Re: Fuckin around in the shed
πΏπ‘–π‘˜π‘Ž-πΏπ‘œπ‘‘π‘Žπ‘ π‘Žπ‘’π‘Ÿ π‘€π‘’π‘”π‘Žπ‘π‘’π‘  πŸ¦– /
Whoops! I was digging thru looking at things an realize that I hacked up an old Urban Express clutch.
I found this other one made of baby Swiss. First I shit canned the springs and cut both ends of the arms. Then sawLed it long ways. Drilled the spring holes then shaved it down to the spring tab thickness.
Juss kinda copied off the hobbit specs.
Cut, hacked, drilled, sawed, and shaved. Nice.
Whens the damn video?
Where the squirrels at????
Haven’t seen any, this has been a fun pet. Bear
I finished the clutch apex, welded a couple hardened steel sleeve in then drilled and tapped. 1 hour per hole. I had the metabo on hand to sharpen the bit about 20 times but it all went thru and is threaded with the 4mm set screws.
The stock hobbit arms weigh 54g. A lot lighter than the urban, prolly cuz its on the crank.
I plowed a bunch off the urban arms to 54g each, from 133g.
The clutch then a spacer then the 2 bearings for the vario. The needles spin great.
Both bell pulleys have no internals.
With the clutch
It’d be neat if it works!
The wheel is about done too, a few bolts and stuff.
Purged and bled the brake. Cleaned it up as good with a fine wire wheel. The double piston caliper was covered in a black rubbery coating, looked like liquid electric tape painted on half of the outside surface. Scrubbed that crap off. I’ll prolly spray a little clear across it to hold off the rust.
The 12mm axle is ready, had to run a dye to extend the threads up the rod an inch or so. A lot better than the dumb 10mm axle concoction that came with it.
Heck yeah, I guessed to advance the stator 45*, right on the money.
Took it apart and drilled holes to hold the stator in the new position.
Fire!
I bolted it back onto the subframe, hookt up a fuel bottle and took it outside. The engine fired up after putting my hand over the carb. Sounds fine, the largest jet I have on hand is an OKO 138, :/ CooL!
The carb had a 102 jet, it’s starting great and running with a 126. Without the damn pipe hahaa! Almost finished the pipe tho won’t be long.
Smoke β€˜em if u got β€˜em
I'm excited!!!
Very curious how that clutch will work. When I tried a rear clutch on a crank and it acted like shit due to the arm weight.
But you are smarter will probably make it work by sheer force of will.
I think the lightening like you did should prob work great (edited)
Yeah the clutch should be interesting. I hope it don’t snap after mauling 80g off each arm. I drawed the line where I thought it it could skinny up and made sections to copy the amount to each arm. Using the scale to check them I wrote down the weight of each area removed until the total arm was 54g and shaped more hobbitish. Mabe that’s what the issue was with the scoot arms, too heavy being directly on the crank as opposed to the way it is on a scoot. The front vario and flywheel momentum with the belt, rear pulley and clutch weight prolly requires heavy arms. I’m guessing..
This ol’Tecumseh magneto had a huge flywheel for jamming snow. like 6-7” I thunk
Yeah what u said!
WorKing on a back-up plan in case it’s too slow.
Umm , you might have to change the frame a little . LOL
science.
square 4?
Quad variation.
You consistently manage to succeed where others have only dreamed, by sheer force of will. Making the impossible work on the already impossible, with time, determination and basically no special tools, that's what makes this so incredibly powerful - you're truly an inspiration to us all.
Just gotta be clever, and go do it. stop overthinking it. i love this thread. i just wanna say thank you.
I’m glad u approve!
Check out the front kit.
The wheels alright, a few bolts for the forks and take a looksee at the brace length for the ride height stuff.
With the wheel dropout thing
Thanks back to you Will! you’re welcome guys, check iT
Somatimes I maka MopEd MascheeNny
Replacing the Taiwanese stem with beefier chinesium steel. Getting our shit bacK
