Re: Woodruff Key Removal
jumpsuit steve /
recently pulled one using a dremel to slice into the center with a dremel. i ground the thin cutoff wheels until the diameter was appropriate, and dove in far enough to relieve pressure from the sides.
without hitting the crank.
freshly flush ground end nippers helped heaps
