Re: Have ye seen deez Sachs Clutch disks
DrGeorgeTompson (Alan) /
I've racked up about 30 miles so far and i am NOT taking it easy. Well, i am when shifting (sometimes i go ham here) and when starting from a stop kinda, but other than that it's pretty much WOT all the time cause it's a moped and i don't have time to be a little bitch. I initially jetted based on a friends 74cc Puch Gila tune with the same carb but I think the main jet is still too lean @ 140 currently. I am gradually approaching the stock tm24 jetting @160. Temps are much better and peaked around 375 -385 now. I forgot to reset the trail tech. More work to come.
Clutch is stronger than the smell of 1000 babies diapers so far. Other things not so much, but they will get better as they fail and i make them better.
My rear sprocket lost a bolt and the other 3 were 80% out by the time i got to my destination/ noticed. I put the wheel together in like january and didn't threadlock it if i recall and haven't really toched it since.
It's funny cause it looked at the bolts right before i left (like just looked at them, didn't try to tighten them or anything) and was like "meh" and began my journey.
My axle tensioners are tripple nutted cause they kept coming off. The theme of this build 2 nuts on everything it seems haha!
skinee puppy Wrote:
> hole' hell on that gear combo i bet it takes a
> long time to get to speed. i would drop the front
> down 1 tooth and just change the rear so you will
> gain some torque
to hell with that. I promise you it is rather quick for being such a tall gear ratio. It REEALLY screams when it gets up on the the pipe in first gear. The carb is massive for one of these motors. I don't think i've ever seen such an insanely equipped Sachs.
My biggest problem is not letting the clutch slip enough to have the bike move from a stop lol. I'm pretty much a scrub when it comes to clutched bikes, and the tall gearing is rather unforgiving.
That and it tends to miss going into second gear via spring tension. I think i will use WillD's extra spring method. That should help a good bit. Also, i (or someone else) might have dropped my crank and knocked it out of true; the perks of sharing a workspace with others. The bike vibrates a LOT in 1st when it gets up in the revs and it kinda spooks me from really revving it out.
I'll probably drop the motor and look at it at some point since the right side pedal o-ring is also leaking transmission fluid even though i replaced it with OEM parts. Though i don't think i saw a puddle yesterday when i took it out so maybe not.
Baron Von Hamilton Wrote:
> Good thread!
^__^(edited)
  Have ye seen deez Sachs Clutch disksTopic by: DrGeorgeTompson (Alan) DrGeorgeTompson (Alan) 05/10/17 12:00PM
  Re: Have ye seen deez Sachs Clutch disksRe: MPB Andyrew MPB Andyrew 05/10/17 01:01PM
  Re: Have ye seen deez Sachs Clutch disksRe: Cpt. F. Cpt. F. 05/10/17 01:08PM
  Re: Have ye seen deez Sachs Clutch disksRe: DrGeorgeTompson (Alan) DrGeorgeTompson (Alan) 05/10/17 01:14PM
  Re: Have ye seen deez Sachs Clutch disksRe: Born to be WillD Born to be WillD 05/10/17 01:42PM
  Re: Have ye seen deez Sachs Clutch disksRe: DrGeorgeTompson (Alan) DrGeorgeTompson (Alan) 05/10/17 01:55PM
  Re: Have ye seen deez Sachs Clutch disksRe: Born to be WillD Born to be WillD 05/10/17 05:45PM
  Re: Have ye seen deez Sachs Clutch disksRe: DrGeorgeTompson (Alan) DrGeorgeTompson (Alan) 05/11/17 02:30AM
  Re: Have ye seen deez Sachs Clutch disksRe: Born to be WillD Born to be WillD 05/11/17 09:13AM
  Re: Have ye seen deez Sachs Clutch disksRe: DrGeorgeTompson (Alan) DrGeorgeTompson (Alan) 05/11/17 12:01PM
  Re: Have ye seen deez Sachs Clutch disksRe: DrGeorgeTompson (Alan) DrGeorgeTompson (Alan) 05/11/17 12:07PM
  Re: Have ye seen deez Sachs Clutch disksRe: Born to be WillD Born to be WillD 05/11/17 09:54PM
  Re: Have ye seen deez Sachs Clutch disksRe: MPB Andyrew MPB Andyrew 05/10/17 03:29PM
  Re: Have ye seen deez Sachs Clutch disksRe: DrGeorgeTompson (Alan) DrGeorgeTompson (Alan) 05/10/17 03:31PM
  Re: Have ye seen deez Sachs Clutch disksRe: ♣Slew Foot♣ ♣Slew Foot♣ 05/24/17 03:05PM
  Re: Have ye seen deez Sachs Clutch disksRe: DrGeorgeTompson (Alan) DrGeorgeTompson (Alan) 05/24/17 03:10PM
  Re: Have ye seen deez Sachs Clutch disksRe: MPB Andyrew MPB Andyrew 05/24/17 05:38PM
  Re: Have ye seen deez Sachs Clutch disksRe: DrGeorgeTompson (Alan) DrGeorgeTompson (Alan) 05/25/17 10:06AM
  Re: Have ye seen deez Sachs Clutch disksRe: Born to be WillD Born to be WillD 05/25/17 03:47PM
  Re: Have ye seen deez Sachs Clutch disksRe: DrGeorgeTompson (Alan) DrGeorgeTompson (Alan) 05/25/17 03:48PM
  Re: Have ye seen deez Sachs Clutch disksRe: Born to be WillD Born to be WillD 06/03/17 08:52AM
  Re: Have ye seen deez Sachs Clutch disksRe: DrGeorgeTompson (Alan) DrGeorgeTompson (Alan) 06/05/17 11:40AM
  Re: Have ye seen deez Sachs Clutch disksRe: DrGeorgeTompson (Alan) DrGeorgeTompson (Alan) 05/26/17 08:09PM
  Re: Have ye seen deez Sachs Clutch disksRe: Graham Motzing Graham Motzing 05/24/17 04:26PM
  Re: Have ye seen deez Sachs Clutch disksRe: DrGeorgeTompson (Alan) DrGeorgeTompson (Alan) 05/24/17 04:52PM
  Re: Have ye seen deez Sachs Clutch disksRe: DrGeorgeTompson (Alan) DrGeorgeTompson (Alan) 05/25/17 10:19AM
  Re: Have ye seen deez Sachs Clutch disksRe: skinee puppy skinee puppy 06/06/17 04:43PM
  Re: Have ye seen deez Sachs Clutch disksRe: DrGeorgeTompson (Alan) DrGeorgeTompson (Alan) 06/06/17 04:54PM
  Re: Have ye seen deez Sachs Clutch disksRe: - Dacruzer - - Dacruzer - 06/29/17 06:15PM
  Re: Have ye seen deez Sachs Clutch disksRe: MPB Andyrew MPB Andyrew 06/06/17 05:47PM
  Re: Have ye seen deez Sachs Clutch disksRe: MPB Andyrew MPB Andyrew 06/06/17 05:52PM
  Re: Have ye seen deez Sachs Clutch disksRe: skinee puppy skinee puppy 06/07/17 12:29PM
  Re: Have ye seen deez Sachs Clutch disksRe: DrGeorgeTompson (Alan) DrGeorgeTompson (Alan) 06/07/17 12:46PM
  Re: Have ye seen deez Sachs Clutch disksRe: ♣Slew Foot♣ ♣Slew Foot♣ 07/10/17 09:55AM
  Re: Have ye seen deez Sachs Clutch disksRe: MPB Andyrew MPB Andyrew 07/10/17 01:57PM
  Re: Have ye seen deez Sachs Clutch disksRe: DrGeorgeTompson (Alan) DrGeorgeTompson (Alan) 07/10/17 02:00PM
  Re: Have ye seen deez Sachs Clutch disksRe: skinee puppy skinee puppy 06/07/17 02:54PM
  Re: Have ye seen deez Sachs Clutch disksRe: CtpEDsHED . CtpEDsHED . 06/12/17 04:02AM
  Re: Have ye seen deez Sachs Clutch disksRe: DrGeorgeTompson (Alan) DrGeorgeTompson (Alan) 06/12/17 09:32AM
  Re: Have ye seen deez Sachs Clutch disksRe: DrGeorgeTompson (Alan) DrGeorgeTompson (Alan) 06/22/17 10:16AM
  Re: Have ye seen deez Sachs Clutch disksRe: MPB Andyrew MPB Andyrew 06/22/17 12:38PM
  Re: Have ye seen deez Sachs Clutch disksRe: DrGeorgeTompson (Alan) DrGeorgeTompson (Alan) 06/22/17 01:20PM
  Re: Have ye seen deez Sachs Clutch disksRe: MPB Andyrew MPB Andyrew 06/22/17 01:51PM
  Re: Have ye seen deez Sachs Clutch disksRe: skinee puppy skinee puppy 06/23/17 07:51PM
  Re: Have ye seen deez Sachs Clutch disksRe: DrGeorgeTompson (Alan) DrGeorgeTompson (Alan) 06/23/17 08:25PM
  Re: Have ye seen deez Sachs Clutch disksRe: skinee puppy skinee puppy 06/27/17 03:47PM
  Re: Have ye seen deez Sachs Clutch disksRe: DrGeorgeTompson (Alan) DrGeorgeTompson (Alan) 06/27/17 03:49PM
  Re: Have ye seen deez Sachs Clutch disksRe: skinee puppy skinee puppy 06/27/17 04:24PM
  Re: Have ye seen deez Sachs Clutch disksRe: DrGeorgeTompson (Alan) DrGeorgeTompson (Alan) 07/10/17 10:21AM
  Re: Have ye seen deez Sachs Clutch disksRe: DrGeorgeTompson (Alan) DrGeorgeTompson (Alan) 07/13/17 02:54PM
  Re: Have ye seen deez Sachs Clutch disksRe: DrGeorgeTompson (Alan) DrGeorgeTompson (Alan) 08/16/17 10:46AM
  Re: Have ye seen deez Sachs Clutch disksRe: Born to be WillD Born to be WillD 08/17/17 05:25PM
  Re: Have ye seen deez Sachs Clutch disksRe: skinee puppy skinee puppy 08/17/17 03:35PM
  Re: Have ye seen deez Sachs Clutch disksRe: DrGeorgeTompson (Alan) DrGeorgeTompson (Alan) 08/17/17 03:37PM
  Re: Have ye seen deez Sachs Clutch disksRe: skinee puppy skinee puppy 08/17/17 04:09PM
  Re: Have ye seen deez Sachs Clutch disksRe: DrGeorgeTompson (Alan) DrGeorgeTompson (Alan) 08/26/17 05:21PM
  Re: Have ye seen deez Sachs Clutch disksRe: DrGeorgeTompson (Alan) DrGeorgeTompson (Alan) 08/27/17 11:01PM
  Re: Have ye seen deez Sachs Clutch disksRe: DrGeorgeTompson (Alan) DrGeorgeTompson (Alan) 08/28/17 07:11PM
  Re: Have ye seen deez Sachs Clutch disksRe: DrGeorgeTompson (Alan) DrGeorgeTompson (Alan) 08/29/17 10:49AM
  Re: Have ye seen deez Sachs Clutch disksRe: MPB Andyrew MPB Andyrew 08/29/17 03:30PM
  Re: Have ye seen deez Sachs Clutch disksRe: skinee puppy skinee puppy 08/29/17 04:34PM
  Re: Have ye seen deez Sachs Clutch disksRe: DrGeorgeTompson (Alan) DrGeorgeTompson (Alan) 08/29/17 04:39PM
  Re: Have ye seen deez Sachs Clutch disksRe: skinee puppy skinee puppy 08/30/17 01:17PM
  Re: Have ye seen deez Sachs Clutch disksRe: DrGeorgeTompson (Alan) DrGeorgeTompson (Alan) 08/31/17 01:12PM
  Re: Have ye seen deez Sachs Clutch disksRe: EH FCC of the QCB EH FCC of the QCB 08/30/17 09:53PM
  Re: Have ye seen deez Sachs Clutch disksRe: Born to be WillD Born to be WillD 08/31/17 01:54PM
  Re: Have ye seen deez Sachs Clutch disksRe: DrGeorgeTompson (Alan) DrGeorgeTompson (Alan) 08/31/17 01:57PM
  Re: Have ye seen deez Sachs Clutch disksRe: Axldeziak . Axldeziak . 08/31/17 02:19PM
  Re: Have ye seen deez Sachs Clutch disksRe: DrGeorgeTompson (Alan) DrGeorgeTompson (Alan) 08/31/17 02:23PM
  Re: Have ye seen deez Sachs Clutch disksRe: MPB Andyrew MPB Andyrew 08/31/17 04:50PM
  Re: Have ye seen deez Sachs Clutch disksRe: Born to be WillD Born to be WillD 09/01/17 02:44PM
  Re: Have ye seen deez Sachs Clutch disksRe: skinee puppy skinee puppy 09/01/17 02:26PM
  Re: Have ye seen deez Sachs Clutch disksRe: Neil Shaddox Neil Shaddox 09/20/17 11:22AM
  Re: Have ye seen deez Sachs Clutch disksRe: DrGeorgeTompson (Alan) DrGeorgeTompson (Alan) 09/20/17 12:11PM
  Re: Have ye seen deez Sachs Clutch disksRe: DrGeorgeTompson (Alan) DrGeorgeTompson (Alan) 11/20/17 04:38PM
  Re: Have ye seen deez Sachs Clutch disksRe: Born to be WillD Born to be WillD 11/20/17 09:55PM
  Re: Have ye seen deez Sachs Clutch disksRe: DrGeorgeTompson (Alan) DrGeorgeTompson (Alan) 11/21/17 10:39AM
  Re: Have ye seen deez Sachs Clutch disksRe: Born to be WillD Born to be WillD 11/26/17 10:40AM
  Re: Have ye seen deez Sachs Clutch disksRe: P D P D 11/26/17 12:02PM
  Re: Have ye seen deez Sachs Clutch disksRe: Born to be WillD Born to be WillD 11/27/17 01:44PM
  Re: Have ye seen deez Sachs Clutch disksRe: P D P D 11/27/17 09:42PM
  Re: Have ye seen deez Sachs Clutch disksRe: DrGeorgeTompson (Alan) DrGeorgeTompson (Alan) 03/09/19 07:40AM
  Re: Have ye seen deez Sachs Clutch disksRe: DrGeorgeTompson (Alan) DrGeorgeTompson (Alan) 09/21/17 01:44PM
  Re: Have ye seen deez Sachs Clutch disksRe: skinee puppy skinee puppy 11/21/17 02:50PM
  Re: Have ye seen deez Sachs Clutch disksRe: DrGeorgeTompson (Alan) DrGeorgeTompson (Alan) 11/21/17 03:01PM
  Re: Have ye seen deez Sachs Clutch disksRe: skinee puppy skinee puppy 12/13/17 05:26PM
  Re: Have ye seen deez Sachs Clutch disksRe: DrGeorgeTompson (Alan) DrGeorgeTompson (Alan) 03/09/19 02:13PM
  Re: Have ye seen deez Sachs Clutch disksRe: Daniel '' Daniel '' 03/09/19 06:35PM
  Re: Have ye seen deez Sachs Clutch disksRe: MPB Andyrew MPB Andyrew 03/11/19 10:11AM
  Re: Have ye seen deez Sachs Clutch disksRe: DrGeorgeTompson (Alan) DrGeorgeTompson (Alan) 03/11/19 10:26AM
  Re: Have ye seen deez Sachs Clutch disksRe: Chris Squid Chris Squid 03/11/19 05:53PM
  Re: Have ye seen deez Sachs Clutch disksRe: Born to be WillD Born to be WillD 03/14/19 10:32AM
  Re: Have ye seen deez Sachs Clutch disksRe: DrGeorgeTompson (Alan) DrGeorgeTompson (Alan) 03/14/19 11:17AM
