Yamaha Chappy - MLM Exhausts fitting on LB50 with footbrake
Hi there fellow Chappy lovers.
I have a 3-speed semi automatic 50cc Yamaha Chappy from 1979.
And as i browsed though https://www.treatland.tv I saw the following MLM exhausts:
- https://www.treatland.tv/MLM-yamaha-lb80-CHAPPY-people-s-pipe-p/mlm-chappy-pipe-907.htm
- https://www.treatland.tv/MLM-yamaha-lb80-CHAPPY-SCORPION-pipe-p/mlm-chappy-pipe-401026.htm
There is a couple of variations of the Chappy model so I wonder if anyone had this mounted on a model with a similar design as mine (see attachment).
The path of the exhaust is quite narrow.
I would also love to see photos of your Chappys with ant of the MLM exhaust mounted.
Kind regards,
Olle from Sweden
Re: Yamaha Chappy - MLM Exhausts fitting on LB50 with footbrake
Did you ever end up ordering on of those MLM pipes? I just bought a LB80 and I was wondering if you followed up on this? I plan on ordering the People's Pipe this week
Olle Jacobsen /
I did write a blog post about it. It fitted perfectly. The post is in Swedish but there are some images.
https://semestergas.se/mlm-scorpio-for-chappy/
