Doppler Spring Death Wobble
On deceleration, I get a horrible wobble. I think it's the amount of tension on my Doppler spring. Here's my setup:
Er3 variator with two heavy and two medium weights.
Doppler red spring
Polini cases
Polini 70 W liquid cooled kit
Malossi swing arm
Doppler clutch pulley with Tomahawk braces
I have let a ton of tension off the spring because I have been told they are strong. I have also read on the wiki that lack of tension will cause the variator to bounce. I have screwed with the tension up and down and it still wobbles.
Any ideas? I don't have much room to "loosen" any more.
Thanks. (edited)
Re: Doppler Spring Death Wobble
It's called bounce, and it's from the spring being too loose.
Tighten it up, or run a launch lever and plant your foot on it to stop the bounce
Or also rig a damper to smooth the bounce like a shock absorber.
its over run from your clutch pulley. kinda terrifying on the track, slotting and balancing the shoes seems to help. the doppler spring shouldn't be too stiff for most set-ups, i've run into the issue where it takes heavier weights to get it to max var, but with a lunch lever this is no issue and is actually very cool to have a mellow tune on the variator.
Marcus Pimentel /
how'd you mount up the spring to the malossi swing arm? Pics?
yeah pics
