Re: Have ye seen deez Sachs Clutch disks
DrGeorgeTompson (Alan) /
So here is what actually fits and works quite well. didn't spin the nut off yet and holds the power really well so far.
-outer bell-lookin' nipple piece (11). I did turn this down maybe a mm. It's pretty hard and a pain to work with.
-Nut (2 jammed) (m10x1.00x5.00 Thin nuts)
-One of these. Had to grind the round part down a bit. was too big. I guess any thinner washer that covers the splined jobby would do.
-1.7mm disc (16)
-3.2mm pad (18)
-1.7mm disc (16)
-3.2mm pad (18)
-1.7mm disc (16)
-3.2mm pad (18)
-1.7mm disc (16)
-Fingerly Discy springy thingy (20)
-Fat bottom spacer (21)
-weird little washer shim with SPEED holes in it (22)
-Clutch bell (23)
I had a hard time getting everything together initially and ground a little bit of material off of the actuator(#7) so it fits together like a glove.
The trans cover would push on the actuator so I have a bout 2.5 mm of gasket and made a spacer out of some random tub lid until I can get a better spacer solution like aluminum or CPVC.
Works good. You can really goose it. Can't ride it too much cause my hand is still somewhat fucked and the clutch is super stiff. Gotta make sure all the bolts are still tight and finish up the wiring and seat and shit. Getting there.(edited)
  Have ye seen deez Sachs Clutch disksTopic by: DrGeorgeTompson (Alan) DrGeorgeTompson (Alan) 05/10/17 12:00PM
  Re: Have ye seen deez Sachs Clutch disksRe: MPB Andyrew MPB Andyrew 05/10/17 01:01PM
  Re: Have ye seen deez Sachs Clutch disksRe: Cpt. F. Cpt. F. 05/10/17 01:08PM
  Re: Have ye seen deez Sachs Clutch disksRe: DrGeorgeTompson (Alan) DrGeorgeTompson (Alan) 05/10/17 01:14PM
  Re: Have ye seen deez Sachs Clutch disksRe: Born to be WillD Born to be WillD 05/10/17 01:42PM
  Re: Have ye seen deez Sachs Clutch disksRe: DrGeorgeTompson (Alan) DrGeorgeTompson (Alan) 05/10/17 01:55PM
  Re: Have ye seen deez Sachs Clutch disksRe: Born to be WillD Born to be WillD 05/10/17 05:45PM
  Re: Have ye seen deez Sachs Clutch disksRe: DrGeorgeTompson (Alan) DrGeorgeTompson (Alan) 05/11/17 02:30AM
  Re: Have ye seen deez Sachs Clutch disksRe: Born to be WillD Born to be WillD 05/11/17 09:13AM
  Re: Have ye seen deez Sachs Clutch disksRe: DrGeorgeTompson (Alan) DrGeorgeTompson (Alan) 05/11/17 12:01PM
  Re: Have ye seen deez Sachs Clutch disksRe: DrGeorgeTompson (Alan) DrGeorgeTompson (Alan) 05/11/17 12:07PM
  Re: Have ye seen deez Sachs Clutch disksRe: Born to be WillD Born to be WillD 05/11/17 09:54PM
  Re: Have ye seen deez Sachs Clutch disksRe: MPB Andyrew MPB Andyrew 05/10/17 03:29PM
  Re: Have ye seen deez Sachs Clutch disksRe: DrGeorgeTompson (Alan) DrGeorgeTompson (Alan) 05/10/17 03:31PM
  Re: Have ye seen deez Sachs Clutch disksRe: ♣Slew Foot♣ ♣Slew Foot♣ 05/24/17 03:05PM
  Re: Have ye seen deez Sachs Clutch disksRe: DrGeorgeTompson (Alan) DrGeorgeTompson (Alan) 05/24/17 03:10PM
  Re: Have ye seen deez Sachs Clutch disksRe: MPB Andyrew MPB Andyrew 05/24/17 05:38PM
  Re: Have ye seen deez Sachs Clutch disksRe: DrGeorgeTompson (Alan) DrGeorgeTompson (Alan) 05/25/17 10:06AM
  Re: Have ye seen deez Sachs Clutch disksRe: Born to be WillD Born to be WillD 05/25/17 03:47PM
  Re: Have ye seen deez Sachs Clutch disksRe: DrGeorgeTompson (Alan) DrGeorgeTompson (Alan) 05/25/17 03:48PM
  Re: Have ye seen deez Sachs Clutch disksRe: Born to be WillD Born to be WillD 06/03/17 08:52AM
  Re: Have ye seen deez Sachs Clutch disksRe: DrGeorgeTompson (Alan) DrGeorgeTompson (Alan) 06/05/17 11:40AM
  Re: Have ye seen deez Sachs Clutch disksRe: DrGeorgeTompson (Alan) DrGeorgeTompson (Alan) 05/26/17 08:09PM
  Re: Have ye seen deez Sachs Clutch disksRe: Graham Motzing Graham Motzing 05/24/17 04:26PM
  Re: Have ye seen deez Sachs Clutch disksRe: DrGeorgeTompson (Alan) DrGeorgeTompson (Alan) 05/24/17 04:52PM
  Re: Have ye seen deez Sachs Clutch disksRe: DrGeorgeTompson (Alan) DrGeorgeTompson (Alan) 05/25/17 10:19AM
  Re: Have ye seen deez Sachs Clutch disksRe: skinee puppy skinee puppy 06/06/17 04:43PM
  Re: Have ye seen deez Sachs Clutch disksRe: DrGeorgeTompson (Alan) DrGeorgeTompson (Alan) 06/06/17 04:54PM
  Re: Have ye seen deez Sachs Clutch disksRe: - Dacruzer - - Dacruzer - 06/29/17 06:15PM
  Re: Have ye seen deez Sachs Clutch disksRe: MPB Andyrew MPB Andyrew 06/06/17 05:47PM
  Re: Have ye seen deez Sachs Clutch disksRe: MPB Andyrew MPB Andyrew 06/06/17 05:52PM
  Re: Have ye seen deez Sachs Clutch disksRe: skinee puppy skinee puppy 06/07/17 12:29PM
  Re: Have ye seen deez Sachs Clutch disksRe: DrGeorgeTompson (Alan) DrGeorgeTompson (Alan) 06/07/17 12:46PM
  Re: Have ye seen deez Sachs Clutch disksRe: ♣Slew Foot♣ ♣Slew Foot♣ 07/10/17 09:55AM
  Re: Have ye seen deez Sachs Clutch disksRe: MPB Andyrew MPB Andyrew 07/10/17 01:57PM
  Re: Have ye seen deez Sachs Clutch disksRe: DrGeorgeTompson (Alan) DrGeorgeTompson (Alan) 07/10/17 02:00PM
  Re: Have ye seen deez Sachs Clutch disksRe: skinee puppy skinee puppy 06/07/17 02:54PM
  Re: Have ye seen deez Sachs Clutch disksRe: CtpEDsHED . CtpEDsHED . 06/12/17 04:02AM
  Re: Have ye seen deez Sachs Clutch disksRe: DrGeorgeTompson (Alan) DrGeorgeTompson (Alan) 06/12/17 09:32AM
  Re: Have ye seen deez Sachs Clutch disksRe: DrGeorgeTompson (Alan) DrGeorgeTompson (Alan) 06/22/17 10:16AM
  Re: Have ye seen deez Sachs Clutch disksRe: MPB Andyrew MPB Andyrew 06/22/17 12:38PM
  Re: Have ye seen deez Sachs Clutch disksRe: DrGeorgeTompson (Alan) DrGeorgeTompson (Alan) 06/22/17 01:20PM
  Re: Have ye seen deez Sachs Clutch disksRe: MPB Andyrew MPB Andyrew 06/22/17 01:51PM
  Re: Have ye seen deez Sachs Clutch disksRe: skinee puppy skinee puppy 06/23/17 07:51PM
  Re: Have ye seen deez Sachs Clutch disksRe: DrGeorgeTompson (Alan) DrGeorgeTompson (Alan) 06/23/17 08:25PM
  Re: Have ye seen deez Sachs Clutch disksRe: skinee puppy skinee puppy 06/27/17 03:47PM
  Re: Have ye seen deez Sachs Clutch disksRe: DrGeorgeTompson (Alan) DrGeorgeTompson (Alan) 06/27/17 03:49PM
  Re: Have ye seen deez Sachs Clutch disksRe: skinee puppy skinee puppy 06/27/17 04:24PM
  Re: Have ye seen deez Sachs Clutch disksRe: DrGeorgeTompson (Alan) DrGeorgeTompson (Alan) 07/10/17 10:21AM
  Re: Have ye seen deez Sachs Clutch disksRe: DrGeorgeTompson (Alan) DrGeorgeTompson (Alan) 07/13/17 02:54PM
  Re: Have ye seen deez Sachs Clutch disksRe: DrGeorgeTompson (Alan) DrGeorgeTompson (Alan) 08/16/17 10:46AM
  Re: Have ye seen deez Sachs Clutch disksRe: Born to be WillD Born to be WillD 08/17/17 05:25PM
  Re: Have ye seen deez Sachs Clutch disksRe: skinee puppy skinee puppy 08/17/17 03:35PM
  Re: Have ye seen deez Sachs Clutch disksRe: DrGeorgeTompson (Alan) DrGeorgeTompson (Alan) 08/17/17 03:37PM
  Re: Have ye seen deez Sachs Clutch disksRe: skinee puppy skinee puppy 08/17/17 04:09PM
  Re: Have ye seen deez Sachs Clutch disksRe: DrGeorgeTompson (Alan) DrGeorgeTompson (Alan) 08/26/17 05:21PM
  Re: Have ye seen deez Sachs Clutch disksRe: DrGeorgeTompson (Alan) DrGeorgeTompson (Alan) 08/27/17 11:01PM
  Re: Have ye seen deez Sachs Clutch disksRe: DrGeorgeTompson (Alan) DrGeorgeTompson (Alan) 08/28/17 07:11PM
  Re: Have ye seen deez Sachs Clutch disksRe: DrGeorgeTompson (Alan) DrGeorgeTompson (Alan) 08/29/17 10:49AM
  Re: Have ye seen deez Sachs Clutch disksRe: MPB Andyrew MPB Andyrew 08/29/17 03:30PM
  Re: Have ye seen deez Sachs Clutch disksRe: skinee puppy skinee puppy 08/29/17 04:34PM
  Re: Have ye seen deez Sachs Clutch disksRe: DrGeorgeTompson (Alan) DrGeorgeTompson (Alan) 08/29/17 04:39PM
  Re: Have ye seen deez Sachs Clutch disksRe: skinee puppy skinee puppy 08/30/17 01:17PM
  Re: Have ye seen deez Sachs Clutch disksRe: DrGeorgeTompson (Alan) DrGeorgeTompson (Alan) 08/31/17 01:12PM
  Re: Have ye seen deez Sachs Clutch disksRe: EH FCC of the QCB EH FCC of the QCB 08/30/17 09:53PM
  Re: Have ye seen deez Sachs Clutch disksRe: Born to be WillD Born to be WillD 08/31/17 01:54PM
  Re: Have ye seen deez Sachs Clutch disksRe: DrGeorgeTompson (Alan) DrGeorgeTompson (Alan) 08/31/17 01:57PM
  Re: Have ye seen deez Sachs Clutch disksRe: Axldeziak . Axldeziak . 08/31/17 02:19PM
  Re: Have ye seen deez Sachs Clutch disksRe: DrGeorgeTompson (Alan) DrGeorgeTompson (Alan) 08/31/17 02:23PM
  Re: Have ye seen deez Sachs Clutch disksRe: MPB Andyrew MPB Andyrew 08/31/17 04:50PM
  Re: Have ye seen deez Sachs Clutch disksRe: Born to be WillD Born to be WillD 09/01/17 02:44PM
  Re: Have ye seen deez Sachs Clutch disksRe: skinee puppy skinee puppy 09/01/17 02:26PM
  Re: Have ye seen deez Sachs Clutch disksRe: Neil Shaddox Neil Shaddox 09/20/17 11:22AM
  Re: Have ye seen deez Sachs Clutch disksRe: DrGeorgeTompson (Alan) DrGeorgeTompson (Alan) 09/20/17 12:11PM
  Re: Have ye seen deez Sachs Clutch disksRe: DrGeorgeTompson (Alan) DrGeorgeTompson (Alan) 11/20/17 04:38PM
  Re: Have ye seen deez Sachs Clutch disksRe: Born to be WillD Born to be WillD 11/20/17 09:55PM
  Re: Have ye seen deez Sachs Clutch disksRe: DrGeorgeTompson (Alan) DrGeorgeTompson (Alan) 11/21/17 10:39AM
  Re: Have ye seen deez Sachs Clutch disksRe: Born to be WillD Born to be WillD 11/26/17 10:40AM
  Re: Have ye seen deez Sachs Clutch disksRe: P D P D 11/26/17 12:02PM
  Re: Have ye seen deez Sachs Clutch disksRe: Born to be WillD Born to be WillD 11/27/17 01:44PM
  Re: Have ye seen deez Sachs Clutch disksRe: P D P D 11/27/17 09:42PM
  Re: Have ye seen deez Sachs Clutch disksRe: DrGeorgeTompson (Alan) DrGeorgeTompson (Alan) 03/09/19 07:40AM
  Re: Have ye seen deez Sachs Clutch disksRe: DrGeorgeTompson (Alan) DrGeorgeTompson (Alan) 09/21/17 01:44PM
  Re: Have ye seen deez Sachs Clutch disksRe: skinee puppy skinee puppy 11/21/17 02:50PM
  Re: Have ye seen deez Sachs Clutch disksRe: DrGeorgeTompson (Alan) DrGeorgeTompson (Alan) 11/21/17 03:01PM
  Re: Have ye seen deez Sachs Clutch disksRe: skinee puppy skinee puppy 12/13/17 05:26PM
  Re: Have ye seen deez Sachs Clutch disksRe: DrGeorgeTompson (Alan) DrGeorgeTompson (Alan) 03/09/19 02:13PM
  Re: Have ye seen deez Sachs Clutch disksRe: Daniel '' Daniel '' 03/09/19 06:35PM
  Re: Have ye seen deez Sachs Clutch disksRe: MPB Andyrew MPB Andyrew 03/11/19 10:11AM
  Re: Have ye seen deez Sachs Clutch disksRe: DrGeorgeTompson (Alan) DrGeorgeTompson (Alan) 03/11/19 10:26AM
  Re: Have ye seen deez Sachs Clutch disksRe: Chris Squid Chris Squid 03/11/19 05:53PM
  Re: Have ye seen deez Sachs Clutch disksRe: Born to be WillD Born to be WillD 03/14/19 10:32AM
  Re: Have ye seen deez Sachs Clutch disksRe: DrGeorgeTompson (Alan) DrGeorgeTompson (Alan) 03/14/19 11:17AM
