Poor Boy Peugeot Cases - TSM or Teknix ???
https://www.treatland.tv/peugeot-teknix-engine-case-p/peugeot-case-complete-set.htm
https://www.treatland.tv/ProductDetails.asp?ProductCode=peugeot-BIG-BOY-engine-case&CartID=3
Which and why? Goona get some hot boy cases at some point but not quite yet. My stock cases are fucked so I need something in the mean time.
Whats the deal?
Re: Poor Boy Peugeot Cases - TSM or Teknix ???
I'm pretty sure the "big boy" case is for the 80cc cyl on treats, it fits 54mm skirts
I have a teknix case, haven't run it on anything yet, not a whole lot of meat for opening up transfers, but the quality looks pretty good
What's wrong with your stock case? Not too hard to add third transfer for aftermarket cylinder
The tsm case won't have a third transfer.
#CrazyWane rocks # Crazy Wayne /
I've had several pugs over the years.
Are you just looking for a case to transfer your parts over to.
Some performance kits require the third port in that case some don't.
Then you will be fine with the Teknix.
If you wanted to go big and go fast, I would get the Pollini or malossi cases. (edited)
Just get the malossi. Teknix are garbage.
