!
Haduhh turn the head. The pipes were hitting the frame causing it to not move forward.
It is tight fellas.
Moved forward enuff to fit the rear proma header down and out.
Josiah Radebaugh /
I'd really like to see this ripp
SERIOUSLY.....keep this thing moving forward! (edited)
Matching carbs sbrac gnihctaM
Whay started out to be a joke some how got out of hand..!
Damn hobbets now lok whathay dund!
