Puch e50 kickstart
Germano Assuncao /
Hi y'all,
I have a Puch Magnum MKii witt a e50 Engineer.
I'm want get a kickstart kit.
What are the exactly items I need for it?
Anyone can help with a list?
Thank you
Re: Puch e50 kickstart
Kickstart cases, clutch bell, clutch and then the rest of your E-50 parts should swap over I believe.
Probably Fred /
Just get a kickstart engine because in addition to all the stuff above you need the kickstart unit too.
They have a kickstart unit that works with regular cases all you have to do is bore some holes but those are hard to fine
Germano Assuncao /
Probably Fred /
> Germano Assuncao Wrote:
> How about the start?
> anyone know if this one works?
> https://www.treatland.tv/suzuki-fa50-OEM-kick-start-shaft-p/suzuki-kick-shaft-26210-02310.htm
No you need a whole different engine
Or this unit plus a kickstart clutch
As well as drilling holes and mounting shimming the unit correctly to your engine
NO.....It is not that easy..... Fast Arrow conversion...or...another engine itself...
Yeah a pullstart would be easier
with the fast arrow kit you use a standard e50 clutch.
Yes to what Andrew said. Easier, simpler, cheaper ,faster, better to maintain.
You will want to do this. Puch E50 pull kit
Am I going to hell? (edited)
> maintain.
> https://www.treatland.tv/v/vspfiles/photos/cheetah-E50-pull-start-unit-2T.jpg
I've got a couple kickstart e50, they are great if complete and in spec but can be a pain to find parts sometimes. I just installed one of the kits from cheetah on a customer bike and I have to agree with him.
Kick starting a bike looks 100% cooler then pull starting though.
You can say that two times.
I personally like the pullstart over the kickstart. Here's some one in Europe with a few kick start engines for sale. https://www.mopedarmy.com/forums/read.php?2,4145140,4145210#msg-4145210
Not hating on Will Jansen, but i could get you a kickstart engine (not rebuilt) for a lot less than 260$
I hate kickstart engines myself, i'd rather push start for 1 meter than kickstart and by god hope it works.
Must be nice. I've never ridden a bike that hasn't stalled out at some point. Trying to push start a bike in traffic is not only humiliating but extremely dangerous around here. God help anyone not moving when the light turns green.
