multimeter puch cdi
I want to test this treats puch cdi before i install it, running it with a pietcard 2041 box and olympia coil. What should everything be reading? i thought this info was somewhere in the wiki but i can't find it.
Re: multimeter puch cdi
Did you ever have any luck figuring this out?
the coil should be like 2-5 ohms from the 'hot' wire to ground, that is usually what goes bad on them
cdi boxes... i dunno how to test em' i usually just do process of elimination with coil resistances.
