TOMOS crank shims
Jeroem Sindaco /
Treatland has A35/A55 crank shims. Will these work in an A3? I see where it is fairly common to install an A35 crank in an A3 case. They told me to ask here to find out.
Re: TOMOS crank shims
i just wrote a post on this in another thread, some cases you can, some you cant, either way you have to replace all your clutches and gears to A35.
its generally not worth it.
you can press an a35 rod into an a3 crank, that is the way to go.
Jeroem Sindaco /
Thanks for the reply. Do you really mean it that a shim would necessitate a xmsn overhaul? I think you mean that the crank necessitates clutch replacement. I know how you guys like to joke around, but thanks anyway...
I ain't had citrus for a month, and I'm RARIN' for a kill /
How did that work out for you?
Mike Pizzarowski /
Mopedcrankworks.com
Want to reply to this thread?
