E50 70cc dmp mods
Hi im currently running a e50 with 70cc dmp. Was gonna have a go at a slight port.nothing fancy.
Plans are..
Transfer match.
1 to 2 mm off piston skirt on intake.
Mat h manifolds to ports.
Possibly open ports by 2mm.
What are your thoughts?
Re: E50 70cc dmp mods
Probably Fred /
What ignition?
What pipe?
What carb/intake?
What gearing?
What clutch?
Just widen exhaust....
And be sure ring clears ex. port at BDC and reaches deck at TDC first...
Standard points ignition,External condenser.
17mm bing carb and manifold.
Standard gearing for now 16-45 . What would you recommend?
3 shoe clutch with blue spring.
Akrapovic exhaust.
18 x 45 or 16 x 40 are identical but pretty good...
> Paul Nickson Wrote:
> Akrapovic exhaust.
Really?
Before you do anything get yourself an expansion chamber pipe.....not kidding...
Iv tried to upload a photo but for some reason it wont?!
My exhaust has an expansion chamber but towards the rear before baffle.
That any good?
Or are chambers straight off cylinder best?
I neef to see the Akrapovic exhaust.
I can't upload a photos!?
it looks just like a biturbo.
I like the look of the circuit exhausts which style is best
They don't even list one!
Either out if production or someone has just stickered it up.
Right I've just port matched my kit. Trimmed about 5mm off base of cylinder hanging over transfer port.
Opened up the intake and exhaust without altering the ports.
Trimmed 1mm off piston skirt.
And opened up the inlet manifold as far as I could to reduce the 90deg angle
Been for a test run.
It pulled miles better! Booom
Treatland has pipes...and every other part you could possibly need....
Probably Fred /
> angle
It boomed ?
timothy rendall /
for a pipe go ave a look at 'PUCHSHOP.De' if your going to big bore and non legal
try on of these
http://www.puchshop.de/puch-engine-parts/puch-exhaust-parts/homoet-p6.html
