Chain tensioner
Does anyone have a solution to the garbage stock chain tensioners on a puch? Should I just delete it?
Re: Chain tensioner
You can get rid of it but then if the drive chain stretches at all you may have a hard time getting both tight without breaking the chains....but I run one of my bikes with no pedal chain and just bump start it
Re: Chain tensioner
Joe Peloquin /
I like the thought of still having the option to pedal like a bike. I'm for sure going to have to bump start it, no way I can pedal start this beast. But I can't have this stupid tensioner binding up and if I delete it i don't want the chain loose enough to possibly fall off while blasting
Re: Chain tensioner
Skateboard wheel.
Re: Chain tensioner
> it?
Upload some pics baby! They make a few different kinds. I had one that I thought was junk also but I rigged it up & made it work for two years before putting on a bike i sold. (edited)
Re: Chain tensioner
Not sure what the issue is with yours. They work just fine on all of my puchs.
Is it bent out of alignment, or the bearings dried up in the idler sprocket, or is the spring broken?
Re: Chain tensioner
Charles McCusker /
i got the one off treats to replace my busted original one.i had to tweak it and the chain guide a little, but once i got it dialed in, it's worked very well.
