505/1D with tomos CDI
Full Tuck /
I have a sachs 505/1D. Need to set + test timing. Need to convert mm BTDC to degrees... surely someone has already done this... halp?
With no woodruff key, setting the timing is a total crapshoot with the spark plug 45 degrees off parallel with the cylinder
Click here to login.
