Re: Fuckin around in the shed
πΏπ‘–π‘˜π‘Ž-πΏπ‘œπ‘‘π‘Žπ‘ π‘Žπ‘’π‘Ÿ π‘€π‘’π‘”π‘Žπ‘π‘’π‘  πŸ¦– /
N do t try to seal the ideaR cuz the CatBox is paintedted.
Hmm , too high and a ladder will be handy . Too low and , well , I wouldn't want to get anything caught in those pulleys and belts . 8/
I call that trifecta the 3 legged squirrel β€˜cause it’s always trying to steal yer nutzz!
That stuff work good on oil spills ? ;)
Alvin and the Chopmunks!
I've the clay kitty litter . Just drop , step and grind it in .
But , the stuff you spilled on your project looks like it might just be chipmunk poop . LOL
The scat is recycled newspaper, I guess they put it thru a meat grinder hahaa
Still haven’t welded anything, a handful of tek screws holding it together. It has the stuffy crank, new seals, cleaned up cylinder with a new piston urban electric. I’ll have an lc head, pump thru this drinking fountain radiator.
More braces across the bottom and stuFF
Best part of the Indian
FUCK YES! I want an Indian frame just to hang on the wall in my garage ha ha.
This is a Jog pulley with the nice twisty go round driven face. I took out the needle bearing to use on the clutch pulley doodad. This sucker fits TIGHT into the pulley, I tried to get it out but it might fuck it up. I’ll smash it back in there, pretty cool fuckin around and get lucky sometimes
> sometimes
A few drops of Astroglide ...
Check iT
Hurry! Hurry! On Sale! hunhΒΏ!?!!
I found it in my dads junk (edited)
Redood the mb5 wheel, disassembled and embedded a Vespa spoke hub then wallered it out to fit the hobbit hub again. Added the Vespa hub, it’s steel and can be welded to the spokes some. The hobbit hub will be drilled and anchored with 4 and 6mm bolts with 3 spacer rod replaced. Way better than it was!
Blast and powder coating gun metal gray would be neat. my wife’s junk
The gear box relies on dual variation so the jack shaft is unnecessary. Fuck it I gotta try it anyway
It only has a shifter for reverse neutral forward position
NeutraL drops!
> Not Sure Wrote:
> The first thing I did to it was hack these 2014 Challenger headlights
> into it. Sawzall shit into a classic! :))
#nothingissacred
> Not Sure Wrote:
> Check iT
Good stuff , that^ .
I have a can of Never-Seez I bought about 3 lifetimes ago . Thick , sticky and doesn't come off anything easily .
Dirty30 Dillon /
When will this thread culminate in a functioning bike.
Or are we doomed to endure madman conniving and experimenting with no Frankenstein's Monster pay-off?
Heck , it's only 26 pages . LOL
I’ll get paid Dillon, getting ready for bolt on shit. Making some barn finds for a minute.
There’s a mini disk welded on, cut it out of the way for a sprocket and larger brakes that stop the transmission to wheels evenly. There’s a lot of little things I do to pass the time, even waste time. I have a damn spinal cord injury so it don’t matter to me at all. This thread is a treat fuck face.
Title of the thread doesn’t say anything complete bikes. fuggin 5 different things going on at once and every minute of it is awesome.
The brake came from a GY6 front wheel punched out and machined with a harbor freight saw tooth blade on the angle grinder. It mauls it up awesome. Gotta hang on to it, scribed and shaved it down to fit in a 35 tooth. The rotor bolted on easy. 12mm axle, I’ll have a set of drop outs for the tension.
That chicken bucket though.. ha
Your lady friend looks thrilled to be there
Her mustang broke and she’s waiting for me to show boring moped stuFF. Good woman!!
Couldn’t earn a KFC patch so.. hah!
The tiny brake pads. Damn
Found a 41” belt in the grass, I think that’s stoc hobbit size. Put it on, kick ass!
Got some things going on but I really like the Sachs motor concoction. Where O’ where does the stock Sachs crank usually break?
Big wheels keep on turning ~
I’m reassembling the shack roof, it came apart easy with a few braces removed but otherwise stood firm for 3 years. A good shelter using overhead concrete deck procederr
2 wooden H girders on top a 4x4 post, outside the shed,
The beam is pieces cobbled together 14’ a post on each end and 1 in the middle. 3 beams like that with the post braces and parallel stay strips, it’s cheap cuz there is no walls hA!
