Morini Mo2 power increase help
hey yall so ive been running the same set up on my commuter with a morini mo2 and am now looking for what to do to get more power out of it. all I have done to it so far is a metrakit mk3 exhaust, larger rear sprocket, and some ignition timing tuning. Would upjetting be a good next step or would getting a 60cc kit be a good choice? Im really looking to get a little bit more low end to make it handle hills much better.
Re: Morini Mo2 power increase help
go for the cylinder. also make sure you pull the pipe apart and shorten the tube inside the pipe then re weld it .
This! even with a kit that pipe sucks until you fix it, here is a how to video video: https://www.instagram.com/p/BSEDMjLjeQp/?taken-by=toledo_riot
