Re: Fuckin around in the shed
Talk about a power edger ... ;)
So it cuts grass and edges?! Hell yeah.
πΏπ‘–π‘˜π‘Ž-πΏπ‘œπ‘‘π‘Žπ‘ π‘Žπ‘’π‘Ÿ π‘€π‘’π‘”π‘Žπ‘π‘’π‘  πŸ¦– /
Not too shabby, the Urban stator, Razz flywheel, and Jog box. It all fits in there nice. Replaced every stator wire. ,With everything bolted tight and the wires spayed, the thing sparks like a champion only it’s an NGK. Heck yeah, now to see if it’s on time..
Careful ... that^ could start a fire . ;)
Not on time, FUCK!n shit caN
The light shows I bolted it down 45* too far retarded. It sounds great cranking over! Swished around a cap of 2T in the chamber. When the oil lined the cylinder even it was noticeably super smooth like wanting to start smooth.
Here’s what I fucked up, pointing down is where it needs adjusted to.
Disassemble drill and tap 2 6mm holes on the new layout, try again. The stator base has a little wiggle room for fine tuning.
bionic eye @ 45* ;/
Flywheel and case stamped and notched. The lower marker lines are the timing light pick up. Timing light hell yeah! Still gotta move the sumbich
WeLL i’m glad I didn’t weld the stator studs!
CHECK IT
Crazy Wayme mails to me a 9 port eckshaust tip!
U can aim them at people.
The cone in there maked it do donuts
Wocket!
Hosing it down for the LC kit.
Ran out of hose clamps Damn
where the hell do you get all this shit. I do have a noodly octopus tip made of spare Swagelok tobing that I'm waiting for the right bike to stick it onto...
Maybe he lives next door to a recycle facility ? ;)
The octo-exhaust is the greatest thing I've seen all month.
I have a few scouts on the look out for moped size pieces.
I went and cleaned up the joint. Moved some stuff out so I could get thru. Then olWaynker calls me and tells me the praformance mod so I got it. Says, this will rip ur dick off??
She’s good and craptized with the dog, a ruff weekend.
I can't quite figure out what I'm seeing there? Please don't tell me it's totalled.
Here is the mod. I kinda see what he’s talking about..
Still setting it up. He says it’ll double paddle easier when it blows up. DickheaD
I logged in just to check on this and jbots progress after talking to CW for like 3 hours.
Y’all Rule
Haterz droll
Can't get off the phone with that loon. Haha.
I know you're looking at this post too Wayne, you narsissistic nut.
Haha.
DONT CALL ME NOW
Wayne u fucked it up! I told u I don’t have speaker phone. Now something is rattling around loose in there, I can hear it.
I started the moped after reassembly with the top secret mods. The thing went nuts in a reverse wheelie and bucked me over the handlebars.
What timing chain are u talking about? I don’t see it..
The moped tied to the plywood on the layout, straight, plumb and level. 45” wheelbase and 29” seat height. Finally ready to melt it down!
The electric bed motor picked it up no problem. I had to clamp the lift cable brake with visestrips to stop it from slipping. A fuzz too heavy, it would stop itself, the plywood about 6” from the floor.
Magical flying ped . ;)
Flying plywood and exploding prayer rugs. Prophets are going thru the roof!
I grabbed the cardboard sheets to build an air diversion from the heat/ac fan and opened the attic door to let the smoke out the ridge vent.
It don’t take long to smoke up the top half the room. Fuk that shit!
Been there . Welding smoke ain't much good .
All this work and you're using a land-line? You so crazy.
Nice welding jig though. The sub-projects are masterpieces unto themselves.
Thanks buddy! That was nice.
Heat and hammer to close the gap, it was fine.
Have to take a minute and build some heavier duty cymbal stands. My wife on drums is like Cyborg. Crushes everything!
And the list of things to have ready for the marriage. Ha!
Good thinking ideaR, im going to try this welding compound.
Ha . It just might . They say it eats odors , so ??? LOL
I went with a 36" fan under the garage door with some sheet wood along side . Opened the windows on the other side of the shop .
Worked great , but left the snow beyond the fan kinda discolored . ;)
I was going good on the front end and I didn’t want to finish too soon I guess. I stacked up a little pile of the GY6 left over junk to see if I could fit it. What do u thinK?
clutch, bell, with tjt and plate
Stock
GY6
Hacked the arms into a shape that uses these other springs. There’s a few more spots im going to dremel to fit it a fuzz better, chomped a bunch!
GY6
