Re: Fuckin around in the shed
> Sçütaur RackΔ™t Wrote:
> Figured out how to make pop tarts taste goOd
That's not possible , is it ? LOL
^ Scraping the nasty frosting off helps.
im gonna go eat a poptart
Ben Premenko /
Yeah so hows the actual build going?
DrGeorgeTompson (Alan) /
I am pretty sure the squirrels got him. RIP
I finished this can of nuts today and for some reason i thought about this thread.
Mikey Antonakakis /
My friend told me a good story about a black squirrel today, it was pretty metal. Apparently a guy he knows had a fire pit going, fire died, cooled down, etc., and he went to clean it out. Reached in to grab a chunk of burnt wood/charcoal to throw away, turns out it was a live black squirrel. I don't think either of them were happy about it.
^^^^^^^^^^^^^^^^^^^ Hahahahhhahahha well played Blaine!
You need a new hobby.
Have you ever considered taxidermy?
(edited)
Show us the double hobbit!!
you're nuts. that's why squirrels like you. figured it out.
Josiah Radebaugh /
^^Somethin like that (edited)
Ungapped rings to bind them all /
So squirrel girl stops by one night after she was out drinking with her friends and she wants a nut. So she's down on her knees doin' 90 degrees and you're just about to giver a nut.... and she jumps up and says she has to go home to feed her cats. So yeah, this thread is like that. :(
^ hahahahaha
πΏπ‘–π‘˜π‘Ž-πΏπ‘œπ‘‘π‘Žπ‘ π‘Žπ‘’π‘Ÿ π‘€π‘’π‘”π‘Žπ‘π‘’π‘  πŸ¦– /
I ran out of film.
That's nice
The rings went good. It’s back together now, I burred away the skirt to pass the gas. It will have a spigot threaded on the intake. Some of the exhaust header is figured out.
I’m on this horrible meds for 2 1/2 more weeks. It fucking SUCKS! Nervous system and brain funkshun meds yuck
A couple pivot mount pics. I’m finishing it up with the shocks then hacking into the forks department.
Sweet!! Did you spray engine with ACE BBQ paint or Mexi chrome?
That would be for fun stick, I have a pc oven that will fit your entire body.
Hell Mick, I forgot to melt the shit on there when it was apart. I wanted to do this icy black. Glad u remembered. :)
Theres going to be lots of engine space for this little sucker
Some of the pull start pieces, from the snow blower setup
Best thing ever to pop out a vagina?? A flat slide with power jet!!!! What size is dat?
So stoked ur back!!
It’s a D slide OKO 24 powerjet. The powerjet hose needs replaced. A Keihin knockoff.
The bowl rolls off and on. If ya try to put it on like any other carb, it turns into a rubicks cube quick.
Do powerjets help at all? I've never run one
It’s built into the carb. The nips and hose bypasses the jet at WOT squirts direct down the throat. See if there is passages on your carb clogged off that can be drilled. The stem from the bowl to the venturi.
The 24mm has it, the 21mm has the same casting
Hose it down Jbot
And adjust the venturi to draw it out
